zgp_init_by_scheduler not call at first startup of my device
I have a project of a device with 2 endpoint plus the GP endpoint (242). It's a coordinator.
at first startup, the green power endpoint doesn't appear in the response of a node descriptor request.
if I reboot my device, the GP endpoint appear in the response of the node descriptor request.
I have found that during the first boot, the zgp_init_by_scheduler  function, from libgppb.a is not call.
Is someone have some information about what is wrong in my device please ?
Jean-Philippe
  • Hi Jean-Philippe,
    This sounds like a possible reason. Is your device a GP Combo Basic device? One of the dependencies for this is that the device is not an end device (see CONFIG_ZIGBEE_GP_CB). So if that is the case it makes sense that it first checks whether the device is a router/coordinator before setting the GP end point as you are saying. However, I will have to check with the developers to confirm this for certain.
    I am not sure if that is a good workaround, as other parts will likely also be affected by which role you set before starting the stack, and thus you might get unexpected behavior if you try to switch to router afterwards. It would, however, be helpful if you could test with calling zb_set_network_coordinator_role or zb_set_network_router_role before zboss_start_no_autostart, just to verify whether this is the cause of the GP endpoint not being set or not.
    Marte
    Yes, my device is a GP Combo Basic device. And it's not an End device. It can be a ZC or a ZR, depending on event comes after the start.
    I have done the test with zb_set_network_coordinator_role or zb_set_network_router_role before zboss_start_no_autostart, and yes, with that, the endpoint appear after the first startup, without restart the device.
  • An other workaround I think to not modified my existing device:
    call zgp_init_by_scheduler in the signal handler 'zboss_signal_handler', at ZB_ZDO_SIGNAL_SKIP_STARTUP signal.
    Is it a more acceptable workaround ?
    I see that in the function 'zgp_init_by_scheduler', a booleen indicate if the initialisation is ever made or not.
    So, at first startup 'my call' is execute, and for next startup, the 'stack call' is execute.
    Best regard
  • Hi Jean-Philippe,
    Thank you for verifying. It is very helpful to know that this issue does not happen when the role is set before the stack is started.
    It is still not a good idea to start the stack before setting the device role. One possible solution I can think of is to do something similar to how Sleepy End Device (SED) behavior is set up in the light switch example. There, holding a specific button while resetting the board enables SED. This is implemented by sleepy_device_setup() being called in main() before the stack starts, which checks the state of the button and sets SED accordingly:
    static void sleepy_device_setup(void)
        zb_set_rx_on_when_idle(bsp_button_is_pressed(SLEEPY_ON_BUTTON) ? ZB_FALSE : ZB_TRUE);
    Since you are using button presses to select the role, would it be possible to do something similar on your device?
    Marte
    I am not understand well the SED example and what do the button.
    what did you call 'before start stack' ?
    This is the call of 'zboss_main_loop_iteration' or 'zboss_start_no_autostart' ?
    Thanks
