zgp_init_by_scheduler not call at first startup of my device
I have a project of a device with 2 endpoint plus the GP endpoint (242). It's a coordinator.
at first startup, the green power endpoint doesn't appear in the response of a node descriptor request.
if I reboot my device, the GP endpoint appear in the response of the node descriptor request.
I have found that during the first boot, the zgp_init_by_scheduler  function, from libgppb.a is not call.
Is someone have some information about what is wrong in my device please ?
Jean-Philippe
  • Hi Jean-Philippe,
    Do you see this happen with the existing examples in the SDK as well, or only with your project?
    Can you upload a sniffer log showing this (as a pcap file)?
    Marte
    I check with the CLI example, which doesn't have the problem.
    So, I think the problem is only in my project.
    PanId is 951B
    Nwk Key : F8 7B 44 41 6E D7 A1 D8 C1 B4 3E 29 E4 F2 DC 59
    My device is the coordinator : 0000 F4CE36F5E6C170DA
    capture no GP endpoint at first startup.pcapng
  • This project was before with SDK v4.1.0 and the behaviour is not present with this version, it appear with the v4.2.0
    Best regard
  • Hi Jean-Philippe,
    I have been trying to reproduce your issue without any success. Can you try to collect some trace logs of when this happens, both first boot where zgp_init_by_scheduler is not called and when you reboot? You can see how to enable trace logs in the documentation here: Debug. The trace logs will be printed as regular logging, and the output will not make much sense, but I can send it to the Zigbee team for decoding.
    Marte
    I haven't collect your data for the moment.
    But what I found, that in you CLI example, 'zb_set_network_coordinator_role' or 'zb_set_network_router_role' are called before the first call to 'zboss_start_no_autostart', and so before the first call to 'zboss_main_loop_iteration'.
    In my device, 'zb_set_network_coordinator_role' or 'zb_set_network_router_role' are called after a push button event and then all BDB process, so after 'zboss_start_no_autostart', and so after one or many call to 'zboss_main_loop_iteration'.
    My supposition is that during the first call to 'zboss_main_loop_iteration', the stack need to know if the device is a router or coordinator, fixed by 'zb_set_network_coordinator_role' or 'zb_set_network_router_role' to initialise the Green Power endpoint, which is not the case in my device (But this work with SDK v4.1.0).
    see comment in 'zboss_api_af.h', ligne 576:
      @note Device has an additional Green Power endpoint if it is ZC or ZR
      and GPPB feature (Mandatory for Zigbee 3.0 ZC/ZR) is enabled.
    Can you confirm this please ?
    For a workaround, do you think it 's possible for me to call 'zb_set_network_coordinator_role'  before 'zboss_start_no_autostart', to fix the GP endpoint initialisation, and when my push button event occur, call again 'zb_set_network_coordinator_role' or 'zb_set_network_router_role' depending on the need, and after that, the BDB process ?
    Jean-Philippe
