Moving gpio pin in device tree leads to error
in my device tree there are three nodes/items concerning battery Management:
  1. One load enable pin
  2. One measure enable pin
  3. the required ADC configuration
The following configuration works:
	batloaden {
		compatible = "gpio-keys";
		bat_load_en: bat_load {
			gpios = <&gpio1 12 GPIO_PUSH_PULL>;
			label = "batLoadEnPin";
	btmeasen {
		bt_meas_en: bt_meas {
			gpios = <&gpio1 14 GPIO_PUSH_PULL>;
			label = "btMeasEn";
	batmeasure {
		bat_adc_conf: bat_adc_conf {
			compatible = "bat-adc-config";
			resolution = <12>;
			gain = <6>;                  //Numeric value of ADC_GAIN_1
			stabilize_time = <3>;
The pin configuration is taken in my Code via
static const struct gpio_dt_spec BatMeasENpinspec = GPIO_DT_SPEC_GET(BAT_MEAS_EN_PIN_NODE, gpios);
But when I try to Group the whole measurement stuff into one node as
	batmeasure {
			resolution = <12>;
			reference = <4>;             //Numeric value of ADC_REF_INTERNAL
			aquisition_time = <0x4028>;  //Numeric value of ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 40)
			ucal_channel_id = <0>;
			ubat_channel_id = <1>;
			ucal_plus_input = <1>;             //Numeric value of NRF_SAADC_INPUT_AIN0
			ucal_minus_ubat_plus_input = <2>;  //Numeric value of NRF_SAADC_INPUT_AIN1
			ubat_minus_input = <3>;            //Numeric value of NRF_SAADC_INPUT_AIN2
			label = "btMeasEn";
I get the error identifier "__device_dts_ord_DT_N_S_batmeasure_S_bt_meas_P_gpios_IDX_0_PH_ORD" is undefined for the line static const struct gpio_dt_spec BatMeasENpinspec = GPIO_DT_SPEC_GET(BAT_MEAS_EN_PIN_NODE, gpios);
Practically I just moved the pin node from top into my matmeasure node.
The pin node is queried by
#define BAT_MEAS_EN_PIN_NODE    DT_NODELABEL(bt_meas_en)
which seems to work in both cases.
Is it required that all my gpio defines are at the top Level to get the Right __device_dts… define?
Regards
Erwin
  • I talked to a device tree expert and got some input. He was not able to look deply into your questions but made some quick comments.
    "The battery adc config is likely served better by existing bindings, like the nordic ADC or SAADC bindings perhaps, or maybe some bindings specific to batteries."
    Check out the sample \samples\boards\nrf\battery, it uses the vbatt node with the compatible voltage-divider
    "I’ll have to check about how this works in terms of which binding is supposed to match in this case actually. It’s definitely not clean and it’s enough of an edge case that I will need to check the source code to be sure. I wouldn’t recommend it either way"
    "It would be better to write a custom application specific binding describing the specific hardware in the customer application or reuse one if an existing general purpose one fits their needs"
  • I asked the devicetree expert internally these two questions:
    • Will the gpio-keys compatible apply to bat_adc_conf?
    • Is there any other consequences the customer can face doing it this way (placing a node with a separate compatible inside a gpio-keys node)?
    I got the following answers:
    "No. Nodes with explicit compatibles that have matching bindings always use those bindings. This check happens before falling back on a check for child bindings from a parent node."
    Is there any other consequences the customer can face doing it this way?
    "Probably not, but this is situation-dependent and it's impossible to guarantee no other errors could occur. For example if you used DT_FOREACH_CHILD() on the batmeasure node and got the GPIOs out of each child, this could lead to a build error on the bat_adc_conf node, which has no gpios property. Things like this are why it does not make sense to put that node there."
    Simon
  • Thank you very much. This answers all my questions.
    I will mark the answer before as verify Answer to close this ticket. According my understanding this is the right way to close it, right?
    Erwin
  • Happy to help!
    It should be enough to verify the answer, find the reply that answers the initial question of this DevZone ticket the best and verify that answer. Then the state of the ticket will be set to "Verified Answer".
    Simon
