Low Power Blinky Example - Power Consumption Problem - Power Profiler Kit II and nRF52840 DK
I have tried running Blinky example with some Low Power directives in the code without success. I came here for help then.
The current consumption used by the example, based on the Blinky sample, on the nRF52840 DK, stays around 2mA when the LED is off.
I am using NCS v2.1.0 and nRF52840 DK. I have used the Voltage Source meter mode for consumption measurement on the PPK II.
Here is the code:
4276.blinky.rar
Though the USB cable is connected to the DK in the image below, it is disconnected from the PC USB.
  • Hello
    Could you explain for me in a drawing how am I supposed to connect PPK to the nRF USB connector in the nRF52840DK?
    I am not sure how I connect PPK this way.
  • Hi thiago_hd,
    I think you have misunderstood me. I am talking about the same USB port on the DK's short edge as the one you are using.
    Your setup as in the picture is already fine, just connect the USB cable to a power source/PC.
    Hieu
  •  it doesnt make any sense to me to plug two power sources (USB and PPK) at the same time. Let me tell you what is the setup that I have.
    I plugged PPK's Vout and GND pins in the P21 External Supply connector + and - pins, respectively.
    I have the USB plugged (and powered, since you requested it) on J2 USB Connector (the same port we use for debugging/flashing).
    P22 (nRF current measurement) is short circuited
    SW8 (Power) switch is ON.
    SW10 (Vext -> nRF) is OFF.
    SW9 (nRF Power Source) is set to VDD (instead of Li-Po and USB).
    SW6 (nRF ONLY | DEFAULT) is set to DEFAULT.
    SW7 (TRACE) is set to Default.
    This is what is happening now:
  • Hi  ,
    Yes, I agree that it does not make much immediate sense why the measurement is only valid when you plug in the debugger cable.
    I tried to dive into the schematic to show you how it would work, but was not very successful due to my limited HW expertise. If you wish to fully understand the details, please let me know and I will try to pull in more knowledgeable people.
    But in any case, the J2 USB Connector has to be plugged in. I found an official source here: https://infocenter.nordicsemi.com/topic/ug_ppk2/UG/ppk/measure_current_source_meter.html
    The picture is small, but you can open it on a separate tab and zoom in to read the details.
    The source also points out one thing both you and I did wrong. PPK2-VOUT has to connect to nRF52840 DK P22 pin VDD_nRF (the pin would be the upper one in your picture.
    Unfortunately, I cannot reproduce this. Are you opening any VCOM maybe? What is your USB cable plugging into?
    Below is what I see in my setup yesterday and today:
    Yesterday setup, same as your original one, with J2 plugged in:
    Today setup, as instructed by the guide linked above
    Finally, here is my setup today
    USB plugged on J2 USB Connector
    P22-VDD_nRF (see picture) connected to PPK2-VOUT
    P21-Ground connected to PPK2-Ground
