Provisioning Certificates Kills GNSS in the asset tracker v2
Hi There.
I'm using the Asset Trackerv2 as a base for my application.
If I provision certificates at boot pior to enabling the LTE connection. the GNSS is never enabled.
*** Booting Zephyr OS build v3.1.99-ncs1 ***
[00:00:00.483,428] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
[00:00:00.483,489] <err> board_secure: Could not set buck to 1.8 V, error: -5
[00:00:00.483,489] <err> board_secure: power_mgmt_init failed with error: -5
[00:00:00.491,180] <err> ADXL362: wrong part_id: 255
[00:00:00.491,333] <err> ADXL372: failed to read id (0xFF:0xFF)
[00:00:00.491,455] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
[00:00:00.492,919] <inf> lis2dh: fs=2, odr=0x4 lp_en=0x0 scale=9576
[00:00:00.497,131] <inf> at_host: UART check failed: 12. Dropping buffer and retrying.
[00:00:00.507,324] <dbg> watchdog: watchdog_timeout_install: Watchdog timeout installed. Timeout: 60
[00:00:00.507,354] <dbg> watchdog: watchdog_start: Watchdog started
[00:00:00.507,385] <dbg> watchdog: watchdog_feed_enable: Watchdog feed enabled. Timeout: 30000
[00:00:00.507,568] <inf> opito: Provisioning certificates        <-----------------HERE
[00:00:00.599,884] <dbg> cloud_module: state_set: State: STATE_LTE_INIT
[00:00:00.599,914] <dbg> cloud_module: sub_state_set: Sub state: SUB_STATE_CLOUD_DISCONNECTED
[00:00:00.600,006] <dbg> data_module: state_set: State: STATE_CLOUD_DISCONNECTED
[00:00:00.600,433] <dbg> data_module: config_settings_handler: Device configuration loaded from flash
[00:00:00.600,463] <dbg> settings: settings_call_set_handler: set-value OK. key: data_module/config
[00:00:00.600,555] <dbg> date_time: date_time_core_register_handler: Registering handler 0x44737
[00:00:00.600,646] <dbg> modem_module: state_set: State transition STATE_INIT --> STATE_DISCONNECTED
[00:00:00.601,226] <dbg> gnss_module: state_set: State transition STATE_INIT --> STATE_RUNNING   <------------------------HERE
[00:00:00.601,470] <dbg> sensor_module: state_set: State: STATE_INIT
[00:00:00.601,501] <err> ext_sensors: Temperature sensor device is not ready
[00:00:00.601,501] <err> sensor_module: EXT_SENSOR_EVT_TEMPERATURE_ERROR
[00:00:00.601,531] <err> ext_sensors: Humidity sensor device is not ready
[00:00:00.601,562] <err> sensor_module: EXT_SENSOR_EVT_HUMIDITY_ERROR
[00:00:00.601,562] <err> ext_sensors: Pressure sensor device is not ready
[00:00:00.601,593] <err> sensor_module: EXT_SENSOR_EVT_PRESSURE_ERROR
[00:00:00.601,593] <err> ext_sensors: Low-power accelerometer device is not ready
[00:00:00.601,623] <err> sensor_module: EXT_SENSOR_EVT_ACCELEROMETER_ERROR
[00:00:00.601,715] <dbg> cloud_module: state_set: State transition STATE_LTE_INIT --> STATE_LTE_DISCONNECTED
[00:00:00.764,343] <inf> app_event_manager: APP_EVT_START
[00:00:00.764,434] <dbg> gnss_module: state_set: State transition STATE_RUNNING --> STATE_INIT                    <-------------------DEFINITELY HERE
[00:00:00.764,526] <dbg> ui_module: state_set: State transition STATE_INIT --> STATE_RUNNING
[00:00:00.764,556] <dbg> ui_module: sub_state_set: Sub state: SUB_STATE_ACTIVE
[00:00:00.764,556] <dbg> ui_module: sub_sub_state_set: Sub state: SUB_SUB_STATE_GNSS_INACTIVE
I've definitely tracked it to provisioning certificates - after hours of work.
The function call is standard
#if defined(CONFIG_MQTT_LIB_TLS)
static int certificates_provision(void){
    int err = 0;
    LOG_INF("Provisioning certificates");
#if defined(CONFIG_NRF_MODEM_LIB) && defined(CONFIG_MODEM_KEY_MGMT)
    //err = modem_key_mgmt_write(CONFIG_MQTT_TLS_SEC_TAG,
    err = modem_key_mgmt_write(24,
                   MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
                   ca_certificate,
                   strlen(ca_certificate));
    if (err) {
        LOG_ERR("Failed to provision CA certificate: %d", err);
        return err;
    return err;
#endif /* defined(CONFIG_MQTT_LIB_TLS) */
Any ideas?
Thanks
Marshall
  • Hello Marshall,
    I will get back to you on this.
    Elfving
  • Hello Marshall,
    Could you provide me the .conf file your are using? And could you run CEREG for me?
    Elfving
  • Hi Elfving - here is the complete prj.conf
    at+cereg? = +CEREG: 0,1,"A680","00054B02",7
    at+cereg=? = +CEREG: (0,1,2)
    I also have the aws.conf and the debug.conf as fragments in the build (these are unchanged)
    # Copyright (c) 2021 Nordic Semiconductor ASA
    # General config
    CONFIG_NEWLIB_LIBC=y
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    CONFIG_FPU=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=47250
    CONFIG_MAIN_STACK_SIZE=1408
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_HW_STACK_PROTECTION=y
    # Increase AT monitor heap size to be able to fit both neighbor cell measurement
    # and other AT notifications that may come in rapid succession.
    CONFIG_AT_MONITOR_HEAP_SIZE=1024
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_MODE_DEFERRED=y
    # nRF modem library
    CONFIG_NRF_MODEM_LIB=y
    # AT Host library - Used to send AT commands directy from an UART terminal and to allow
    #		    integration with nRF Connect for Desktop LTE Link monitor application.
    CONFIG_AT_HOST_LIBRARY=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_IPV6=y
    CONFIG_NET_IPV4=y
    # LTE link control
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    ## Power saving timers.
    ### 320 hours PSM.
    CONFIG_LTE_PSM_REQ_RPTAU="11000001"
    ### 20 seconds active time.
    CONFIG_LTE_PSM_REQ_RAT="00001010"
    # Settings - Used to store real-time device configuration to flash.
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_FCB=y
    CONFIG_FCB=y
    # FOTA
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_DFU_TARGET=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300
    CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=128
    # Flash - Used in FOTA, settings and storage for P-GPS.
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_STREAM_FLASH=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # MCUBOOT
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # Watchdog
    CONFIG_WATCHDOG_APPLICATION=y
    # Application Event Manager
    CONFIG_APP_EVENT_MANAGER=y
    CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=n
    # cJSON - Used in cloud data encoding.
    CONFIG_CJSON_LIB=y
    # CAF - Common Application Framework
    CONFIG_CAF=y
    CONFIG_LED=y
    CONFIG_CAF_LEDS=y
    CONFIG_CAF_INIT_LOG_LED_READY_EVENTS=n
    CONFIG_CAF_INIT_LOG_LED_EVENTS=n
    CONFIG_CAF_INIT_LOG_MODULE_STATE_EVENTS=n
    # Default cloud transport service
    CONFIG_NRF_CLOUD_AGPS=n
    CONFIG_MODEM_ANTENNA_AT_MAGPIO="AT%XMAGPIO=1,1,1,7,1,746,803,2,698,748,2,1710,2200,3,824,894,4,880,960,5,791,849,7,1565,1586"
    CONFIG_MODEM_ANTENNA_AT_COEX0="AT%XCOEX0=1,1,1565,1586"
    CONFIG_NRFX_PWM1=y
    CONFIG_NRFX_PWM2=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    #MKB Additions Oct 22
    #for key loading automatically.
    CONFIG_MODEM_KEY_MGMT=y
    CONFIG_MAIN_STACK_SIZE=4096
    #for Flash
    #for LED WS2812.
    CONFIG_LED_STRIP=y
    CONFIG_WS2812_STRIP=y
    #CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.1.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
    #CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.1.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
    CONFIG_NRFX_SPIM1=y
    CONFIG_NRFX_TWIM2=y
    CONFIG_SPI_NOR=y
    CONFIG_SPI_NOR_IDLE_IN_DPD=y
    CONFIG_LIS2DH=y
    CONFIG_LIS2DH_TRIGGER_GLOBAL_THREAD=y
    CONFIG_LIS2DH_ACCEL_RANGE_2G=y
  • %XMONITOR: 1,"One NZ","One NZ","53001","A680",7,28,"00166103",,,,,"","00001010","11000001","01001111"
