Hi All, trying to find a cause of this problem, we have two devices, one is acting as peripheral and one as master.
Peripheral: (nRF52832, s132 v7.0.1) a remote wireless sensor just sitting and waiting for request to send data using NUS, and once request is received it sends data back immediately, data length is 20 bytes.
Central: (nRF52832, s132 v7.0.1), a device that reads data from above mentioned remote sensor. Used example code from SDK16 for UART Central and modified it adding repeated timer scheduled event every 500ms to just send "ble_nus_c_string_send" command to trigger remote sensor to send data back. This repeated sensor polling only starts after receiving BLE_GAP_EVT_CONNECTED event and once BLE_GAP_EVT_DISCONNECTED happens, polling stops.
With that 500ms delay sensor polling speed It works fine and sensor reporting data without issues, however I need to speed up polling speed from 500ms to 250ms and if I do that, once central connected to the peripheral it sends requests and receives data until I turn sensor off by removing battery, in that case central crashes and never reporting BLE_GAP_EVT_DISCONNECTED event. It just reboots after executing "ble_nus_c_string_send".
I need to implement a check if connection is live before executing another "ble_nus_c_string_send" and my idea was to do it by catching BLE_GAP_EVT_CONNECTED and BLE_GAP_EVT_DISCONNECTED events to start or stop polling. But as I mentioned above the problem is that once peripheral is turned off, central never gets to BLE_GAP_EVT_DISCONNECTED event. Monitoring BLE_GATTS_EVT_HVN_TX_COMPLETE did not help as this even does not even get triggered.
What would you suggest to find a cause of this problem?
Thank you.
