I am trying to implement external flash storage onto my custom board, featuring an nrf9160-SICA-B1 and a Winbound w25q128jv 128Mbit flash chip on SPI3 (I cannot get QSPI to work in devicetree).
I am able to successfully read the entire flash chip through a small test script using the base flash_read APIs, however as soon as I enable either CONFIG_NVS or CONFIG_FILE_SYSTEM_LITTLEFS the board no longer boots, and debugging has only gotten me so far with an exception handler break somewhere inside TFM. I am unsure on how to debug this further, or what the root cause is. It's not clear what exactly breaks, as I don't even need to implement anything in my storage module (remove from cmake) and the board will still refuse to boot (or at least output to UART) so I assume something is wrong inside the TFM side of things.
Stepping through with the debugger it never gets past FIH_CALL(tfm_core_init, fih_rc);
It also appears that the partitions are not being placed into the external flash as I would expect, just looking at the partition yaml file. I tried static partition config but that also didn't help, and I am unsure on how to proceed for that as the documentation is unclear.
My end goal, is to have 16MB (128MBit) of flash memory available to either littlefs or NVS for storing persistent data offline while waiting for LTE to sync.
SPI3 Definition:
&spi3 {
label = "SPI3";
status = "okay";
cs-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&spi3_default>;
pinctrl-1 = <&spi3_sleep>;
w25q128jv: w25q128jv@0 {
compatible = "jedec,spi-nor";
label = "W25Q128JV_SPI";
reg = <0x0>;
spi-max-frequency = <80000000>;
wp-gpios = <&gpio0 8 GPIO_ACTIVE_LOW>;
hold-gpios = <&gpio0 10 GPIO_ACTIVE_LOW>;
size = <DT_SIZE_M(16)>;
// has-dpd;
// t-enter-dpd = <4000>;
// t-exit-dpd = <25000>;
jedec-id = [ ef 40 18 ];
chosen {
nordic,pm-ext-flash = &w25q128jv;
Partition Definition:
/delete-node/ &storage_partition;
&w25q128jv {
partitions {
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "storage";
reg = <0x0 DT_SIZE_M(16)>;
My prj.conf
#### Flash Storage #### CONFIG_SPI=y CONFIG_SPI_NOR=y CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096 CONFIG_NORDIC_QSPI_NOR=n CONFIG_FLASH=y CONFIG_FLASH_MAP=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FILE_SYSTEM=y CONFIG_FS_LOG_LEVEL_DBG=y # Uncommenting either of these causes the board to not run # CONFIG_FILE_SYSTEM_LITTLEFS=y # CONFIG_NVS=y
Happy to provide more debugging information as necessary, just not sure what to include. I may be missing something.
