why can cause this problem! I'm not familiar with NCS OTA
The error refers to the magic image number that is used in MCUboot (0x96f3b83d), and that is not found as expected in the image. Where does this .bin file come from? Are you sure it is a valid update image?
I use NCS 1.5.1 uart example (ncs1.5.1\nrf\samples\bluetooth\peripheral_uart) add the ota, but fail
Steps are as follows
1. add this code to prj.conf
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_BT_L2CAP_TX_MTU=252
#CONFIG_BT_BUF_ACL_RX_SIZE=256 this in NCS2.0.0 is ok but ncs1.5.1 without it so CONFIG_BT_ACL_RX_COUNT replace it
CONFIG_BT_ACL_RX_COUNT=256
CONFIG_MCUMGR_SMP_BT=y
CONFIG_MCUMGR_SMP_BT_AUTHEN=n
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
2.add this code to main.c
I used this same approach successfully in NCS2.0 。but NCS1.5.1 without CONFIG_BT_BUF_ACL_RX_SIZE and OTA failed。 the reson is MCUmgr disconnecting
and how to open the OTA LOG
The only way I am able to reproduce this is by using an invalid image. Can you clarify which image file you use with nRF Connect? You should use the file called "app_update_bin", and this is found under build/zephyr.
app_update.zipthis is the .bin
