NRF52832-QFAA-R GPIO abnormal
Hi Nordic expert,
We are K5DET1/3/5/7/9/11 output high level, then string 10K resistor, K5DET2/4/6/8/10/12 through the mercury switch to read this high level, while adding 1M puldown resistor.
Normally, after the mercury switch is on, the K5DET2-12 pin level should be about 3.6V, but some pins will actually measure 1.2, 1.8, 2.1 and other abnormal levels.
Please help to check whether there is any problem with the hardware. What may cause an I/O exception?
The battery is a lithium sub battery with an open circuit voltage of 3.66V and a maximum continuous discharge current of 50MA.
Looking forward to your professional answers,,thanks.
