nRF53 peripheral cannot accept multiple connections - advertising fails while connected
Using a simple example application, which works on nRF52, but fails on nRF53, using the Nordic Connect SDK:
- nRF53 in peripheral mode
- connectable advertising
- BT_MAX_CON > 1
- Can accept a single connection, but re-enabling advertising fails while connected
- Therefore, cannot accept a second connection.
Curiously, this works fine on nRF52.
Also curiously, this works fine on vanilla Zephyr, instead of NCS (https://github.com/zephyrproject-rtos/zephyr)
The error log on the nRF53 is: (bt_hci_core: opcode 0x200a status 0x09)
[00:00:00.462,249] <dbg> bt_conn: bt_conn_set_state: disconnected -> connecting-adv
[00:00:00.462,249] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
[00:00:00.462,341] <dbg> bt_conn: bt_conn_prepare_events:
[00:00:00.463,226] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
Updated MTU: TX: 23 RX: 23 bytes
Connected
[00:01:03.034,393] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
[00:01:03.034,393] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
[00:01:03.034,423] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
[00:01:03.034,484] <dbg> bt_conn: bt_conn_set_state: disconnected -> connecting-adv
[00:01:03.034,484] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
[00:01:03.034,576] <dbg> bt_conn: bt_conn_prepare_events:
[00:01:03.035,308] <wrn> bt_hci_core: opcode 0x200a status 0x09
[00:01:03.035,339] <dbg> bt_conn: bt_conn_set_state: connecting-adv -> disconnected
[00:01:03.035,339] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
[00:01:03.035,369] <dbg> bt_conn: bt_conn_unref: handle 0 ref 1 -> 0
[00:01:03.035,369] <dbg> bt_conn: bt_conn_set_state: connecting-adv -> connected
[00:01:03.039,337] <dbg> bt_conn: bt_conn_set_state: disconnected -> connecting-adv
[00:01:03.039,337] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
[00:01:03.039,428] <dbg> bt_conn: bt_conn_prepare_events:
[00:01:03.039,428] <dbg> bt_conn: conn_prepare_events: Adding conn 0x200012e8 to poll list
[00:01:03.040,161] <wrn> bt_hci_core: opcode 0x200a status 0x09
[00:01:03.040,191] <dbg> bt_conn: bt_conn_set_state: connecting-adv -> disconnected
[00:01:03.040,191] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
[00:01:03.040,191] <dbg> bt_conn: bt_conn_unref: handle 0 ref 1 -> 0
[00:01:03.040,283] <dbg> bt_conn: bt_conn_prepare_events:
I have attached a minimal sample application, which can reproduce the problem.
The gist of the application is:
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err 0x%02x)\n", err);
	} else {
		printk("Connected\n");
    bt_le_adv_resume(); // or: bt_start_advertising();
and CONFIG_BT_MAX_CONN=4 in prj.conf
Here's the full sample:
5037.ble-advertising-while-connect-sample.zip
