I have written a word (32 bites) in 0xFF000 using nrf_fstorage_write(), When BLEInit(), nrf_fstorage_evt() callback not trigged,
BLE_Sleept()
nrf_storage_write()
BLE_wakeup()
BLE_Sleept()
nrf_storage_write()
BLE_wakeup()
I noticed a few problems with your write_to_flash() implementation, please see diff below for details. I did not review the other functions in your code.
diff --git a/source/Infa.c b/source/Infa.c
index 2168665..bca5633 100644
--- a/source/Infa.c
+++ b/source/Infa.c
@@ -38,7 +38,7 @@ NRF_FSTORAGE_DEF(nrf_fstorage_t my_instance) = {
bool write_to_flash(uint32_t SAddr,uint32_t dLen,uint8_t *wData)
ret_code_t rc=0;
- NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
+ //NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen; // Remove. NVMC cannot be accessed when Softdevice is enabled
rc = nrf_fstorage_write(&my_instance, /* The instance to use. */
SAddr, /*
@@ -49,10 +49,14 @@ bool write_to_flash(uint32_t SAddr,uint32_t dLen,uint8_t *wData)
NULL /* Optional parameter, backend-dependent. */
- app_sched_execute();
+ // app_sched_execute(); // This function is meant to be called from the main loop
// nrf_delay_ms(1000);
//iDebug("\r\nflash write.... \r\n");
- while(nrf_fstorage_is_busy(&my_instance));
+ /* Remove while loop here. It will block forever if called from an interrupt context.
+ * Note that fstorage can queue up multiple write operations so a wait loop like this should normally
+ * be reduntant
+ //while(nrf_fstorage_is_busy(&my_instance));
if (rc == NRF_SUCCESS) {
//iDebug("\r\nflash write success");
@@ -508,7 +512,10 @@ void StartRadarApp()
iDebug(" fs pgnum %ul",pgnum);
iDebug(" fs pgsize %ul ",pgsize);
read_from_flash(0xFF064,42);
+ static uint32_t data = 0xAAAAAAAA;
+ /* Test write */
+ write_to_flash(0xFF064, sizeof(uint32_t), (uint8_t *) &data);
nrf_delay_ms(100);
for (;;)
Thank you for reviewing, i will check
