I am working on BLE MESH using nRF52840. I am trying to put nRF52840 into deep sleep mode. For this I am referring to lpn example in BLE Mesh which makes use of Friend Node. As per documentation, using Friend Node it is possible to put node in Deep Sleep.
My setup:
nRF SDK ver : nRF5_SDK_17.0.2_d674dde
BLE MESH ver : nrf5_SDK_for_Mesh_v5.0.0
Hardware : BT840 based custom board
I am tryting to compile lpn example from examples - nrf5_SDK_for_Mesh_v5.0.0\examples\lpn. It looks like the example needs some modification in order to compile. The example shows this error while compiling.
..\nrf5_sdk_17.0.2_d674dde\modules\nrfx\drivers\include\nrfx_power_clock.h:67:6: error: #error "This code is not supposed to be compiled when neither POWER nor CLOCK is enabled."67 | #error "This code is not supposed to be compiled when neither POWER nor CLOCK is enabled."
POWER_ENABLED and NRFX_POWER_ENABLED is already 1 in the example code. So upon enabling macros NRF_CLOCK_ENABLED and NRFX_CLOCK_ENABLED or it shows further compilation errors. I was wondering if this is a right way to go about it.
nRF5_SDK_17.0.2_d674dde/external/segger_rtt/SEGGER_RTT_Conf.h:86:46: error: 'SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS' undeclared here (not in a function); did you mean 'SEGGER_RTT_MAX_NUM_DOWN_BUFFERS'?86 | #define SEGGER_RTT_MAX_NUM_DOWN_BUFFERS (SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS) // Max. number of down-buffers (H->T) available on this target (Default: 3)| ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../nRF5_SDK_17.0.2_d674dde/external/segger_rtt/SEGGER_RTT_Conf.h:86:46: note: in definition of macro 'SEGGER_RTT_MAX_NUM_DOWN_BUFFERS'86 | #define SEGGER_RTT_MAX_NUM_DOWN_BUFFERS (SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS) // Max. number of down-buffers (H->T) available on this target (Default: 3)| ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Kindly let me know the changes/modification required to compile lpn example.
Best Regards,
Rajendra
