Fatal errors when attempting to configure GPIOs with custom DTS file
I am trying to configure GPIOs with a custom DTS file, for initial bring-up and testing of the PCBA prior to higher-level development.  During compile, I am getting a message "FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.0.0\opt\bin\cmake.EXE' --build 'c:\nordic\V1_man-in-middle_new\build'", but there I am not seeing any issues in the 'problems' tab of VS code.
If I comment out line 42, the compile executes cleanly.
if (!device_is_ready(led0.port)) {
		return;
Do you have any recommendations of where to start looking to debug this?
 * Copyright (c) 2012-2014 Wind River Systems, Inc.
#include <zephyr.h>
#include <sys/printk.h>
#include <device.h>
#include <drivers/pwm.h>
#include <drivers/gpio.h>
// Define the pins in the Nordic connection
// Bar Light
#define LED0_NODE DT_ALIAS(ledbar0)
#define LED1_NODE DT_ALIAS(ledbar1)
#define LED2_NODE DT_ALIAS(ledbar2)
#define LED3_NODE DT_ALIAS(ledbar3)
// Button lights
#define LEDBL_NODE DT_ALIAS(ledbuttonl)
#define LEDBR_NODE DT_ALIAS(ledbuttonr)
// Generate structs for LEDs
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(LED1_NODE, gpios);
static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(LED2_NODE, gpios);
static const struct gpio_dt_spec led3 = GPIO_DT_SPEC_GET(LED3_NODE, gpios);
static const struct gpio_dt_spec ledBL = GPIO_DT_SPEC_GET(LEDBL_NODE, gpios);
static const struct gpio_dt_spec ledBR = GPIO_DT_SPEC_GET(LEDBR_NODE, gpios);
// // switches
// #define SW0_NODE	DT_ALIAS(buttonl)
// #define SW1_NODE	DT_ALIAS(buttonr)
// static const struct gpio_dt_spec button0 = GPIO_DT_SPEC_GET(SW0_NODE, gpios);
// static const struct gpio_dt_spec button1 = GPIO_DT_SPEC_GET(SW1_NODE, gpios);
void main(void)
	int ret;
		return;
	// /* // Verify that the device is ready for use
	// if (!device_is_ready(button0.port)) {
	// 	return;
	// ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
	// ret += gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
	// ret += gpio_pin_configure_dt(&led2, GPIO_OUTPUT_ACTIVE);
	// ret += gpio_pin_configure_dt(&led3, GPIO_OUTPUT_ACTIVE);
	// if (ret < 0) {
	// 	return;
	// ret = gpio_pin_configure_dt(&button0, GPIO_INPUT);
	while(1){
		/*  Read the status of the button and store it */
        // bool val = gpio_pin_get_dt(&button0);
		/* STEP 6.2 - Update the LED to the status of the button */
		// gpio_pin_toggle_dt(&led0);
		// gpio_pin_toggle_dt(&led1);
		// gpio_pin_toggle_dt(&led2);
		// gpio_pin_toggle_dt(&led3);
        k_msleep(1000); // Put the main thread to sleep for 100ms for power optimization
DTS file:
// Copyright (c) 2022 Nordic Semiconductor ASA
// SPDX-License-Identifier: Apache-2.0
/dts-v1/;
#include <nordic/nrf52840_qiaa.dtsi>
	model = "10_000010_00_Throttle_Splitter";
	compatible = "fifteen-motors,10-000010-00-throttle-splitter";
	chosen {
		zephyr,sram = &sram0;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
	leds {
		compatible = "gpio-leds";
		ledbar0: led_0 {
			gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
			label = "LED Bar 0";
		ledbar1: led_1 {
			gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
			label = "LED Bar 1";
		ledbar2: led_2 {
			gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
			label = "LED Bar 2";
		ledbar3: led_3 {
			gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
			label = "LED Bar 3";
		ledbuttonl: led_l {
			gpios = <&gpio0 24 GPIO_ACTIVE_LOW>;
			label = "LED Button Left";
		ledbuttonr: led_r {
			gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
			label = "LED Button Right";
	/* These aliases are provided for compatibility with samples */
	aliases {
		// buttonl = &buttonl;
		// buttonr = &buttonr;
		ledbar0 = &ledbar0;
		ledbar1 = &ledbar1;
		ledbar2 = &ledbar2;
		ledbar3 = &ledbar3;
		ledbuttonl = &ledbuttonl;
		ledbuttonr  = &ledbuttonr;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x0 0xc000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0xc000 0x72000>;
		slot1_partition: partition@7e000 {
			label = "image-1";
			reg = <0x7e000 0x72000>;
		scratch_partition: partition@f0000 {
			label = "image-scratch";
			reg = <0xf0000 0xa000>;
		storage_partition: partition@fa000 {
			label = "storage";
			reg = <0xfa000 0x6000>;
