[Matter] light bulb example (from nRF SDK) cannot bind Cluster 8 to light-switch-app (from original chip-Repo)
Following Setup:
1.) Building light-switch-app from original https://github.com/project-chip/connectedhomeip Repo for nRF5340 from command line with nRF SDK v2.1.0
cd <connecthomeip-repo>
source scripts/activate.sh
source <nrf-sdk-path>/zephyr/zephyr-env.sh
cd examples/light-switch-app/nrfconnect
west build -b nrf5340dk_nrf5340_cpuapp
2.) Building light-bulb example from nRF SDK with nRF VS Code Extension
Following steps to adapted this example to run on nRF52840 USB Dongle --> (Why is this example not available for nRF52840 USB Dongle out off the box???)
Create a pm_static_nrf52840dongle_nrf52840_no_dfu.yml file in root dir of example. Following content:
settings_storage:
    address: 0xd8000
    region: flash_primary
open_bootloader:
    address: 0xe0000
Create a nrf52840dongle_nrf52840_no_dfu.conf file in boards dir of example. Following content:
#    Copyright (c) 2022 Project CHIP Authors
#    Licensed under the Apache License, Version 2.0 (the "License");
#    you may not use this file except in compliance with the License.
#    You may obtain a copy of the License at
#        http://www.apache.org/licenses/LICENSE-2.0
#    Unless required by applicable law or agreed to in writing, software
#    distributed under the License is distributed on an "AS IS" BASIS,
#    WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
#    See the License for the specific language governing permissions and
#    limitations under the License.
# Configure logging over USB
# - do enable shell to reduce flash usage
# - disable CDC ACM logs as it may lead to infinite loop when CDC ACM is used as the log backend
CONFIG_USB_DEVICE_STACK=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_LOG_BACKEND_UART=y
CONFIG_SHELL_LOG_BACKEND=n
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_CDC_ACM_LOG_LEVEL_OFF=y
# The minimal logging mode does not work properly with the USB CDC device, so use the deferred mode
CONFIG_LOG_MODE_MINIMAL=n
CONFIG_LOG2_MODE_DEFERRED=y
CONFIG_LOG_BUFFER_SIZE=8192
# Reduce the code size as the dongle reserves some space for MBR and Open Bootloader
CONFIG_ASSERT_VERBOSE=n
CONFIG_SHELL=n
CONFIG_OPENTHREAD_SHELL=n
# Use partition manager to configure the settings partition not to overlap with Open Bootloader
CONFIG_PM_SINGLE_IMAGE=y
# Disable factory data support.
# --> disabled cause nRF create application don't know about these CONFIG_PARMS
#CONFIG_CHIP_FACTORY_DATA=n
#CONFIG_CHIP_FACTORY_DATA_BUILD=n
Create nrf52840dongle_nrf52840.overlay file in boards dir of example. Following content:
 *    Copyright (c) 2021 Project CHIP Authors
 *    Licensed under the Apache License, Version 2.0 (the "License");
 *    you may not use this file except in compliance with the License.
 *    You may obtain a copy of the License at
 *        http: //www.apache.org/licenses/LICENSE-2.0
 *    Unless required by applicable law or agreed to in writing, software
 *    distributed under the License is distributed on an "AS IS" BASIS,
 *    WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 *    See the License for the specific language governing permissions and
 *    limitations under the License.
 	chosen {
 		zephyr,console = &cdc_acm_uart0;
&zephyr_udc0 {
	cdc_acm_uart0: cdc_acm_uart0 {
		compatible = "zephyr,cdc-acm-uart";
		label = "CDC_ACM_0";
Change CMakeLists.txt in root dir of example. File content should look like:
# Copyright (c) 2021 Nordic Semiconductor ASA
cmake_minimum_required(VERSION 3.20.0)
get_filename_component(MATTER_MODULE_ROOT $ENV{ZEPHYR_BASE}/../modules/lib/matter REALPATH)
# Set Kconfig root files that will be processed as a first Kconfig for used child images.
set(mcuboot_KCONFIG_ROOT ${MATTER_MODULE_ROOT}/config/nrfconnect/chip-module/Kconfig.mcuboot.root)
set(multiprotocol_rpmsg_KCONFIG_ROOT ${MATTER_MODULE_ROOT}/config/nrfconnect/chip-module/Kconfig.multiprotocol_rpmsg.root)
if(NOT CONF_FILE STREQUAL "prj_no_dfu.conf" AND NOT BOARD STREQUAL "nrf52840dongle_nrf52840")
    set(PM_STATIC_YML_FILE ${CMAKE_CURRENT_SOURCE_DIR}/configuration/${BOARD}/pm_static_dfu.yml)
endif()
find_package(Zephyr HINTS $ENV{ZEPHYR_BASE})
project(matter-light-bulb)
set(COMMON_ROOT ${ZEPHYR_NRF_MODULE_DIR}/samples/matter/common)
set(NLIO_ROOT ${MATTER_MODULE_ROOT}/third_party/nlio/repo)
include(${MATTER_MODULE_ROOT}/config/nrfconnect/app/enable-gnu-std.cmake)
include(${MATTER_MODULE_ROOT}/src/app/chip_data_model.cmake)
# NORDIC SDK APP START
target_include_directories(app PRIVATE
    src
    ${COMMON_ROOT}/src
    ${NLIO_ROOT}/include
    ${MATTER_MODULE_ROOT}/zzz_generated/app-common
target_sources(app PRIVATE
    src/app_task.cpp
    src/lighting_manager.cpp
    src/main.cpp
    src/zcl_callbacks.cpp
    src/zap-generated/IMClusterCommandHandler.cpp
    src/zap-generated/callback-stub.cpp
    ${COMMON_ROOT}/src/led_widget.cpp
    ${COMMON_ROOT}/src/thread_util.cpp
if(CONFIG_CHIP_OTA_REQUESTOR)
    target_sources(app PRIVATE ${COMMON_ROOT}/src/ota_util.cpp)
endif()
if(CONFIG_MCUMGR_SMP_BT)
    target_sources(app PRIVATE ${COMMON_ROOT}/src/dfu_over_smp.cpp)
endif()
chip_configure_data_model(app
    INCLUDE_SERVER
    ZAP_FILE ${CMAKE_CURRENT_SOURCE_DIR}/src/light_bulb.zap
if (CONFIG_SHELL AND BOARD STREQUAL "nrf52840dongle_nrf52840")
  target_sources(app PRIVATE ${NRFCONNECT_COMMON}/util/DFUTrigger.cpp)
endif()
# NORDIC SDK APP END
Change the main.c in src dir of the example. Like this
 * Copyright (c) 2021 Nordic Semiconductor ASA
#include "app_task.h"
#if DT_NODE_HAS_COMPAT(DT_CHOSEN(zephyr_console), zephyr_cdc_acm_uart)
#include <zephyr/drivers/uart.h>
#include <zephyr/usb/usb_device.h>
LOG_MODULE_REGISTER(app, CONFIG_MATTER_LOG_LEVEL);
using namespace ::chip;
static int InitUSB()
    int err = usb_enable(nullptr);
    if (err)
        LOG_ERR("Failed to initialize USB device");
        return err;
    const struct device * dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
    uint32_t dtr              = 0;
    while (!dtr)
        uart_line_ctrl_get(dev, UART_LINE_CTRL_DTR, &dtr);
        k_sleep(K_MSEC(100));
    return 0;
int main()
	CHIP_ERROR err = CHIP_NO_ERROR;
    err = System::MapErrorZephyr(InitUSB());
	err = GetAppTask().StartApp();
	LOG_ERR("Exited with code %" CHIP_ERROR_FORMAT, err.Format());
	return err == CHIP_NO_ERROR ? EXIT_SUCCESS : EXIT_FAILURE;
Now you can build the light-build example for nRF52840 USB Dongle.
Copy the light-bulb application to the nRF52840 by nRF Programmer Tool.
3.) Pair both matter devices to an existing or new created thread-network with chip-tool
4.) Set the ACL access for the light-bulb
sudo ./chip-tool accesscontrol write acl '[{"fabricIndex": 1, "privilege": 5, "authMode": 2, "subjects": [112233], "targets": null}, {"fabricIndex": 1, "privilege": 3, "authMode": 2, "subjects": [light-switch-id], "targets": [{"cluster": 6, "endpoint": 1, "deviceType": null}, {"cluster": 8, "endpoint": 1, "deviceType": null}]}]' light-bulb-id 0
There is an error in the chip tool log
1665610428271] [16033:1856894] CHIP: [EM] >>> [E:4373i M:3817318090 (Ack:115418483)] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
[1665610428272] [16033:1856894] CHIP: [EM] OnMessageReceived failed, err = ../connectedhomeip/examples/chip-tool/third_party/connectedhomeip/src/messaging/ExchangeMgr.cpp:305: CHIP Error 0x00000070: Unsolicited msg with originator bit clear
[1665610428457] [16033:1856854] CHIP: [EM] >>> [E:4374i M:11470867 (Ack:81659602)] (S) Msg RX from 1:0000000000000100 [0BB5] --- Type 0001:07 (IM:WriteResponse)
5.) Create the binding to cluster 6 and cluster 8 for the light-switch
sudo ./chip-tool binding write binding '[{"fabricIndex": 1, "node": light-bulb-id, "endpoint": 1, "cluster": 6}, {"fabricIndex": 1, "node": light-bulb-id, "endpoint": 1, "cluster": 8}]' light-switch-id 1
There is an error in the Log of the light-switch application (nRF5340DK) during the binding:
I: 327706 [EM]<<< [E:47538i M:132360026 (Ack:3817318092)] (U) Msg TX to 0:0000000000000000 [0000] --- Type
I: 327719 [IN](U) Sending msg 132360026 to IP address 'UDP:[fdf9:547d:593b:1:cd8:1a0f:d500:29a2]:5540'
D: 327729 [EM]Flushed pending ack for MessageCounter:3817318092 on exchange 47538i
I: 327737 [EM]>>> [E:47538i M:3817318093 (Ack:132360023)] (U) Msg RX from 0:0000000000000000 [0000] --- Ty
E: 327750 [EM]OnMessageReceived failed, err = 70
6.) Press the button 2 of the nRF5340DK Board to toggle the light-bulb on the nRF52840 Dongle. (works).
7.) Press button 2 for longer time to dim the LED of the light-bulb --> That doesn't work (seems to be a binding error)
I: 397578 [DMG]Received Command Response Status for Endpoint=1 Cluster=0x0000_0008 Command=0x0000_0000 Sta
tus=0x85
E: Binding command was not applied! Reason: 585
