Hello. I'm relatively new to zephyr and working with nrf's and I'm experiencing a modem error when running the mqtt_simple sample project that I cant resolve.
Upon booting, i get the following result:
The only change I've made to the sample project is configuring mqtt variables and adding "CONFIG_LOG=y" in prj.conf
I think the first modem error is the root cause, because i also got this when trying to run a simple application (simply a printk() in main)
I've spent days trying to figure out what this means and how to fix it, but without luck. I was told that the nrf9160dk hardware is relatively old, so I suspected some version compatibility issues, however after revising the compatibility matrices online, I could not find any faults there.
I did find the nrf_errno.h in /nrfxlib/nrf_modem/, which says this error code means "no child process", however I couldnt figure out what that means and how to fix it. I've built this using the nrf connect sdk (version 2.1.99-dev1) which I installed manually by following the official guide. Before you ask why Im not using the nrf connect desktop app to automatically install - it is because we (3-4 students) got error messages we couldn't resolve when installing it automatically.
So my question is what is causing this error and how can I fix it?
I'll try to list all relevant specs, but please let me know if you need to know more.
OS: Ubuntu 20.4
nRF9160dk hardware version: 0.8.4 (PCA10090)
nrf connect sdk version: 2.1.99-dev1 (got same error running v2.1.0)
zephyr-sdk version: 0.14.1
modem firmware version: 1.3.2
Attaching the build output so you can get the full picture of the build system:
oscar@oscar-desktop:~/ncs/nrf/samples/nrf9160/mqtt_simple$ west build --board nrf9160dk_nrf9160_ns --pristine
-- west build: making build dir /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build pristine
-- Application: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple
-- Found Python3: /usr/bin/python3.8 (found suitable exact version "3.8.10") found components: Interpreter
-- Cache files will be written to: /home/oscar/.cache/zephyr
-- Zephyr version: 3.1.99 (/home/oscar/ncs/zephyr)
-- Board: nrf9160dk_nrf9160_ns, Revision: 0.7.0
-- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
-- Found host-tools: zephyr 0.14.1 (/home/oscar/zephyr-sdk-0.14.1)
-- Found dtc: /home/oscar/zephyr-sdk-0.14.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (/home/oscar/zephyr-sdk-0.14.1)
-- Found BOARD.dts: /home/oscar/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
-- Generated zephyr.dts: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/dts.cmake
Parsing /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/Kconfig
Loaded configuration '/home/oscar/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
Merged configuration '/home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/prj.conf'
Configuration saved to '/home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/.config'
Kconfig header saved to '/home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: /home/oscar/zephyr-sdk-0.14.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
Dropping partition 'nonsecure_storage' since it is empty.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build
[5/291] Preparing syscall dependency handling
[28/291] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (/home/oscar/ncs/zephyr), build: v3.1.99-ncs1-10-gd4b8ac4db1ed
[58/291] Generating ../../tfm/CMakeCache.txt
-- Found Python3: /usr/bin/python3.8 (found version "3.8.10") found components: Interpreter
-- Configuring done
-- Generating done
-- Build files have been written to: /home/oscar/ncs/nrf/samples/nrf9160/mqtt_simple/build/tfm
[63/291] Performing build step for 'tfm'
[1/2] Re-running CMake...
-- Configuring done
-- Generating done
[169/169] Linking C static library secure_fw/libtfm_s_veneers.a
[65/291] Performing install step for 'tfm'
-- Install configuration: "MinSizeRel"
[279/291] Linking C executable zephyr/zephyr_pre0.elf
[283/291] Linking C executable zephyr/zephyr_pre1.elf
[289/291] Linking C executable zephyr/zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 106616 B 992 KB 10.50%
SRAM: 21760 B 211736 B 10.28%
IDT_LIST: 0 GB 2 KB 0.00%
[291/291] Generating zephyr/merged.hexprj.conf:
# # Copyright (c) 2020 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # Networking CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y # LTE link control CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n # Modem library CONFIG_NRF_MODEM_LIB=y # MQTT CONFIG_MQTT_LIB=y CONFIG_MQTT_LIB_TLS=n CONFIG_MQTT_CLEAN_SESSION=y # Application # CONFIG_MQTT_PUB_TOPIC="my/publish/topic" # CONFIG_MQTT_SUB_TOPIC="my/subscribe/topic" # CONFIG_MQTT_CLIENT_ID="my-client-id" # CONFIG_MQTT_BROKER_HOSTNAME="test.mosquitto.org" # CONFIG_MQTT_BROKER_PORT=1883 # Button support CONFIG_DK_LIBRARY=y # Enable logging CONFIG_LOG=y CONFIG_MQTT_SIMPLE_LOG_LEVEL_DBG=y # Memory CONFIG_MAIN_STACK_SIZE=4096 CONFIG_HEAP_MEM_POOL_SIZE=2048 # NewLib C CONFIG_NEWLIB_LIBC=y # Shell support CONFIG_SHELL=y
