No response from nRF52820 when DFU is attempted again
Hello everyone,
I have successfully managed to perform a DFU with a DFU package consisting of an app and a softdevice. I wanted to test what happens when I manually cancel the DFU and then try to start a new DFU.
After I cancelled the DFU of the app and restarted the DFU, the DFU works without any problems and the app starts as expected.
However, after I cancel the DFU of the softdevice and restart the DFU, there is no response from the nRF in the DFU after a certain point.
This is the log where the DFU of SD + App worked:
log_ok.txt
This is the log where the DFU of SD + App did not work (after I cancelled the DFU of the softdevice manually):
log_fail.txt
In the log where the DFu didn't work, I see that flash memory is written to from address 0x27000. However, this is the area of the application. I would have expected that first in the area of the softdevices is written, because this was also so in the log where the DFU has worked.
Is this possibly a bug?
Best Regards
Louis
