No response from nRF52820 when DFU is attempted again
Hello everyone,
I have successfully managed to perform a DFU with a DFU package consisting of an app and a softdevice. I wanted to test what happens when I manually cancel the DFU and then try to start a new DFU.
After I cancelled the DFU of the app and restarted the DFU, the DFU works without any problems and the app starts as expected.
However, after I cancel the DFU of the softdevice and restart the DFU, there is no response from the nRF in the DFU after a certain point.
This is the log where the DFU of SD + App worked:
log_ok.txt
This is the log where the DFU of SD + App did not work (after I cancelled the DFU of the softdevice manually):
log_fail.txt
In the log where the DFu didn't work, I see that flash memory is written to from address 0x27000. However, this is the area of the application. I would have expected that first in the area of the softdevices is written, because this was also so in the log where the DFU has worked.
Is this possibly a bug?
Best Regards
Louis
  • the softdevice+application DFU worked with nrfutil version 6.1.7.
  • It also works for me if I don't cancel the DFU manually. For me, it's about simulating an error case where the DFU terminates for some reason in the later product and you have to restart the DFU via remote. If I abort the DFU while the softdevice is being updated, and restart the DFU afterwards, then it won't work anymore. I also use nrfutil version 6.1.7.
    Maybe you could test if it works for you. So during the first part of the DFU (Softdevice DFU) disconnect the nRF from power and then restart the DFU again.
  • i checked when device mode on dfu then i power off and then again connect it is show me on dfu mode
    but i used nrf52832 module
  • My device is also in DFU mode but when I restart the DFU, then after a certain point no response comes from the nrf52820. Have you ever tested a SD+App DFU? As I described it in the original post
    As I said, the DFU itself works. But when I cancel it manually and restart it, it no longer works. At the beginning, data is also transferred, but at some point there is no longer a response from the nRF. As can be seen in the logs in the original post, I think the bytes from the softdevices are also written to the wrong place in the flash memory (0x27000, but this is the beginning of my application). Normally the bytes should be written from address 0x1000. For these reasons, I think this may be a bug.
    This is the log of the DFU, after I cancelled the the previous DFU manually while the softdevice is being updated:
    00> <info> app: boot: Inside main
    00> <debug> app: In nrf_bootloader_init
    00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    00> <debug> nrf_dfu_settings: Using settings page.
    00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    00> <info> nrf_dfu_settings: Backing up settings page to address 0x3E000.
    00> <debug> app: Enter nrf_bootloader_fw_activate
    00> <info> app: No firmware to activate.
    00> <info> app: Boot validation failed. No valid app to boot.
    00> <debug> app: DFU mode because app is not valid.
    00> <info> nrf_bootloader_wdt: WDT is not enabled
    00> <debug> app: timer_stop (0x20002A64)
    00> <debug> app: timer_activate (0x20002A64)
    00> <info> app: Entering DFU mode.
    00> <debug> app: dfu: NRF_DFU_EVT_DFU_INITIALIZED
    00> <debug> app: Initializing transports (found: 1)
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    00> <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    00> <debug> app: dfu: NRF_DFU_EVT_TRANSPORT_ACTIVATED
    00> <debug> nrf_dfu_validation: PB: Init packet data len: 69
    00> <debug> app: Enter main loop
    00> <debug> nrf_dfu_serial: Received ping 1
    00> <info> nrf_dfu_serial_uart: Allocated buffer 200041F0
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    00> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    00> <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    00> <debug> nrf_dfu_serial: Set receipt notif target: 0
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    00> <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    00> <debug> nrf_dfu_serial: Received serial mtu
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    00> <debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    00> <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    00> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    00> <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    00> <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00027000, len=1 pages), queue usage: 0
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00027000, pending 0
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
    00> <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    00> <info> nrf_dfu_serial_uart: Allocated buffer 20004274
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027000, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027040, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027080, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000270C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000270C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027100, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027140, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027180, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000271C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000271C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027200, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027240, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027280, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000272C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000272C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027300, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027300, pending 0
    00> a)
    00> x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027340, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027380, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027380, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000273C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000273C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027400, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027400, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027440, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027440, pending 0
    00> a)
    00> ding 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027600, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027600, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027640, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027640, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027680, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027680, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000276C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000276C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027700, src=0ding 0
    00> 0x1
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000278C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000278C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027900, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027900, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027940, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027940, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027980, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027980, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000279C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000279C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A00, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027A00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A40, src=0a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A80, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027A80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027AC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027AC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B00, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027B00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027B40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B80, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027B80, pending 0
    00> 0x1
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C00, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027C00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027C40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027C80, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027C80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027CC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027CC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027D00, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00027D00, pending 0
    00> 0x1
    00> a)
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
    00> <debug> app: dfu: NRF_DFU_EVT_OBJECT_RECEIVED
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00028000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00028000, pending 0
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00001000, CRC: 0x36E4BF70
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028000, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028040, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028080, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000280C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000280C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028100, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028140, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028180, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000281C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000281C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028200, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028240, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028280, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000282C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000282C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028300, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028300, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000283C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000283C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028400, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028400, pending 0
    00> <info> nrf_dfu_serial_uart: Allocated buffer 200042F8
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028440, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028440, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028480, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028480, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000284C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000284C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028500, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028500, pending 0
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028640, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028680, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028680, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000286C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000286C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028700, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028700, pen<info> nrf_dfu_serial_uart: Allocated buffer 200042F8
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028A40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028A80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028A80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028AC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028AC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028B00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028B40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028B80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028B80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028BC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028BC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028C00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028C40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028C80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028C80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028CC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028CC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028D00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028D00, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028DC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028DC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028E00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028E40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028E80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028E80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028EC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028EC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00028F00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00028F00, pending 0
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00029000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00029000, pending 0
    00> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00002000, CRC: 0x57D22D0B
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029000, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029040, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029080, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000290C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000290C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029100, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029140, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029180, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000291C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000291C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029200, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029240, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029280, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000292C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000292C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029300, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029300, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029340, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029340, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029380, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029380, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029680, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029680, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000296C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000296C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029700, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029700, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029740, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029740, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029780, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029780, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000297C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000297C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029800, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029800, pending 0
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029840, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029880, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029880, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000298C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000298C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029900, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029900, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029940, src=0x20004278, len=64 bytes), queue usage: 1
    00> ding 0
    00> 0x1
    00> a)
    00> ding 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029C40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029C80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029C80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029CC0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029CC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029D00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029D40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029D80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029D80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029DC0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029DC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00029E00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00029E00, pending 0
    (Connection lost)
    This is the log of the DFU, after I cancelled the the previous DFU manually while the app is being updated:
    00> <debug> nrf_dfu_validation: PB: Init packet data len: 64
    00> <debug> app: Shutting down transports (found: 1)
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
    00> <debug> app: dfu: NRF_DFU_EVT_DFU_STARTED
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
    00> <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    00> <info> nrf_dfu_validation: Signature required. Checking signature.
    00> <info> nrf_dfu_validation: Calculating hash (len: 69)
    00> <info> nrf_dfu_validation: Verify signature
    00> <info> nrf_dfu_validation: Image verified
    00> <debug> app: Enter nrf_dfu_cache_prepare()
    00> <debug> app: required_size: 0x25634.
    00> <debug> app: single_bank: true.
    00> <debug> app: keep_app: false.
    00> <debug> app: keep_softdevice: false.
    00> <debug> app: SD_PRESENT: true.
    00> <debug> app: Bank contents:
    00> <debug> app: Bank 0 code: 0x00: Size: 0x0
    00> <debug> app: Bank 1 code: 0x00: Size: 0x0
    00> <debug> app: pass: 0.
    00> <debug> app: cache_address: 0x27000.
    00> <debug> app: cache_too_small: true.
    00> <debug> app: keep_firmware: false.
    00> <debug> app: delete_more: true.
    00> <debug> app: pass: 1.
    00> <debug> app: pass: 2.
    00> <debug> app: cache_address: 0x1000.
    00> <debug> app: cache_too_small: false.
    00> <debug> app: keep_firmware: true.
    00> <debug> app: Invalidating SoftDevice.
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003004, src=0x0003C358, len=4 bytes), queue usage: 0
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003004, pending 0
    00> <debug> app: Invalidating app.
    00> <debug> nrf_dfu_validation: Write address set to 0x00001000
    00> <debug> nrf_dfu_settings: Writing settings...
    00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0003F000
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0003F000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0003F000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0003F000, src=0x20004774, len=896 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0003F000, pending 0
    00> <debug> nrf_dfu_settings: Erasing old settings at: 0x0003E000
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0003E000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x0003E000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0003E000, src=0x200043F4, len=896 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x0003E000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00001000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00001000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001000, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001040, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001080, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000010C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000010C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001100, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001140, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001180, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000011C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000011C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001200, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001240, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001280, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000012C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000012C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001300, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001300, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001340, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001340, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001380, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001380, pending 0
    00> a)
    00> ding 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001400, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001400, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001440, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001440, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001480, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001480, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000014C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000014C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001500, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001500, pending 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001640, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001640, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001680, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001680, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000016C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000016C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001700, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001700, pending 0
    00> a)
    00> 0x1
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000018C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000018C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001900, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001900, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001940, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001940, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001980, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001980, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000019C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000019C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001A00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001A00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001A40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001A40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001A80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001A80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001AC0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001AC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001B00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001B00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001B40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001B40, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001C40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001C40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001C80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001C80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001CC0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001CC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001D00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001D00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001D40, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001D40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001D80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001D80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00001FC0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00001FC0, pending 0
    00> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    00> <debug> nrf_dfu_req_handler: Offset:4096, CRC:0x36E4BF70
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00002000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00002000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002000, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002040, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002080, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000020C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000020C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002100, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002140, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002180, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000021C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000021C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002200, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002240, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002280, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000022C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000022C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002300, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002300, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002340, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002340, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002400, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002440, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002440, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002480, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002480, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000024C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000024C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002500, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002500, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002540, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002540, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002580, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002780, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002780, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000027C0, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000027C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002800, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002800, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002840, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002840, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002880, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002880, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000028C0, src=0ding 0
    00> 0x1
    00> a)
    00> ding 0
    00> 0x1
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002940, src=0x200041F4, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002940, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002980, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002980, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000029C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000029C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002A00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002A00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002A40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002A40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002A80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002A80, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> ding 0
    00> 0x1
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002CC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002CC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002D00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002D00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002D40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002D40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002D80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002D80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002DC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002DC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002E00, src=0ding 0
    00> 0x1
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002E40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002E40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002E80, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002E80, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002EC0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002EC0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002F00, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002F00, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002F40, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00002F40, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00002F80, src=0ding 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00003000, len=1 pages), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash erase success: addr=0x00003000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003000, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003000, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003040, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003040, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003080, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003080, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000030C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000030C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003100, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003100, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003140, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003140, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003180, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003180, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000031C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000031C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003200, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003200, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003240, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003240, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003280, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003280, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000032C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000032C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003300, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003300, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003340, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003340, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003380, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003380, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000033C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000033C0, pending 0
    00> a)
    00> ding 0
    00> 0x1
    00> a)
    00> a)
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003680, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003680, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000036C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000036C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003700, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003700, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003740, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003740, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003780, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003780, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000037C0, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x000037C0, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003800, src=0x200042FC, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003800, pending 0
    00> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00003840, src=0x20004278, len=64 bytes), queue usage: 1
    00> <debug> nrf_dfu_flash: Flash write success: addr=0x00003840, pending 0
    00> 0x1
    (Connection lost)
      Can you help out, maybe?
  • , this is a known limitation, unfortunately. From the SDK release notes:
    ** DFU **
    - NRFFOETT-2579: If the transfer is aborted when transferring a SoftDevice to a device
      with no SoftDevice present (using sd-req = 0), the device can erroneously think that the SoftDevice
      was transferred correctly. On smaller devices there could be no room
      to transfer the SoftDevice again.
      Workaround: Transfer any application with sd-req set to 0.
      The application must be at least 3 pages (0x3000 bytes) long.
      The application will overwrite the SoftDevice, allowing it to be retransferred.
    In other words, to allow the SD update to be attempted again, you have to prepare a dummy app update which can overwrite the Softdevice first.
