How to add the descriptions of GATT Primary Service(0x2800) and GATT characteristic? Just like the picture below.
Hi
You can use sd_ble_gatts_descriptor_add() to add Characteristic User Descriptions to your characteristics.
You can do something like this:
static uint32_t our_descriptor_add(ble_os_t * p_our_service, uint16_t char_handle)
uint32_t err_code; // Variable to hold return codes from library and softdevice functions
ble_gatts_attr_md_t attr_md;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
ble_uuid_t attr_uuid;
attr_uuid.uuid = BLE_UUID_DESCRIPTOR_CHAR_USER_DESC;
ble_uuid128_t base_uuid = {0x23, 0xD1, 0x13, 0xEF, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}; // 128-bit base UUID
err_code = sd_ble_uuid_vs_add(&base_uuid, &attr_uuid.type);
uint8_t attr_value[] = "Your User description";
const uint16_t attr_len = sizeof(attr_value);
ble_gatts_attr_t attr;
memset(&attr, 0, sizeof(attr));
attr.init_len = attr_len;
attr.max_len = attr_len;
attr.init_offs = 0;
attr.p_value = attr_value;
attr.p_attr_md = &attr_md;
attr.p_uuid = &attr_uuid;
err_code = sd_ble_gatts_descriptor_add(char_handle, &attr, &p_our_service->descr_handle);
return err_code;
Please have a look at e.g. the ble_app_hids_mouse example in e.g. SDK 9.0.0. It shows how to add descriptors like this.
Hi, Martin Børs-Lind
I can't find the example how to add descriptors in the ble_app_hids_mouse example . And, what is the ble_os_t and and char_handle in the code you showed above. Can you tell me how to use the "our_descriptor_add()" detailedly?
The example is located in "your_sdk_folder\examples\ble_peripheral\ble_app_hids_mouse". The sd_ble_gatts_descriptor_add() function is used in e.g. the rep_char_add() function found in ble_hids.c file.
The code above is copy-pasted from a random example i made. ble_os_t and char_handle are just residues from that example. ble_os_t is a service struct containing data about the service being worked on and char_handle is the handle to the characteristic that you want to add a descriptor to. If you want to use the code above you will have to modify it a bit to fit your particular application.
