BLE characteristic ( Longer than 20 Bytes. ) notification not working. NCS.
Hi There,
I am currently developing the firmware for a peripheral device using the NRF52840 and NCS V2.0.0.
At the moment everything is working as expected except for notifying characteristics longer than 20 Bytes. I am aware that the extension of the ATT MTU is possible as I have in the past got this working with the classic SDK however I am still new to NCS.
The following errors occur when I try to send these notifications: Larger than 20 Bytes.
[00:01:06.056,304] <wrn> bt_att: No ATT channel for MTU 26
[00:01:06.057,006] <wrn> bt_gatt: No buffer available to send notification
And the bt_gatt_notify() function returns the value -128.
The project configuration prj.conf looks like this:
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
CONFIG_BT=y
CONFIG_BT_DEBUG_LOG=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="NGP-BL"
#BLE Allow connection parameters update.
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
CONFIG_BT_PERIPHERAL_PREF_MAX_INT=100
CONFIG_BT_PERIPHERAL_PREF_MIN_INT=100
#BLE Buffering configuration.
CONFIG_BT_ATT_PREPARE_COUNT=20
CONFIG_BT_BUF_ACL_TX_COUNT=20
CONFIG_BT_BUF_ACL_RX_COUNT=20
CONFIG_BT_BUF_ACL_RX_SIZE=251
CONFIG_BT_BUF_ACL_TX_SIZE=251
CONFIG_BT_L2CAP_TX_MTU=247
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_RX_STACK_SIZE=4096
# Bluetooth PHY selection.
CONFIG_BT_CTLR_PRIVACY=n
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_CTLR_PHY_2M=y
# BLE Configuration.
CONFIG_BT_DEVICE_NAME_DYNAMIC=y
# Enable power management module
CONFIG_PM=y
# Required to disable default behavior of deep sleep on timeout
CONFIG_PM_DEVICE=y
CONFIG_REBOOT=y
# Peripheral Configuration
CONFIG_GPIO=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
CONFIG_ADC=y
CONFIG_PWM=n
# Native peripheral configuration
CONFIG_NRFX_PWM0=y
CONFIG_NRFX_PPI=y
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_TIMER2=y
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_SAADC=y
# Multiprotocol service layer.
CONFIG_MPSL=y
CONFIG_RING_BUFFER=y
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=1
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=y
CONFIG_SERIAL=y
# Enable console
CONFIG_CONSOLE=y
# Enable RTT logging.
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
# Allow use of sprintf and print
CONFIG_NEWLIB_LIBC=y
# Logging subsystem configuration
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
# Use this mode for time sensitive logging
# CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_LOG_BACKEND_SHOW_COLOR=y
CONFIG_LOG_INFO_COLOR_GREEN=y
# Allow system to use internal low frequency RC for Softdevice.
CONFIG_HEAP_MEM_POOL_SIZE=16384
The central device I am using is the nrf52840 USB Dongle, and the Bluetooth Low Energy Standalone V4.0.0, I doubt the configuration on the central device is the issue as I have a couple of different devices which work fine with it notifying characteristics up to 247 bytes long. But based of the classic SDK.
To my my understanding the following lines define the MTU size however it does not work.
Any idea as to why this may happen ?
Secondly, How could I set the value of a particular characteristic ? in the previous SDK versions I would have used the following function:
sd_ble_gatts_value_set();
Is there a equivalent to this in NCS ?
Cheers,
