Failed to build spim program on 5340 net core
I have met problem on net core when I moved my program which can be built on app core. I want to use bluetooth and spim, so I close the uart0. I get this error when building:
[3/13] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && D:\code\bluetooth\v1.9.1\toolchain\opt\bin\arm-none-eabi-gcc.exe   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=D:/zhaoyuan_data/dsp/brain_usb/nRF/peripheral_spim/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp"  -LD:/zhaoyuan_data/dsp/brain_usb/nRF/peripheral_spim/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m33+nodsp  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  D:/code/bluetooth/v1.9.1/nrfxlib/mpsl/lib/cortex-m33+nodsp/soft-float/libmpsl.a  D:/code/bluetooth/v1.9.1/nrfxlib/softdevice_controller/lib/cortex-m33+nodsp/soft-float/libsoftdevice_controller_multirole.a && cmd.exe /C "cd /D D:\zhaoyuan_data\dsp\brain_usb\nRF\peripheral_spim\build\zephyr && D:\code\bluetooth\v1.9.1\toolchain\opt\bin\cmake.exe -E echo ""
d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 3748 bytes
d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(main.c.obj):D:\zhaoyuan_data\dsp\brain_usb\nRF\peripheral_spim\src\main.c:102: undefined reference to `__device_dts_ord_39'
d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: zephyr/drivers/console/libdrivers__console.a(uart_console.c.obj): in function `uart_console_init':
D:\code\bluetooth\v1.9.1\zephyr\drivers\console\uart_console.c:599: undefined reference to `__device_dts_ord_45'
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'd:\code\bluetooth\v1.9.1\toolchain\opt\bin\cmake.EXE' --build 'd:\zhaoyuan_data\dsp\brain_usb\nRF\peripheral_spim\build'
# Copyright (c) 2018 Nordic Semiconductor
# Enable the UART driver
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_UARTE0=n
CONFIG_SERIAL=y
CONFIG_GPIO=y
# Make sure printk is printing to the UART console
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
CONFIG_BT_DEVICE_APPEARANCE=833
CONFIG_BT_MAX_CONN=1
CONFIG_BT_MAX_PAIRED=1
CONFIG_NFCT_PINS_AS_GPIOS=y
# Enable the NUS service
CONFIG_BT_NUS=y
# Enable bonding
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
# Enable DK LED and Buttons library
CONFIG_DK_LIBRARY=y
# This example requires more workqueue stack
# Config logger
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_ASSERT=y
CONFIG_NRFX_SPIM0=y
CONFIG_NRFX_PRS_BOX_2=y
# This is needed for using another SPIM instance via the Zephyr SPI driver.
CONFIG_SPI=y
  • Here are sdk and board I use
    - nRF connect SDK 1.9.1
    - nRF5340 DK
    Try disabling these configs:
    CONFIG_SERIAL
    CONFIG_CONSOLE
    CONFIG_UART_CONSOLE
  • Hello Oivind,
    I have disabled these conifgs, but I still get the same error:
    [166/176] Linking C executable zephyr\zephyr_pre0.elf
    cmd.exe /C "cd . && D:\code\bluetooth\v1.9.1\toolchain\opt\bin\arm-none-eabi-gcc.exe   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=D:/zhaoyuan_data/dsp/brain_usb/nRF/peripheral_spim/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a  zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a  zephyr/subsys/net/libsubsys__net.a  zephyr/subsys/random/libsubsys__random.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/spi/libdrivers__spi.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/entropy/libdrivers__entropy.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a  modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/subsys/bluetooth/controller/lib..__nrf__subsys__bluetooth__controller.a  modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a  modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a  modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -L"d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp"  -LD:/zhaoyuan_data/dsp/brain_usb/nRF/peripheral_spim/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m33+nodsp  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  D:/code/bluetooth/v1.9.1/nrfxlib/mpsl/lib/cortex-m33+nodsp/soft-float/libmpsl.a  D:/code/bluetooth/v1.9.1/nrfxlib/softdevice_controller/lib/cortex-m33+nodsp/soft-float/libsoftdevice_controller_multirole.a && cmd.exe /C "cd /D D:\zhaoyuan_data\dsp\brain_usb\nRF\peripheral_spim\build\zephyr && D:\code\bluetooth\v1.9.1\toolchain\opt\bin\cmake.exe -E echo ""
    d:/code/bluetooth/v1.9.1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `FLASH' overflowed by 3508 bytes
  • It's not the same error, now it complains about a lack of space in the flash.
    It looks like you based this on the peripheral_uart sample, is there a reason for this? The flash on the network core is quite limited, could you have based it on a smaller sample?
