I have MCUBOOT working using the default UART pin numbers. I need to change the UART RX and TX pin numbers used by MCUBOOT for a custom application. I am able to change the UART pin numbers used in the application firmware by creating an overlay file and referencing the overlay file with a -DDTC_OVERLAY_FILE:STRING= argument in the extra CMake arguments in the VS Code build configuration.
I read the examples given on DevZone and created an overlay file for MCUBOOT.called mcuboot_dtc.overlay as shown below. This file is in a child_image directory.
&uart0_default { group1 { psels = <NRF_PSEL(UART_TX, 0, 0)>, <NRF_PSEL(UART_RTS, 0, 5)>; }; group2 { psels = <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_CTS, 0, 7)>; bias-pull-up; }; }; &uart0_sleep { group1 { psels = <NRF_PSEL(UART_TX, 0, 0)>, <NRF_PSEL(UART_RX, 0, 8)>, <NRF_PSEL(UART_RTS, 0, 5)>, <NRF_PSEL(UART_CTS, 0, 7)>; low-power-enable; }; };
I added lines to the CMakeLists.txt file to reference the overlay file.
cmake_minimum_required(VERSION 3.20.0) find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE}) project(blinky) set(mcuboot_DTC_OVERLAY_FILE ${CMAKE_CURRENT_SOURCE_DIR}/child_image/mcuboot_dtc.overlay ) set(mcuboot_CONF_FILE ${CMAKE_CURRENT_SOURCE_DIR}/child_image/mcuboot.conf ) target_sources(app PRIVATE src/main.c)
After these additions MCUBOOT is still using the default UART pin numbers. Is this the right approach? What could I missing?
Your help is appreciated.
Ray
