Hi friend,
I am using SDK16.0 and softdevice is S140 7.0.1 version. But SPI can only send out 1 byte. It can't call back the function of spi_event_handler, so my code is locked while checking spi_xfer_done.
Can someone help me? My code snippet is below.
Thank you in advance.
static void cc1101_gpio_init(void)
nrf_gpio_pin_dir_set(CC1101A_SS_PIN, NRF_GPIO_PIN_DIR_OUTPUT);
nrf_gpio_pin_set(CC1101A_SS_PIN);
nrf_gpio_pin_dir_set(CC1101B_SS_PIN, NRF_GPIO_PIN_DIR_OUTPUT);
nrf_gpio_pin_set(CC1101B_SS_PIN);
nrf_gpio_pin_dir_set(CC1101A_PWR_PIN, NRF_GPIO_PIN_DIR_OUTPUT);
nrf_gpio_pin_clear(CC1101A_PWR_PIN);
nrf_gpio_pin_dir_set(CC1101B_PWR_PIN, NRF_GPIO_PIN_DIR_OUTPUT);
nrf_gpio_pin_clear(CC1101B_PWR_PIN);
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void *p_context)
spi_xfer_done = true;
void cc1101_spi_init(void)
nrf_drv_spi_config_t const spi_config =
.sck_pin = CC1101_SCK_PIN,
.mosi_pin = CC1101_MOSI_PIN,
.miso_pin = CC1101_MISO_PIN,
.ss_pin = NRF_DRV_SPI_PIN_NOT_USED,
.irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY,
.orc = 0xFF,
.frequency = NRF_DRV_SPI_FREQ_125K,
.mode = NRF_DRV_SPI_MODE_0,
.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST
APP_ERROR_CHECK(nrf_drv_spi_init(&m_spi, &spi_config, spi_event_handler, NULL));
//|==================== SPI Initialisation for CC1101 =========================|
void cc1101_spi_begin(void)
/* configure SPI */
cc1101_gpio_init();
cc1101_spi_init();
//-------------------------------[end]------------------------------------------
uint8_t cc1101_spi_putc(uint8_t data)
uint8_t statusByte;
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi, &data, 1, NULL, 0));
while(!spi_xfer_done) {}
APP_ERROR_CHECK(nrf_drv_spi_transfer(&m_spi, NULL, 0, &statusByte, 1));
//----------------------[CC1101 init functions]---------------------------------
uint8_t cc1101_begin(uint8_t *My_addr)
uint8_t CC1101_freq_select, CC1101_mode_select, CC1101_channel_select;
uint8_t partnum, version;
cc1101_spi_begin(); //inits SPI Interface
// cc1101_reset(); //CC1101 init cc1101_reset
cc1101_spi_write_strobe(SFTX);nrf_delay_us(100);//flush the TX_fifo content
cc1101_spi_write_strobe(SFRX);nrf_delay_us(100);//flush the RX_fifo content
partnum = cc1101_spi_read_register(PARTNUM); //reads CC1101 partnumber
version = cc1101_spi_read_register(VERSION); //reads CC1101 version number
//checks if valid Chip ID is found. Usualy 0x03 or 0x14. if not -> abort
if(version == 0x00 || version == 0xFF)
NRF_LOG_INFO("no CC11xx found!");
return FALSE;
NRF_LOG_INFO("Partnumber:%x", partnum);
NRF_LOG_INFO("Version:%x", version);
//default settings
//*My_addr = 0x00;
CC1101_freq_select = 0x02; //433.92MHz
CC1101_mode_select = 0x07; //gfsk 9.6kbps
CC1101_channel_select = 0x00;
//set modulation mode
cc1101_set_mode(CC1101_mode_select);
//set ISM band
cc1101_set_ISM(CC1101_freq_select);
//set channel
cc1101_set_channel(CC1101_channel_select);
//set my receiver address
cc1101_set_myaddr(*My_addr); //set addr
NRF_LOG_INFO("...done");
cc1101_receive(); //set CC1101 in cc1101_receive mode
return TRUE;
