Differences between N52832QFAAE0 and N52832QFAAE1
we have a problem  with modules from raytec MDBT42Q.
We have modules which work with our software as expected, and other ( newer ) that will stuck in Software.
The difference between Modules is the Revison of the silicon.
We use the nus service and SDK 17.1.
Any idea what difference between this to revision can cause the problem?
Andreas
  • Hi Ruetten,
    The only difference between N52832QFAAE0 and N52832QFAAE1 is the production code. So the revision of the silicone is the same but only production configuration different. So they, in theory, should behave exactly the same with same code.
    How many module with N52832QFAAE1 do you observe the issue ?
    Have you got any debug information from the module ? Any log showing where the software crashed ? Have you tried to test with one of our example in the SDK ?
