Add CDC class to the USB Device Example
I am developing a USB keyboard + mouse using a NRF52833. I have use the USB Device Example from nRF5 SDK v17.1.0. I chose this example because my project is in C++ and had problems compiling the USB HID Composite Example regarding to "designator order for field 'app_usbd_hid_inst_t::p_hid_methods' does not match declaration order in 'app_usbd_hid_inst_t'".
I have implemented the keyboard + mouse HID to my project since the original example only works as a mouse. Now I need to add the CDC class to have a serial com port, any suggestions or examples on how to do it?
    Don't log directly in your event handlers.
    You can push log messages, but only if deferred logging is enabled. This means that if sdk_config.h::NRF_LOG_DEFERRED = 1, you can log in the event handler, but you cannot call NRF_LOG_FLUSH then.
    This will cause issues.
    In your sdk_config.h, can you try to set "#define APP_USBD_CDC_ACM_ZLP_ON_EPSIZE_WRITE 1" and see if this helps as well?
    Håkon
  • That flag is already enabled:
    Also I have deleted all the logs inside the event handler and print the Rx buffer in the main but it still does not work:
    void usb_cdc_ev_handler(app_usbd_class_inst_t const *p_inst, app_usbd_cdc_acm_user_event_t event)
        app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
        switch (event)
            case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
                    Setup first transfer.
                    If it does not do this, no Bytes can be received later.
                app_usbd_cdc_acm_read(&serial_cdc_class, serial_rx_buffer, 1);
            case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
                    ret_code_t ret;
                    num_bytes = 0;
                    do
                        ret = app_usbd_cdc_acm_read(&serial_cdc_class, &serial_rx_buffer[num_bytes++], 1);
                    } while (ret == NRF_SUCCESS);  // Fetch data until internal buffer is empty.
                    serial_rx_buffer[num_bytes] = '\0';
                    flag_rx_done = true;
    This is the log:
    <info> app: Rx 3 Bytes = 23
    <info> app: Rx 3 Bytes = 231
    The same result, the first Byte is missing and the third character of the first transmission is the null character '\0'.
    If I enable the log for the USBD_CDC_ACM module I get these messages:
    <debug> cdc_acm: Received 3 bytes. Stored in internal buffer.
    <info> cdc_acm: EPOUT_DATA: 04 done
    <info> app: -> Rx 3 Bytes = 23
    <info> app: -> Rx 3 Bytes = 231
    Update:
    I have added this log in the cdc_acm_consumer() function from the app_usbd_cdc_acm.c file to print the rx buffer:
            char *cstr = (char *)p_next->p_data.rx;
            NRF_LOG_DEBUG("Rx: %s", cstr);
     * @brief CDC ACM consumer.
     * @note See @ref nrf_drv_usbd_consumer_t
    static bool cdc_acm_consumer(nrf_drv_usbd_ep_transfer_t * p_next,
                                 void *                       p_context,
                                 size_t                       ep_size,
                                 size_t                       data_size)
        app_usbd_cdc_acm_ctx_t * p_cdc_acm_ctx = (app_usbd_cdc_acm_ctx_t *) p_context;
        p_next->size = data_size;
        if (data_size <= p_cdc_acm_ctx->rx_transfer[0].read_left)
            p_next->p_data.rx = p_cdc_acm_ctx->rx_transfer[0].p_buf;
            p_cdc_acm_ctx->rx_transfer[0].p_buf     += data_size;
            p_cdc_acm_ctx->bytes_read               += data_size;
            p_cdc_acm_ctx->rx_transfer[0].read_left -= data_size;
            NRF_LOG_DEBUG("Received %d bytes. Space left in user buffer: %d bytes.",
                          data_size,
                          p_cdc_acm_ctx->rx_transfer[0].read_left);
            return (p_cdc_acm_ctx->rx_transfer[0].read_left) != 0;
            p_next->p_data.rx = p_cdc_acm_ctx->internal_rx_buf;
            p_cdc_acm_ctx->cur_read = data_size;
            NRF_LOG_DEBUG("Received %d bytes. Stored in internal buffer.", data_size);
            return false;
    And up to this point the Bytes are really being received well. This is the log:
    <debug> cdc_acm: Rx: 123
    Have you tried just reading the whole buffer instead of byte-by-byte?
    There seems to be something that goes wrong in the main.c logic, as seen by your results by looking at the internal buffers as well, so it might be beneficial to declare your variables used in different scopes as volatile (ie. flag_rx_done and num_bytes)
    Håkon
  • Those variables are already static volatile and yes I have tried reading all the buffer at once with the same results and then switch to reading Byte by Byte as this es the most common way seen in the forum examples.
    Is it still printing like this?
    Are you sure it is not the logger itself that is blocked or otherwise showing the incorrect data? Since the amount of bytes is correct, it might be that the logger is having buffering issues when printing, while the actual data is present in a normalized format.
    Try catching the scenario by parsing the data (ie. check for content "231") instead of plain printing it.
    Håkon
