I am using NCS v2 with VSCode on Windows 11.
I am using the jlink programmer inside a nRF52840-DK to program a custom board. Actually, two different custom boards.
My question is about a seeming change in behavior of jlink between the two custom boards with no difference in code or jlink commands.
The jlink is hooked up via SWD.
Boards
| Board 1 | Board 2 | |
| What | an nRF52840-based module (a BT840) | an nRF52840 directly (replacing the BT840 module) |
| Chip label | N52840 QIAAD0 2202ZR |
N52840 QIAAD0 2122DX |
| nrfjprog --deviceversion | NRF52840_xxAA_REV2 | NRF52840_xxAA_REV2 |
Programming
From VSCode, I can use the flash action in nRFConnect extension to flash an example program (eg mass) to Board 1 over and over again with no problems.
* Executing task: nRF Connect: Flash: mass/build (active) Flashing build to undefined west flash -d /home/doug/git/mass/build --skip-rebuild -r jlink --dev-id 683684592 -- west flash: using runner jlink -- runners.jlink: JLink version: 7.66b -- runners.jlink: Flashing file: /home/doug/git/mass/build/zephyr/zephyr.hex * Terminal will be reused by tasks, press any key to close it.
If I do this same action with Board 2, the first works, but then I get an error.
I am able to program it again if I disconnect/re-connect power to the board.
* Executing task: nRF Connect: Flash: mass/build (active) Flashing build to undefined west flash -d /home/doug/git/mass/build --skip-rebuild -r jlink --dev-id 683684592 -- west flash: using runner jlink -- runners.jlink: JLink version: 7.66b -- runners.jlink: Flashing file: /home/doug/git/mass/build/zephyr/zephyr.hex FATAL ERROR: command exited with status 1: /opt/SEGGER/JLink_V766b/JLinkExe -USB 683684592 -nogui 1 -if swd -speed 4000 -device nRF52840_xxAA -CommanderScript /tmp/tmp3yijixf5jlink/runner.jlink -nogui 1 * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Notably, I tweaked the nRFConnect extension to use the jlink runner because it is WAY faster (you guys should update this to be a configurable option).
Can you help me figure out what is going on?
Thanks.
