Using SDK17.1.0, I need to manually force an event handler to run. But the event handler is part of the SDK and is declared static. Key constraint is that i cannot modify the SDK.
I'm using the app_button library. But the handler i registered for the button doesn't run when the chip is wakes up from shutdown mode (following button press). I am aware this is because the debounce timer doesn't start (started in the gpiote event handler).
I tried manually running my local app_button handler, but of course this skips many steps within the app_button library and causes all sorts of problems. So, essentially i need to call a function from further back in the call stack/ chain of events.
But every function that potentially provides a route to triggering the app_button event handler is declared static or is out of scope of my code.
The event handler i'd like to trigger is below: (line 245 app_button.c)
static void gpiote_event_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
app_button_cfg_t const * p_btn = button_get(pin);
bool is_set = nrf_drv_gpiote_in_is_set(p_btn->pin_no);
bool is_active = !((p_btn->active_state == APP_BUTTON_ACTIVE_HIGH) ^ is_set);
/* If event indicates that pin is active and no other pin is active start the timer. All
* action happens in timeout event.
if (is_active && (m_pin_active == 0))
NRF_LOG_DEBUG("First active button, starting periodic timer");
timer_start();
Ideally i could do to find the memory location in which the pointer to the above handler is stored (when it is initialised). i could, for example, do this using the following code:
nrfx_gpiote_evt_handler_t handler = channel_handler_get((uint32_t)channel_port_get(BTN_PIN));
handler(BTN_PIN, GPIOTE_CONFIG_POLARITY_HiToLo);
But again, both of these functions are static.
Ideally, i'm looking for suggestions of global functions that can be used to retrieve a pointer to the gpiote event handler (the one in the first extract of code above). Or some other way of manually forcing a button action. Even if i could perhaps manually force the pin's IRQ at register level?
Sean
