Log to nrf52 thingy internal flash
I am working on a prototype using the nRF Connect SDK v2.1.0 on the nRF52 Thingy platform.
For my prototype, I need to store normal log output on the internal flash of the nRF52 Thingy in FAT format. The reason behind this is: I will put my Thingys in a testing environment to collect data. After some days, I want to collect the Thingys and read the log data via USB.
What is the best way to implement that?
I have been trying the https://docs.zephyrproject.org/latest/samples/subsys/usb/mass/README.html#fat-fs-example, but the FLASH configuration does not work (not on the Thingy and not on the nRF52840DK platform).
Michael
  • When running the USB Mass sample in FLASH configuration on the nRF52840DK, I get the following RTT logs:
    [00:00:00.254,333] <err> usb_msc: Storage init ERROR !!!! - Aborting USB init
    [00:00:00.258,514] <err> fs: fs mount error (-5)
    [00:00:00.258,544] <err> main: Failed to mount filesystem
    [00:00:00.258,728] <inf> main: The device is put in USB mass storage mode.
  • Hello Michael
    I tried running buildining the sample \zephyr\samples\subsys\usb\mass in NCS v2.1.0 and flashing it to the nRF52840DK v3.0.0 but did not encounter the issue you did.
    I got the following RTT output:
    [00:00:00.255,645] <inf> main: No file system selected
    [00:00:00.255,737] <inf> main: The device is put in USB mass storage mode.
    and the following serial output:
    *** Booting Zephyr OS build v3.1.99-ncs1  ***
    Try running nrfjprog --qspieraseall first, and program the USB Mass sample again.
    Simon
  • Hi Simon,
    Thank you for your fast reply. As far as I can tell, you run the sample without specifying a file system. ("No file system selected" in the RTT output.
    Here is my full prj.conf content:
    CONFIG_STDOUT_CONSOLE=y
    #USB related configs
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PRODUCT="Zephyr MSC sample"
    CONFIG_LOG=y
    CONFIG_USB_DRIVER_LOG_LEVEL_ERR=y
    CONFIG_USB_MASS_STORAGE=y
    CONFIG_USB_DEVICE_LOG_LEVEL_ERR=y
    CONFIG_USB_MASS_STORAGE_LOG_LEVEL_ERR=y
    CONFIG_MAIN_STACK_SIZE=1536
    CONFIG_APP_MSC_STORAGE_FLASH_FATFS=y
    I have executed nrfjprog --qspieraseall, but it did not solve the problem.
    Michael
  • Can you try to apply the following patch to Zephyr?
    diff --git a/drivers/disk/flashdisk.c b/drivers/disk/flashdisk.c
    index 62ad2babeb..3917900779 100644
    --- a/drivers/disk/flashdisk.c
    +++ b/drivers/disk/flashdisk.c
    @@ -56,8 +56,11 @@ static int disk_flash_access_init(struct disk_info *disk)
     		return 0;
    -	flash_dev = device_get_binding(CONFIG_DISK_FLASH_DEV_NAME);
    -	if (!flash_dev) {
    +	//flash_dev = device_get_binding(CONFIG_DISK_FLASH_DEV_NAME);
    +	//if (!flash_dev) {
    +	flash_dev = DEVICE_DT_GET(DT_NODELABEL(mx25r64));
    +    if (!device_is_ready(flash_dev)) {
     		return -ENODEV;
    After I did that, I got the following output using the USB mass sample with your prj.conf.
    Area 4 at 0x0 on mx25r6435f@0 for 131072 bytes
    Mount /NAND:: 0
    /NAND:: bsize = 512 ; frsize = 512 ; blocks = 216 ; bfree = 216
    /NAND: opendir: 0
    End of files
    [00:00:05.844,879] <inf> main: The device is put in USB mass storage mode.
    Use of the devicetree label property has been deprecated per release notes of Zephyr v.3.2, and the flashdisk driver has not taken this into account.
    Would you be able to create a Zephyr GitHub issue about this?
  • Thanks that fixed the problem.
    I have created a Zephyr issue so that this will get fixed in the future (https://github.com/zephyrproject-rtos/zephyr/issues/51720). Thanks.
