libuarte Unexpected RX free input parameter
Hi there,
several months ago I developed a usb to uart bridge based on the nRF52820. We've produced a hand full of those bridges for internal tests and the feedback showed some problems.
Right now the biggest problem is that sometimes the bridge stops responding when hitting it with a load from both sides. Right now DEBUG is set so an error results in an endless loop instead of a reset
So far I figured out that the problem lies within the nrf_libuarte_async_rx_free function. Here I run into the "Unexpected RX free input parameter" case. Debugging it shows that rx_free_cnt is 499968 and rx_buf_size is 0 ...
Here is my init function:
#define UART_RX_BUF_SIZE   256
#define UART_RX_BUF_NUM    8
#define UART_RX_PIN_NUMBER 30
#define UART_TX_PIN_NUMBER 29
#define UART_RX_TIMEOUT_US 100
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, 3, UART_RX_BUF_SIZE, UART_RX_BUF_NUM);
void uart_init(UART_init_struct_t* psInit)
  ret_code_t                  err_code;
  nrf_libuarte_async_config_t nrf_libuarte_async_config;
  nrf_libuarte_async_config.tx_pin     = UART_TX_PIN_NUMBER;
  nrf_libuarte_async_config.rx_pin     = UART_RX_PIN_NUMBER;
  nrf_libuarte_async_config.baudrate   = NRF_UARTE_BAUDRATE_1000000;
  nrf_libuarte_async_config.parity     = NRF_UARTE_PARITY_EXCLUDED;
  nrf_libuarte_async_config.timeout_us = UART_RX_TIMEOUT_US;
  nrf_libuarte_async_config.int_prio   = APP_IRQ_PRIORITY_HIGH;
  nrf_libuarte_async_config.pullup_rx  = true;
  nrf_libuarte_async_config.rts_pin    = UART_PIN_DISCONNECTED;
  nrf_libuarte_async_config.cts_pin    = UART_PIN_DISCONNECTED;
  nrf_libuarte_async_config.hwfc       = NRF_UARTE_HWFC_DISABLED;
  nrf_libuarte_async_uninit(&libuarte);
  err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void*)&libuarte);
  if(err_code != NRF_SUCCESS)
    NRF_LOG_ERROR("libuarte async init = %d", err_code);
  nrf_libuarte_async_enable(&libuarte);
The uart events get handled via the scheduler:
static void uart_event_sched_handler(void* p_event_data, uint16_t event_size)
  nrf_libuarte_async_evt_t* p_evt = (nrf_libuarte_async_evt_t*) p_event_data;
  switch(p_evt->type)
    case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
      u8* pu8Data;
      u32 i;
      for(i = 0, pu8Data = p_evt->data.rxtx.p_data; i < p_evt->data.rxtx.length; i++, pu8Data++)
        UART_RxProcess(*pu8Data);
      nrf_libuarte_async_rx_free(&libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
    case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
      UART_Tx(NULL, 0);
    case NRF_LIBUARTE_ASYNC_EVT_ERROR:
      NRF_LOG_INFO("UART Error: %d", p_evt->data.errorsrc);
      NRF_LOG_INFO(" unexpected libuarte event: %d", p_evt->type);
void uart_event_handler(void* context, nrf_libuarte_async_evt_t* p_evt)
  app_sched_event_put(p_evt, sizeof(nrf_libuarte_async_evt_t), uart_event_sched_handler);
I'm using the nRF5 SDK version 17.1.0 without softdevice.
Any idea what the problem could be?
Johannes
  • Ok somehow Ozone showed me complete nonsense.
    Sometimes I reach the point where rx_free_cnt is 250 and nrf_libuarte_async_rx_free is called with a length greater than 6 (e.g. 20) which results in rx_free_cnt exceeding the buffer size 256.
    Q1: Does the event "NRF_LIBUARTE_ASYNC_EVT_ERROR" occur at some point?
    Q2: You seem to configure NRF_LIBUARTE_ASYNC_DEFINE(..) to use both RTC and high speed TIMER for timeout generation, is this intended?
    Q3: The timeout is set to 100 us. This sounds a bit low for receiving up to 256 bytes payload. Have you tried adjusting this a bit higher?
    Håkon
  • Hi Håkon,
    A1: Only if I unplug or plug in the uart connector when the bridge is already running, which normally isn't the case.
    A2: I've found an example that configured the libuarte like this and haven't thought much about it. Sweat smile
    A3: Well I used the same timeout that is used in the libuarte example in the SDK. Is there a rule of thumb how to choose the right timeout?
    Johannes
  • Hi Johannes,
    Ok, that is to be expected. You can add a re-init routine to recover from that scenario, if wanted.
    You should select either RTC based timing, or high speed TIMER.
    Sorry, the logic was misread from my side. This is on a byte-for-byte basis, so 100 us is fine here.
    The usual scenario when receiving "Unexpected RX free input parameter" is that there is a timing issue in the firmware, wrong input parameter, etc.
    Looking at your code here:
      switch(p_evt->type)
          u8* pu8Data;
          u32 i;
    What is the "libuarte" variable here? normally, you want to pass both the void pointer and the p_evt coming from the libuarte evt handler:
    void my_libuarte_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
        nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
        switch (p_evt->type)
            nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
    It looks like context is going out of scope at your end. Could you try storing uart_event_handler::context and using that instead of "&libuarte"?
    Håkon
  • Hi Håkon,
    libuarte is the variable I got from NRF_LIBUARTE_ASYNC_DEFINE.
    I've tried that before when implementing libuarte but back then I couldn't get it to run. According to my logs from back then I only got unexpected libuarte events
    I've changed the timeout to 1ms and so far I haven't seen the error again. But instead on the usb side something behaves strangely now.
    Johannes
