Advice on how to proceed with my nRF9160 project
I am just getting started with the nRF9160 DK. I have a few questions, and I have searched the DevZone for answers, but I am still a bit confused and unsure how to go on with my project.
I have not worked much with wireless technologies before, especially not LTE-M or other mobile data technologies. First of all, I would like to program a simple application that would send small amounts of data to a HTTP server. I also need to access the GNSS module.
So far, I have two ideas on how to achieve this (all using the proprietary LTE-M modem firmware):
1) Flash the Serial LTE Modem sample as the application firmware and use another microcontroller to communicate with the nRF9160 through just an UART connection. My own application firmware would then be on the external microcontroller.
2) Write a custom application firmware for the nRF9160 DK using Zephyr and connect to the modem firmware using nrfxlib.
But, what I think I really would like to do is this:
3) Write a custom application firmware in a bare metal fashion, that can control the proprietary LTE-M modem firmware using, for example, an internal UART connection or similar.
I understand that 1) might be the easiest way for me to go, but it requires an external microcontroller.
I am a low level kind of guy, and I usually do bare metal programming with little or no use of third-party libraries. I really do not want to learn Zephyr and fiddle with west and other build tools. So I think 2) is basically ruled out.
Option 3) sounds interesting to me, since I would learn a lot about socket programming, TCP/IP etc. - but, I fear that I might chicken out and go with 1) and just add an external microcontroller :-)
However, before I rule out 3) completely, I would like to know how the application part of the nRF9160 can communicate with the modem firmware on the lowest level. For example, is it possible to send AT commands, internally, using one of the UART peripherals? And what about data packets? Can they be transferred through the AT interface as well?
I have looked at the nrf_modem headers and source files included with the nrfxlib, but those files did not answer my questions - only made me more confused.
But, at least I recently found out how to do bare metal programming on the nRF9160:
devzone.nordicsemi.com/.../bare-metal-programming-on-the-nrf9160
Any help or advice is much appreciated. Thanks a lot in advance :-)
