How to remove the nRF9160's erase protection.
Hello everyone,
I'm working on a project with nRF9160 and I used to this code to test the erase protection. But I found that the value of the "ERASEPROTECT->DISABLE" register does not match.
#include <zephyr.h>
void main(void)
    NRF_NVMC->CONFIG = ( (NVMC_CONFIG_WEN_Wen | NVMC_CONFIG_WEN_Een) << NVMC_CONFIG_WEN_Pos);
    while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
    NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK = 0x00000000;
    NRF_UICR->APPROTECT = 0x00000000;
    NRF_UICR->ERASEPROTECT = 0x00000000;
    NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE = 0xDEADBEEF;
    printk("Before Write Key.\n");
    printk("ERASEPROTECT     Addr	 0x%X\n", &NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK);
    printk("ERASEPROTECT          0x%X\n",  NRF_UICR->ERASEPROTECT);
    printk("ERASEPROTECT.LOCK    0x%X\n",   NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK);
    printk("ERASEPROTECT.DISABLE 0x%X\n",   NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE);
    uint32_t count = 0;
    while (1)
        k_msleep(1000);
        printk("Count:: %u\r\n", count++);
} /* main */
Command to build this code:
$ west build -b nrf9160dk_nrf9160 .
My result on UART terminal.
*** Booting Zephyr OS build v3.0.99-ncs1 ***
Begin Unlock.
Before Write Key.
ERASEPROTECT Addr 0x50006500
ERASEPROTECT 0x0
ERASEPROTECT.LOCK 0x0
ERASEPROTECT.DISABLE 0x0
And then I try to write the value to "ERASEPROTECT->DISABLE" as the same c-code using this script.
setPassword.txt
SWDSelect
SWDWriteDP 1 0x50000000
SWDWriteDP 2 0x04000010
SWDWriteAP 3 0xDEADBEEF
sleep 10000
SWDWriteDP 2 0x04000000
SWDWriteAP 0 0x00000001
SWDReadAP 0
SWDReadAP 0
sleep 5000
SWDWriteAP 0 0x00000000
SWDReadAP 0
SWDReadAP 0
sleep 1000
exit
Command to run script
$ JLinkExe -Commandfile setPassword.jlink
The result:
SEGGER J-Link Commander V7.80c (Compiled Sep 27 2022 16:06:19)
DLL version V7.80c, compiled Sep 27 2022 16:05:56
J-Link Command File read successfully.
Processing script file...
J-Link>SWDSelect
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...O.K.
Firmware: J-Link Ultra V5-1 compiled Sep 22 2022 14:54:27
Hardware version: V5.10
J-Link uptime (since boot): 0d 00h 13m 13s
S/N: 505101964
License(s): RDI, FlashBP, FlashDL, JFlash, GDB
USB speed mode: High speed (480 MBit/s)
VTref=3.270V
Select SWD by sending SWD switching sequence.
Found SWD-DP with ID 0x6BA02477
J-Link>SWDWriteDP 1 0x50000000
Write DP register 1 = 0x50000000
J-Link>SWDWriteDP 2 0x04000010
Write DP register 2 = 0x04000010
J-Link>SWDWriteAP 3 0xDEADBEEF
Write AP register 3 = 0xDEADBEEF
J-Link>sleep 10000
Sleep(10000)
J-Link>SWDWriteDP 2 0x04000000
Write DP register 2 = 0x04000000
J-Link>SWDWriteAP 0 0x00000001
Write AP register 0 = 0x00000001
J-Link>SWDReadAP 0
Read AP register 0 = 0x00000000
J-Link>SWDReadAP 0
Read AP register 0 = 0x00000001
J-Link>sleep 5000
Sleep(5000)
J-Link>SWDWriteAP 0 0x00000000
Write AP register 0 = 0x00000000
J-Link>SWDReadAP 0
J-Link>SWDReadAP 0
J-Link>sleep 1000
Sleep(1000)
J-Link>exit
Script processing completed.
I found my board can't disable erase protection and I can't recover it.
Helpful hints Exactly what is happening?
Best regards
Wasan
  • Hi All,
    When I remove some line in my code as below. My device is working.
    Test base on:
    SDK 2.1.2
    MCU nRF9160
     * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    #include <drivers/gpio.h>
    #define GPIO_DEV     gpio0 /**< The gpio blank name. */
    #define BUTTON_A_PIN 12    /**< Pin number of factory button. */
    #define BUTTON_B_PIN 18    /**< Pin number of factory button. */
    static const struct device *gpio_dev;
    void main(void)
        const uint32_t key = 0xDEADBEEF;
        gpio_dev = DEVICE_DT_GET(DT_NODELABEL(GPIO_DEV));
        if (gpio_dev == NULL)
            LOG_ERR("Could not get GPIO Module.");
            return -EIO;
        gpio_pin_configure(gpio_dev, BUTTON_A_PIN, GPIO_INPUT);
        gpio_pin_configure(gpio_dev, BUTTON_B_PIN, GPIO_INPUT);
        NRF_NVMC->CONFIG = ( (NVMC_CONFIG_WEN_Wen  ) << NVMC_CONFIG_WEN_Pos);
        NRF_UICR->SECUREAPPROTECT = 0x00000000;
        NRF_NVMC->CONFIG = ( (NVMC_CONFIG_WEN_Ren  ) << NVMC_CONFIG_WEN_Pos);
         * @brief When unuse unlock feature in this boot.
        // NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK = 0x00000001;
        // while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
        uint32_t count = 0;
        k_msleep(1000);
        while (1)
            if (0 == gpio_pin_get(gpio_dev, BUTTON_A_PIN))
                k_msleep(100);
                    printk("Unlock with Key A:0x%x\r\n", count++);
                    while (0 == gpio_pin_get(gpio_dev, BUTTON_A_PIN))
                        k_msleep(1);
            if (0 == gpio_pin_get(gpio_dev, BUTTON_B_PIN))
                k_msleep(100);
                    printk("Unlock with Key B:0x%x\r\n", count++);
                    NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE = 0x00000000;
                    while (0 == gpio_pin_get(gpio_dev, BUTTON_B_PIN))
                        k_msleep(1);
            k_msleep(1);
    } /* main */
    Scrip file > setPassword.jlink
    SWDSelect
    sleep 10000
    SWDReadAP 0
    SWDReadAP 0
    sleep 5000
    SWDReadAP 0
    SWDReadAP 0
    sleep 1000
    exit
    Noted:
    1. The device can't  disable erase protection when set the register NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE = 0x00000000;
    2. Please use the "nrfjprog --recover" command to test the nRF91's erase protection that has been disabled.
    Best regards
    Wasan
  • Hi  ,
    I read through the Q&A as I wanted to test the working of ERASEPROTECT and disable it using the Jlink script you have provided, I think I am also not able to disable erase protection. nrfjprog --recover is also not helping.
    #include <zephyr.h>
    void main(void)
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
            while (NRF_NVMC->READY == NVMC_READY_READY_Busy);
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
            if (NRF_UICR_S->ERASEPROTECT != UICR_ERASEPROTECT_PALL_Unprotected)
                    NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK = (uint32_t)0x00000001;
                NRF_CTRL_AP_PERI_S->ERASEPROTECT.DISABLE = key;
            printk("ERASEPROTECT     Addr    0x%p\n", &NRF_CTRL_AP_PERI_S->ERASEPROTECT.LOCK);
            uint32_t count = 0;
            k_msleep(1000);
            while (count < 10)
                    k_msleep(1000);
    output:
    *** Booting Zephyr OS build zephyr-v2.3.0-22164-gb121d671c44c  ***
    Before Write Key.
    ERASEPROTECT     Addr    0x0x50006500
    ERASEPROTECT          0x0
    ERASEPROTECT.LOCK    0x1
    Count:: 0
    Count:: 1
    Count:: 2
    Count:: 3
    Count:: 4
    Count:: 5
    Count:: 6
    Count:: 7
    Count:: 8
    Count:: 9
    jlink script:
    USB 960093400
    SWDSelect
    sleep 10000
    SWDReadAP 0
    SWDReadAP 0
    sleep 5000
    SWDReadAP 0
    SWDReadAP 0
    sleep 1000
    exit
    Help needed.
    Dinesh Kumar K
  • Could you provide output message when you run command scrip?
    Sorry for reply late.
  • Hi
    The issue was solved, I made a mistake by putting ERASEPROTECT.LOCK enable state and setting key to ERASEPROTECT.DISABLE.
    Doing this locked out the device before setting the erase protect key. which in turn makes the device unrecoverable. it was clearly discussed here https://devzone.nordicsemi.com/f/nordic-q-a/100614/request-for-guidance-and-documentation-on-eraseprotect-approtect-secureapprotect
