nRF5340 beacon example with RPC
Beacon example (zephyr/samples/bluetooth/beacon)
Issuing the following:
west build -b nrf5340dk_nrf5340_cpuapp
west flash
I get images running on APP and NET core, beacon can be catched by nrfconnect.
But if I want the whole BT stack run on NET core with RPC interface:
west build -b nrf5340dk_nrf5340_cpuapp -- -DCONFIG_BT_RPC_STACK=y
west flash
Compile succeeds, but the console shows a lot of errors:
*** Booting Zephyr OS build v3.1.99-ncs1  ***ng system
Starting Beacon Demo
[00:00:00.265,350] <err> BT_RPC: Missmatched CONFIG_BT_PERIPHERAL: net=1, app=0
[00:00:00.265,411] <err> BT_RPC: Missmatched CONFIG_BT_SMP: net=1, app=0
[00:00:00.265,441] <err> BT_RPC: Missmatched CONFIG_BT_CONN: net=1, app=0
[00:00:00.265,472] <err> BT_RPC: Missmatched CONFIG_BT_ECC: net=1, app=0
[00:00:00.265,502] <err> BT_RPC: Missmatched CONFIG_BT_MAX_PAIRED: net=1, app=0
[00:00:00.265,502] <err> BT_RPC: Missmatched CONFIG_BT_SETTINGS_CCC_LAZY_LOADING: net=1, app=0
[00:00:00.265,533] <err> BT_RPC: Missmatched CONFIG_BT_SETTINGS: net=1, app=0
[00:00:00.265,563] <err> BT_RPC: Missmatched CONFIG_BT_MAX_CONN: net=1, app=255
[00:00:00.265,594] <err> BT_RPC: Missmatched CONFIG_BT_DEVICE_APPEARANCE: net=833, app=0
[00:00:00.265,594] <err> BT_RPC: Missmatched CONFIG_BT_DEVICE_NAME: net="Nordic_UART_S, app="Test beacon"
[00:00:00.265,625] <err> BT_RPC: Missmatched BT RPC config.
[00:00:00.265,655] <err> NRF_RPC: Error on receive reported -22, group bt_rpc, id 0x01, type 0x80
[00:00:00.265,716] <err> BT_RPC: nRF RPC error -22 ocurred. See nRF RPC logs for more details.
[00:00:00.265,716] <err> os: r0/a1:  0x00000003  r1/a2:  0x0000000d  r2/a3:  0x0000000c
[00:00:00.265,747] <err> os: r3/a4:  0x200006e8 r12/ip:  0x0000869c r14/lr:  0x00009187
[00:00:00.265,747] <err> os:  xpsr:  0x69000000
[00:00:00.265,747] <err> os: Faulting instruction address (r15/pc): 0x000048aa
[00:00:00.265,777] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:00:00.265,808] <err> os: Current thread: 0x20000d50 (unknown)
And not all of the above errors can be fixed by adding the appropriate config options to prj.conf.
What is the solution?
    Can you try to follow the description for peripheral UART first to check that it works as expected, then next is the HIDS mouse, ref example build description:
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/samples/bluetooth/rpc_host/README.html#example-build
    Which ones are left? To get more information about the assert I suggest to add the following:
    # Debugging configuration
    CONFIG_THREAD_NAME=y
    CONFIG_THREAD_ANALYZER=y
    CONFIG_THREAD_ANALYZER_AUTO=y
    CONFIG_THREAD_ANALYZER_RUN_UNLOCKED=y
    CONFIG_THREAD_ANALYZER_USE_PRINTK=y
    # Add asserts
    CONFIG_ASSERT=y
    CONFIG_ASSERT_VERBOSE=y
    CONFIG_ASSERT_NO_COND_INFO=n
    CONFIG_ASSERT_NO_MSG_INFO=n
    CONFIG_RESET_ON_FATAL_ERROR=n
    You can also try to run something like this in your build folder (open command line from toolchain manager):
    C:\ncs\toolchains\v2.1.0\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-addr2line.exe -e .\zephyr\zephyr.elf 0x000048aa (provided the fault is still at the same address as your original dump)
    Kenneth
  • Which ones are left?
    [00:00:00.427,947] <err> BT_RPC: Missmatched CONFIG_BT_SETTINGS_CCC_LAZY_LOADING: net=1, app=0
    [00:00:00.427,978] <err> BT_RPC: Missmatched CONFIG_BT_SETTINGS: net=1, app=0
    My edited prj.conf looks like this (other dependencies could be resolved with it):
    CONFIG_BT=y
    CONFIG_BT_DEBUG_LOG=y
    CONFIG_BT_DEVICE_NAME="Test beacon"
    CONFIG_BT_RPC=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_SMP=y
    CONFIG_BT_ECC=y
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_SETTINGS=y
    CONFIG_BT_SETTINGS_CCC_LAZY_LOADING=y
    CONFIG_BT_DEVICE_APPEARANCE=833
    CONFIG_BT_DEVICE_NAME="Nordic_UART_Service"
    Tracing back the point of failure with addr2line: it points to bt_rpc_common.c::err_handler(...) function, which is used in nrf_rpc_init(err_handler).
  • <err> BT_RPC: Missmatched CONFIG_BT_SETTINGS_CCC_LAZY_LOADING: net=1, app=0
    The error indicate a mismatch between appcore and netcore, have you tried to setting them to the same value between the two cores? E.g. =y in both cores.
    Kenneth
  • I don't know how to set the APP and NET configuration separately. A few posts above I've shown my prj.conf. Please tell me how to edit APP and NET configs separately in case of a multi image build, like this!
