Hi, I am looking to use mcuboot to manage 2 separate images. The idea is that under certain conditions, image 1 would jump to image 2.
To test the idea, I am using the zephyr hello_world sample with minimal modifications:
prj.conf:
CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_FLASH=y CONFIG_IMG_MANAGER=y CONFIG_UPDATEABLE_IMAGE_NUMBER=2 CONFIG_NRF53_UPGRADE_NETWORK_CORE=n
child_image/mcuboot.conf:
pm_static.yml:
app: address: 0x10200 region: flash_primary size: 0x1fe00 mcuboot: address: 0x0 region: flash_primary size: 0x10000 mcuboot_pad: address: 0x10000 region: flash_primary size: 0x200 mcuboot_primary: address: 0x10000 orig_span: &id001 - mcuboot_pad - app region: flash_primary size: 0x20000 span: *id001 mcuboot_primary_app: address: 0x10200 orig_span: &id002 - app region: flash_primary size: 0x1fe00 span: *id002 mcuboot_primary_1: address: 0x30000 size: 0x20000 region: flash_primary mcuboot_secondary: address: 0x50000 size: 0x20000 region: flash_primary mcuboot_secondary_1: address: 0x70000 size: 0x20000 region: flash_primary EMPTY_0: address: 0x90000 size: 0x70000 region: flash_primary
On boot, I get the following logs from mcuboot:
*** Booting Zephyr OS build v3.1.99-ncs1 *** I: Starting bootloader I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Boot source: none W: Failed reading image headers; Image=0 I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 I: Boot source: none W: Failed reading image headers; Image=1 E: Image in the primary slot is not valid! E: Unable to find bootable image
And my application does not boot.
I am using NCS v2.1.0 and nRF5340 DK, along with the nRF Connect VSCode extension for building and flashing.
