USBD_STATUS_CANCELED
Hi there,
as already mentioned in other tickets I'm developing a usb to uart bridge based on the nrf52820. The nRF5 SDK version I'm using is 17.1.0.
Right now I'm facing an error on the usb side.
A bit of a context:
When connected, one of our test tools retrieves information (e.g. device state, device id, ...) from a device. This is done every second by sending 4 messages to it.
If it takes one answer more than 10 seconds to return, the connection to the device is closed.
Right now I'm facing the problem that after some time (20 seconds up to 10 minutes) one answer isn't completely received.
Most of the time the answer get's split into 2 parts (according to wireshark). The first part is always received. When the error happens the second part only gets transmitted when the connection get's closed. When this happens the IRP USB_STATE is USBD_STATUS_CANCELED (0xc0010000).
In the image you can see that packet number 13124 is the request and packets number 13127 and 13150 are the answer.
Any idea what could be causing this?
Johannes
    Q1: Could you share the .pcapng?
    Q2: any logs from the nRF side that could hint at what is happening?
    Q3: How does your schematic look wrt. D+/D- routing? There should not be any series-resistors on these lines (as a side-note: but we do recommend to use ESD protection diodes).
    Håkon
  • Hi Håkon,
    A1: Yeah sure. The interface in question is interface number 1.failed_communication_-_USBD_STATUS_CANCELED.pcapng
    A2: Sadly no. I've tried activating the logs in all USB modules but nothing happened.
    A3: The only thing between the usb port and the nRF D+/D- pins is a USBLC6-2SC6 diode.
    Johannes
  • Hi Johannes,
    Schematic looks good.
    The sniffer trace unfortunately is on a OS level, and does not show much other than the communication stops on EP1 (ie. your data EP)
    Did you set sdk_config.h:NRFX_USBD_CONFIG_LOG_ENABLED in addition to sdk_config.h:NRF_LOG_ENABLED?
    Håkon
  • Hi Håkon,
    sorry for the late reply I've been on vacation the last few days.
    Yes I did.
    I'm wondering why the missing data get's "received" when the program closes the connection to the device. Is there some sort of flush being performed?
    What happens if I try to send more than 64 byte at once and when will I receive TX finished in this case?
    Johannes
    USB is, like most other transports, driven by a host. If the host stops polling the device, incoming data stream also stops.
    Not saying that this happens here, but it might be a possibility.
    On the bus itself, it will be split up into 64 byte chunks.
    If you continuously send a size that is equal to the EP side, it might be beneficial to look at sdk_config.h::USBD_CONFIG_ISO_IN_ZLP.
    Also, what terminal are you using when you're seeing this issue? Is it present on all computers, with different terminal programs?
    Håkon
