Good day
I noticed that the NFC tag reader sample is not compatible with the nrf9160K. Is there a reason for this ? will development be possible?
Thank you!
Good day
Thank you!
"Compatible" just means that the listed DK have been tested with it, but typically it should run just as well on any other nRF DK.
Kenneth
Hello, I'm struggling to create a start condition to switch the device on. Do you maybe have an idea which function I need to use to do this. When using a i2c_write function, on the correct address, it doesn't seem to register. I can't seem to see how it was done in the tag_reader sample.
Hassan
When you have problems with an I2C device, I highly recommend connect a logic analyzer, then you will immediately find the problem; e.g. wrong pins, missing pull up, wrong address, error in data, nack or ack etc.
Kenneth
