Disabling mesh to get low power consumption
Iam using sensor_client example from nrf 5 mesh sdk and trying to reduce its power consumption by turning off mesh totally when it sleeps
I have also referred to this previous cases: nrf_mesh_disable() function changed since SDK for Mesh V3.1.0? - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
Low power Mesh node based on Lightswitch example by using proxy_stop() and mesh_disable() - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
I have implemented the sam
    initialize();
    start();
          uint32_t retval = proxy_stop();
          if (retval == NRF_SUCCESS)
                  //scanner_disable(); // not needed
                  retval = nrf_mesh_disable();
          __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Disabling mesh: status: %d\n", retval);
    for (;;)
        (void)sd_app_evt_wait();
e
When i run this program after provisioning the device, it throws Mesh assert at 0x0002D9CC
Is there anything changed to disable mesh after that??
  • Hi Vignesh R,
    Just want to let you know that I have received your question. However, I am out of office today, so my follow-up will be delayed to latest next week Tuesday.
    Hieu
    update: I tried calling it in a handler and also switched to light_switch_client example, now it works both disabling and enabling mesh, but the current consumption is still avg.2.5mA when disabled.
    Do i need to disable anything further to reduce consumption??
    Thanks.
  • Hi Vignesh R,
    It's great to know you have found a solution to your problem.
    Regarding the 2.5mA current drawn, some quick things to check are:
    - Did the device enter sleep mode yet?
    - Is logging/debugging still enabled?
    - Is the setup measuring the current for the whole board, not just the nRF chip?
    Since that topic would be different from the original intent of this thread, I must ask that you open a new Q&A for any further follow-up/support request.
    As for this topic, it would also help the community if you could quickly write down what was wrong that made nrf_mesh_disable() not work.
    Hieu
