Hi!
I have a product based on nRF52832 with legacy code, that I would like to port to Zephyr.
It has 3 UART devices connected to the 3 pair of UART pins: GPS SOM on pins 6 and 7, LoRa SOM on pins 8 and 11, and an FTDI chip on pins 12 and 13.
The legacy firmware implements a "uart_select" function that re-configures UART on the fly.
My question is: what would be the proper way to implement this in Zephyr? Would it be possible to use pinmuxes? Or to write a UART mux driver?
Eve
void uart_select(uint8_t Uart_Select) { ret_code_t err_code; while(app_uart_send_in_progress()); if(fUartOpen) app_uart_close(); fUartOpen = 0; app_uart_comm_params_t comm_params = { .rx_pin_no = 0, .tx_pin_no = 0, .flow_control = APP_UART_FLOW_CONTROL_DISABLED, .use_parity = false, .baud_rate = UARTE_BAUDRATE_BAUDRATE_Baud9600 //UART_BAUDRATE_BAUDRATE_Baud115200 }; if(Uart_Select == UART_LORA){ nrf_gpio_cfg_default(RX_PIN_LORA); nrf_gpio_cfg_default(TX_PIN_LORA); comm_params.rx_pin_no = RX_PIN_LORA; comm_params.tx_pin_no = TX_PIN_LORA; comm_params.baud_rate = UART_LORA_BAUDRATE; } else if(Uart_Select == UART_GPS){ nrf_gpio_cfg_default(RX_PIN_GPS); nrf_gpio_cfg_default(TX_PIN_GPS); comm_params.rx_pin_no = RX_PIN_GPS; comm_params.tx_pin_no = TX_PIN_GPS; comm_params.baud_rate = UART_GPS_BAUDRATE; } else{ nrf_gpio_cfg_default(RX_PIN_FTDI); nrf_gpio_cfg_default(TX_PIN_FTDI); comm_params.rx_pin_no = RX_PIN_FTDI; comm_params.tx_pin_no = TX_PIN_FTDI; comm_params.baud_rate = UART_FTDI_BAUDRATE; } APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_event_handle, UART_PRIORITY, err_code); APP_ERROR_CHECK(err_code); fUartOpen = 1; }
