gcc can compile with object file compiled from keil-arm complier?
I'm converting my project to OSX GNU from windows keil because of license problem.
There is some .o files made by keil-arm complier in my previous project. and I don't have those c files.
and I tried compile projects and when it try to link those .o files, it exit by error like this.
gcc can't compile with object file compiled from keil-arm complier?
Thanks..
"/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc" -Xlinker -Map=_build/ble_app_allb_s110_xxaa.map -mcpu=cortex-m0 -mthumb -mabi=aapcs -L ..//Source//templates/gcc/ -Tgcc_nrf51_s110_xxaa.ld  _build/main.o _build/Sensor.o _build/Common.o _build/ble_nus.o _build/ble_srv_common.o _build/retarget.o _build/ble_advdata.o _build/app_timer.o _build/simple_uart.o _build/softdevice_handler.o _build/nrf_delay.o _build/pstorage.o _build/ble_conn_params.o _build/system_nrf51.o _build/gcc_startup_nrf51.o adc.o afe4403.o mpu6050.o spi_master2.o twi_hw_master_sd.o -o _build/ble_app_allb_s110_xxaa.out
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: error: adc.o: Conflicting CPU architectures 12/0
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file adc.o
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: error: afe4403.o: Conflicting CPU architectures 12/0
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file afe4403.o
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: error: mpu6050.o: Conflicting CPU architectures 12/0
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file mpu6050.o
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: error: spi_master2.o: Conflicting CPU architectures 12/0
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file spi_master2.o
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: error: twi_hw_master_sd.o: Conflicting CPU architectures 12/0
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: failed to merge target specific data of file twi_hw_master_sd.o
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: Dwarf Error: Could not find abbrev number 10.
afe4403.o: In function `afe_write_reg':
..\..\RedCarrot_ver2(c)\afe4403.c:(.text+0x0): undefined reference to `_printf_percent'
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: Dwarf Error: found dwarf version '0', this reader only handles version 2, 3 and 4 information.
..\..\RedCarrot_ver2(c)\afe4403.c:(.text+0x0): undefined reference to `_printf_d'
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: Dwarf Error: found dwarf version '11822', this reader only handles version 2, 3 and 4 information.
..\..\RedCarrot_ver2(c)\afe4403.c:(.text+0x0): undefined reference to `_printf_int_dec'
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: Dwarf Error: found dwarf version '23598', this reader only handles version 2, 3 and 4 information.
afe4403.o: In function `heartpulse':
..\..\RedCarrot_ver2(c)\afe4403.c:(.text+0x7a2): undefined reference to `__2sprintf'
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: _build/ble_app_allb_s110_xxaa.out: hidden symbol `__2sprintf' isn't defined
/usr/local/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
make: *** [_build/ble_app_allb_s110_xxaa.out] Error 1
