Found another bug with the peripheral_uart example
in main.c, you have this code
    if (IS_ENABLED(CONFIG_BT_NUS_SECURITY_ENABLED)) {
        err = bt_conn_auth_cb_register(&conn_auth_callbacks);
        if (err) {
            printk("Failed to register authorization callbacks.\n");
            return;
        err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
        if (err) {
            printk("Failed to register authorization info callbacks.\n");
            return;
but if you set CONFIG_BT_NUS_SECURITY_ENABLED=n in the prj.conf file, then there are #defines that will prevent the definition of the function conn_auth_info_callbacks().  This section of the code uses the runtime macro IS_ENABLED() which still compiles the code but just doesn't run it.  As conn_auth_info_callbacks() is no longer defined, this code can no longer be compiled and fails (if CONFIG_BT_NUS_SECURITY_ENABLED=n).
To fix, jus change them to #defines
#ifdef CONFIG_BT_NUS_SECURITY_ENABLED
        if (err) {
            return;
        if (err) {
            return;
