FOTA to external flash
Hi there
I'm using Asset tracker v2 as a base for my application with AWS, however I wanted the FOTA to download to external flash, as the Asset tracker application is large, and leaves little room for any other application code.
I'm able to FOTA, to external SPI flash using MCUBoot, however once the download is complete I get an error
<err> dfu_target_mcuboot: boot_request_upgrade for image-0 error -14
Any help appreciated.
Here is the debug
[00:07:17.860,687] <inf> download_client: Downloaded 323584/328496 bytes (98%)
[00:07:18.965,179] <inf> download_client: Downloaded 324608/328496 bytes (98%)
[00:07:20.061,065] <inf> download_client: Downloaded 325632/328496 bytes (99%)
[00:07:21.231,323] <inf> download_client: Downloaded 326656/328496 bytes (99%)
[00:07:22.301,300] <inf> download_client: Downloaded 327680/328496 bytes (99%)
[00:07:23.365,417] <inf> download_client: Downloaded 328496/328496 bytes (100%)
[00:07:23.365,509] <dbg> STREAM_FLASH: stream_flash_erase_page: Erasing page at offset 0x00050000
[00:07:23.494,506] <inf> download_client: Download complete
[00:07:23.497,711] <dbg> STREAM_FLASH: stream_flash_erase_page: Erasing page at offset 0x000e0000
[00:07:23.618,499] <err> dfu_target_mcuboot: boot_request_upgrade for image-0 error -14
[00:07:23.618,530] <err> fota_download: dfu_target_done error: -14
[00:07:23.618,530] <err> aws_fota: FOTA_DOWNLOAD_EVT_ERROR
[00:07:23.618,560] <dbg> aws_fota: update_job_execution: update_job_execution, status: 3, version_number: 1236
[00:07:23.620,544] <err> aws_iot: AWS_FOTA_EVT_ERROR
[00:07:23.620,544] <dbg> aws_iot_integration: aws_iot_event_handler: AWS_IOT_EVT_FOTA_ERROR
[00:07:23.620,574] <dbg> cloud_module: cloud_wrap_event_handler: CLOUD_WRAP_EVT_FOTA_ERROR
The only files I had to add to the asset_tracker application were.
\child_image\mcuboot\boards\thingy91_nrf9160.overlay
	chosen {
		nordic,pm-ext-flash = &is25lp032d;
&spi3 {
	status = "okay";
    pinctrl-0 = <&spi3_default>;
	pinctrl-1 = <&spi3_sleep>;
	cs-gpios = < &gpio0 7 GPIO_ACTIVE_LOW >,< &gpio0 7 GPIO_ACTIVE_LOW >;
	is25lp032d: is25lp032d@0 {
		compatible = "jedec,spi-nor";
		label = "IS25LP032D";
		reg = < 0 >;
		spi-max-frequency = < 40000000 >;
		wp-gpios = < &gpio0 8 GPIO_ACTIVE_LOW >;
		hold-gpios = < &gpio0 10 GPIO_ACTIVE_LOW >;
		size = < 0x2000000 >;
		has-dpd;
		t-enter-dpd = < 3000 >;
		t-exit-dpd = < 30000 >;
		jedec-id = [ 9d 60 16  ];
&uart0 {
	status = "okay";
	/delete-property/ cts-pull-up;
	//hw-flow-control;
    pinctrl-0 = <&uart0_default_alt>;
	pinctrl-1 = <&uart0_sleep_alt>;
&pinctrl {
	uart0_default_alt: uart_default_alt {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 6)>,
				<NRF_PSEL(UART_RX, 0, 5)>,
				<NRF_PSEL(UART_RTS, 0, 16)>,
				<NRF_PSEL(UART_CTS, 0, 15)>;
	uart0_sleep_alt: uart0_sleep_alt {
		group1 {
			low-power-enable;
    spi3_default: spi3_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 11)>,
                <NRF_PSEL(SPIM_MOSI, 0, 9)>,
                <NRF_PSEL(SPIM_MISO, 0, 28)>;
    spi3_sleep: spi3_sleep {
        group1 {
            low-power-enable;
\child_image\mcuboot.conf
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
CONFIG_MULTITHREADING=y
# MCUboot requires a large stack size, otherwise an MPU fault will occur
CONFIG_MAIN_STACK_SIZE=10240
# Enable flash operations
CONFIG_FLASH=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
#MKB Added
#https://devzone.nordicsemi.com/f/nordic-q-a/87502/mcubootloader-won-t-build-for-custom-board---zephyr-zephyr_pre0-elf-section-text-will-not-fit-in-region-flash
#CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
#compiled size is 49584bytes. = 0xC1B0 so C200 is enough.
CONFIG_PM_PARTITION_SIZE_MCUBOOT=0xc200
# Size of mcuboot partition
CONFIG_SIZE_OPTIMIZATIONS=y
###############  ALSO #######
#comment out or rename the file
#C:\ncs\v2.1.0\nrf\boards\arm\thingy91_nrf9160\thingy91_pm_static.yml
#commenting it out will allow the partition manager to use the CONFIG_PM_PARTION_SIZE_MCUBOOT
#above.
  • What is this in the asset_tracker_v2 application.
    \boards\thingy91_nrf9160_ns.conf
    # Disable MCUboot DFU -- incompatible with static partitions
    CONFIG_SECURE_BOOT=n
    CONFIG_BUILD_S1_VARIANT=n
    I thought I got rid of static partitions. by comment out or rename the file
    Don't I want to enable this so I can FOTA the new app into slot1 ?????
    When I do enable it, it won't compile
    CONFIG_SECURE_BOOT=y
    CONFIG_BUILD_S1_VARIANT=y
    D C:\opito\zephyr\opito_base_oct22\build\b0\zephyr && C:\ncs\toolchains\v2.1.0\opt\bin\cmake.exe -E echo ""
    c:/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr/drivers/i2c/libdrivers__i2c.a(i2c_nrfx_twim.c.obj): in function `k_sem_give':
    C:\opito\zephyr\opito_base_oct22\build\b0\zephyr\include\generated\syscalls\kernel.h:1062: undefined reference to `z_impl_k_sem_give'
    c:/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: zephyr/drivers/i2c/libdrivers__i2c.a(i2c_nrfx_twim.c.obj): in function `k_sem_take':
    C:\opito\zephyr\opito_base_oct22\build\b0\zephyr\include\generated\syscalls\kernel.h:1045: undefined reference to `z_impl_k_sem_take'
    c:/ncs/toolchains/v2.1.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.exe: C:\opito\zephyr\opito_base_oct22\build\b0\zephyr\include\generated\syscalls\kernel.h:1045: undefined reference to `z_impl_k_sem_take'
    collect2.exe: error: ld returned 1 exit status
    It really shouldn't be this hard...
    Thanks
    Marshall
  • Hi
    Sorry about the late reply, I needed to discuss this with some colleagues. First off, what exactly are you wanting to get the log of here exactly? The MCUBoot logging will only log the bootloader (what occurs when the MCU boots up before going into the application area), and not the entire DFU process. The logs of the actual DFU with the files moving from one place and onto your board is set in the DFU part of your application.
    We're also not sure where exactly this error occurs, as it only refers to your application trying to call a bad address after this firmware update it seems.
    Simon
  • Thanks Simon.
    I was wanting to see any MCU Boot messages when it started to try and determine if my external flash was being detected by MCUBoot.
    "We're also not sure where exactly this error occurs, as it only refers to your application trying to call a bad address after this firmware update it seems."
    I'm not sure which issue this is referring to:
    1. The original -  "dfu_target_mcuboot: boot_request_upgrade for image-0 error -14"
    2. The disabling of dfu by default in Asset Tracker V2
    Perhaps it would be simpler if I rephrase the issue like this.
    1. How do I enable FOTA in Asset Tracker V2?
    2. How do I enable FOTA with External Flash in Asset Tracker V2?
    Thanks and Regards
    Marshall
  • Hi
    1. There shouldn't be necessary to do anything different compared to other applications to enable FOTA in the Asset Tracker v2 project.
    2. To enable FOTA with external flash in you should set the external flash as the "chosen" target in the partition manager as explained in the external flash memory partitions documentation.
    Simon
  • Does this work at all, I've spent yet another weekend banging my head on the desk!
    Can you please post a link to a WORKING and tested response to your point 2 above.
    Also I found this... It seems to sum up the issues I'm having.
    MCUBoot Update hooks - Rejects any mcuboot updates when used with immutable bootlader - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
    Thanks
    Marshall
