I'm trying to use `bt_hci_register_vnd_evt_cb' to register a call back to process vendor specific hci events.
below is my prj.conf
CONFIG_LOG=y CONFIG_CONSOLE=y CONFIG_STDOUT_CONSOLE=y CONFIG_USE_SEGGER_RTT=y CONFIG_SHELL_BACKEND_RTT=y CONFIG_SERIAL=y CONFIG_GPIO=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_BT=y CONFIG_BT_HCI_RAW=y CONFIG_BT_HCI_RAW_H4=y CONFIG_BT_HCI_RAW_H4_ENABLE=y CONFIG_BT_BUF_ACL_RX_SIZE=255 CONFIG_BT_BUF_CMD_TX_SIZE=255 CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255 CONFIG_BT_CTLR_ASSERT_HANDLER=y CONFIG_BT_MAX_CONN=16 CONFIG_BT_TINYCRYPT_ECC=n CONFIG_BT_CTLR_DTM_HCI=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512 # Workaround: Unable to allocate command buffer when using K_NO_WAIT since # Host number of completed commands does not follow normal flow control. CONFIG_BT_BUF_CMD_TX_COUNT=10 CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_MCUBOOT_IMAGE_VERSION="0.1.0+0" CONFIG_PINCTRL=y CONFIG_GPIO_AS_PINRESET=y CONFIG_LED_STRIP=y CONFIG_LED_STRIP_LOG_LEVEL_DBG=y # CONFIG_WS2812_STRIP=y # CONFIG_WS2812_STRIP_SPI=y CONFIG_SPI=y CONFIG_BT_HCI_VS_EVT_USER=y CONFIG_BT_HCI_VS_EXT=y CONFIG_BT_HCI_VS=y CONFIG_BT_HCI_RAW_CMD_EXT=y
my callback function for testing is as below
bool vnd_evt_cb(struct net_buf_simple *buf){
LOG_INF("HCI", "vendor event cb");
return 0;
then in the main()
when I try to register the above callback using the bt_hci_register_vnd_evt_cb() build always fails with the error,
undefined reference to `bt_hci_register_vnd_evt_cb'
I'm using nrfconnect 2.1.0.
What might be the cause of the failure and a possible fix.
TIA.
