jlink programmer connection error (no idcode detected)
I'm using nrf52840, try to program using Jlink SWD programmer but fessing some issues.
over hardware connections are like below.
When I try to Connect J-Link, I get an error that says "Failed to connect to target. No idcode detected. Please check connection and Target Interface Type".
so could you please tell me this is hardware problem or software problem, if this error solve using software then could you please provide a steps to solve connection error.
  • Have someone reviewed your schematic and layout? Do you see the same on all boards or only some boards? Have you tried a different j-link? Do you have any other nRF52 board you can use for test?
    Kenneth
  • i have sent schematic earlier.
    I got this problem in only 2 board out of 10. this 2 board earlier works fine but after some test its not connect with jlink.
  • In all likelyhood something have happend to the boards, it could be some mechanical or electrical damage that now cause the boards to now not work (e.g. ESD). What can you tell me about the handling of the boards? Is it possible they might have been damaged during use?
    Kenneth
  • i think you are right. its looks like damage during test. But we are using ESD band to remove static.
  • Please find attached log file, if u find any error on it.
    [2023-Apr-25 07:27:40] [debug] --------------------------------------------------------------------------------
    [2023-Apr-25 07:27:40] [debug] nrfjprog --reset --log /home/poulami/Desktop
    [2023-Apr-25 07:27:40] [debug] nrfjprog version 10.21.0 external
    [2023-Apr-25 07:27:40] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
    [2023-Apr-25 07:27:40] [ info] Library loaded, loading member functions.
    [2023-Apr-25 07:27:40] [ info] Member functions succesfully loaded.
    [2023-Apr-25 07:27:40] [debug] [ Client] - open
    [2023-Apr-25 07:27:40] [debug] [ Client] - start
    [2023-Apr-25 07:27:40] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 610d855f-bc09-41fe-9ce8-b5d3aaff5c8f.
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2023-Apr-25 07:27:40] [debug] [  JLink] - Logger sink registered in JLink logger
    [2023-Apr-25 07:27:40] [debug] [  nRFXX] - open
    [2023-Apr-25 07:27:40] [debug] [  nRFXX] - just_check_family
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - open_dll
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2023-Apr-25 07:27:40] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.
    [2023-Apr-25 07:27:40] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2023-Apr-25 07:27:40] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - Set batch mode
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - dll_version
    [2023-Apr-25 07:27:40] [ info] [SeggerBackend] - Segger dll version 7.86.g loaded.
    [2023-Apr-25 07:27:40] [trace] [ Client] - Command open executed for 11 milliseconds with result 0
    [2023-Apr-25 07:27:40] [debug] [ Client] - config
    [2023-Apr-25 07:27:40] [trace] [ Client] - Command config executed for 2 milliseconds with result 0
    [2023-Apr-25 07:27:40] [debug] [ Client] - enum_emu_snr
    [2023-Apr-25 07:27:40] [trace] [ Worker] - Command open executed for 8 milliseconds with result 0
    [2023-Apr-25 07:27:40] [debug] [  nRFXX] - config
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - enum_emu_snr
    [2023-Apr-25 07:27:40] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
    [2023-Apr-25 07:27:40] [debug] [  nRFXX] - enum_emu_con_info
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Apr-25 07:27:40] [debug] [SeggerBackend] - enum_emu_con_info
    [2023-Apr-25 07:27:41] [trace] [ Client] - Command enum_emu_con_info executed for 818 milliseconds with result 0
    [2023-Apr-25 07:27:41] [debug] [ Client] - connect_to_emu_with_snr
    [2023-Apr-25 07:27:41] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Apr-25 07:27:41] [trace] [ Worker] - Command enum_emu_con_info executed for 818 milliseconds with result 0
    [2023-Apr-25 07:27:41] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2023-Apr-25 07:27:41] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2023-Apr-25 07:27:41] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2023-Apr-25 07:27:41] [debug] [SeggerBackend] - ---just_get_num_emus
    [2023-Apr-25 07:27:43] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Segger logging enabled.
    [2023-Apr-25 07:27:44] [trace] [  JLink] - Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Nov  7 2022 16:21:57
    [2023-Apr-25 07:27:44] [trace] [  JLink] - Hardware: V1.00
    [2023-Apr-25 07:27:44] [trace] [  JLink] - S/N: 683556667
    [2023-Apr-25 07:27:44] [trace] [  JLink] - OEM: SEGGER
    [2023-Apr-25 07:27:44] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2023-Apr-25 07:27:44] [trace] [  JLink] - USB speed mode: High speed (480 MBit/s)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2023-Apr-25 07:27:44] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 42.823ms returns "O.K."
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_HasError()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_Lock()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.003ms returns 0x01
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.002ms returns 0x00
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.001ms returns 0x00
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.006ms returns 0
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 6.573ms returns 0x00
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - 10000000 Hz / n, n >= 10
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 1000kHz
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Requested speed 2000kHz is higher than the emulator max speed of 1000kHz
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.018ms
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_GetSpeed()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.003ms returns 1000
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - SWD speed was reported as 1000kHz after requesting 2000kHz. Check the capabilities of the selected emulator.
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_GetSN()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.003ms returns 683556667
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.004ms
    [2023-Apr-25 07:27:44] [debug] [  nRFXX] - read_device_family
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_IsOpen()
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - read_debug_port_idr
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - read_debug_port_register
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - coresight_configure
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.044ms returns 0
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 102.577ms returns 0
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.256ms returns -1
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.008ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 3.060ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.814ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.989ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.984ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.023ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.943ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.042ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.093ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.861ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.108ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.959ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.991ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.010ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.978ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.022ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.925ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.976ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.027ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.025ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.961ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.026ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.981ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.029ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.053ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.095ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.869ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.020ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.965ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.035ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.021ms returns -1
    [2023-Apr-25 07:27:44] [error] [ Client] - Encountered error -102: Command connect_to_emu_with_snr executed for 2607 milliseconds with result -102
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.986ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.964ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.006ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.057ms
    [2023-Apr-25 07:27:44] [error] [ Worker] - An unknown error.
    [2023-Apr-25 07:27:44] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 2608 milliseconds with result -102
    [2023-Apr-25 07:27:44] [debug] [  nRFXX] - close
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.005ms returns 0x01
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - close
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - disconnect_from_emu
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - is_connected_to_device
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_IsConnected()
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.003ms returns FALSE
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.710ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.946ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.046ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.033ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.958ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.996ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.960ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.909ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.055ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.264ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.554ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.969ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.257ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.581ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.781ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.021ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.876ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.245ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.804ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.707ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 3.435ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.503ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 3.947ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.828ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.400ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.150ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.757ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.742ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.908ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.967ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.004ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.977ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.174ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.820ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.012ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 1.919ms returns -1
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 2.040ms returns -1
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2023-Apr-25 07:27:44] [trace] [  JLink] - - 0.029ms
    [2023-Apr-25 07:27:44] [trace] [  JLink] - JLINK_Close()
    [2023-Apr-25 07:27:44] [debug] [SeggerBackend] - Segger Backend closed.
    [2023-Apr-25 07:27:44] [debug] [  nRFXX] - nRF family DLL closed
    [2023-Apr-25 07:27:44] [trace] [ Client] - Command close executed for 117 milliseconds with result 0
    [2023-Apr-25 07:27:44] [debug] [ Client] - terminate
    [2023-Apr-25 07:27:44] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2023-Apr-25 07:27:44] [trace] [ Worker] - Command close executed for 117 milliseconds with result 0
    [2023-Apr-25 07:27:44] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2023-Apr-25 07:27:44] [trace] [ Worker] - Executed 6 commands for 3553 milliseconds
    [2023-Apr-25 07:27:44] [debug] [ Client] - Child process terminated with result 0
    [2023-Apr-25 07:27:44] [trace] [ Client] - Executed 6 commands for 3555 milliseconds
