Hi
The documentation of nRF5340 Audio Application of nRF Connect SDK 2.1.1 mentions "onboard hardware codec" and "external hardware codec".
CODEC Off - No configuration loaded to the onboard hardware codec.
and
OB/EXT
Solid green - On-board hardware codec selected.
Solid yellow - External hardware codec selected. This LED turns solid yellow also when the devices are reset, for the time then pins are floating.
Is there some more description on how I can select either of the 3 LC3 codecs?
- LC3 software codec (used in default configuration)
- Onboard hardware codec
Additionally, I'm not sure about what component is meant by "onboard hardware codec". What component is it?
Many thanks for bringing more light into that.
