Code snippet below produces the error code 0x00000001 during nrfx_spim_xfer:
ret_code_t Spi_Transfer(uint8_t *txBuff, uint8_t *rxBuff, size_t tx_length, size_t rx_length, uint8_t cs)
nrfx_spim_xfer_desc_t xferDesc = NRFX_SPIM_XFER_TRX(txBuff, tx_length, rxBuff, rx_length);
// Reset rx buffer and transfer flag
memset(rxBuff, 0, rx_length);
spi_xfer_done = false;
/*NOTE: Below manual operation of CS pin is necessary because driver does not
natively handle multiple spi slaves on one spi instance */
nrf_gpio_pin_clear(cs);
// TODO: use nonblocking mode
ret_code_t ret = nrfx_spim_xfer(&m_spi, &xferDesc, 0);
while (!spi_xfer_done)
__WFE();
nrf_gpio_pin_set(cs);
return ret== NRF_SUCCESS;
The same SW in a different project does not produce the error. The error occurs during attempted communication with a Winbond W25Q64JV and FW crashes. There is another device on the SPI bus that doesn't have an issue. What does this error indicate as the reason for it's generation? We are using SDK nRF5_SDK_17.1.0_ddde560 and SES ARM V5.70a IDE. Screenshot of error below:
