[nRF Connect SDK] Pairing failure
Target nRF52832(nrf52dk_nrf52832)
SDK NCS v2.0.0
original case
(+) [nRF Connect SDK]Force to make pairing(bonding) - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
Here is my test step. (Nordic: peripheral role)
1) Nordic begins advertising (custom UUID like peripheral_uart sample)
2) Android app gets predefined bt mac (example 00:16:7F:11:22:36).
There were no BLE scan. and connect to Nordic.
3) Nordic connected and initiate pairing
bt_set_bondable(true);
bt_conn_set_security(conn, BT_SECURITY_L4);
Result
Much of case my Android (MTK) failed to make pairing. (Especially right after android rebooted)
MTK have told me Nordic should provide solution to resolve this issue.
RTT Viewer
00> Connected secmode 4
00> HS connected
00> HS Connected 00:16:7F:40:1E:D0 (public)
00> D:
00> D: 00:16:7F:40:1E:D0 (public)
00> D: prnd 7d93ec3b4828ce3b4210d054f903653a
00> D: chan 0x20001f54 cid 0x0006
00> D: status 0x8
00> D: chan 0x20001f54 conn 0x20001c90 handle 0 encrypt 0x00 hci status 0x1f
00> Security failed: 00:16:7F:40:1E:D0 (public) level 1 err 9
(Android public mac 00:16:7F:40:1E:D0)
2772.sf650_error_03Nov2022.7z
BTW, Nordic required sniff log for analyzing pairing error. However, I hardly get sniff log.
I can get CONNECT_IND then drops next packets. Do you have any idea?
nrf_sniffer_for_bluetooth_le_4.1.1
wireshark 4.0.1
nRF52DK dev borad
J-Link 6.88a
  • P.s: Could you also try using the nRF Connect app to perform the pairing? The app can produce some potentially helpful logs from the phone side.
  • Thanks for updating.
    I'll upload the nRF Connect app log as soon as it is ready.
  • Just in case, you also saw my longer reply where I ask if you can see if more reproductions of the issues result in the same disconnect reason 0x28, and where I asked for the sniffer trace again, right?
  • 1. nRF Connect app log
    nRF Connect, 2022-11-14
    Nordic_UART_Service (00:16:7F:11:22:36)
    V	14:27:21.563	Connecting to 00:16:7F:11:22:36...
    D	14:27:21.564	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	14:27:22.357	[Callback] Connection state changed with status: 133 and new state: DISCONNECTED (0)
    E	14:27:22.357	Error 133 (0x85): GATT ERROR
    I	14:27:22.357	Disconnected
    2.
    -> Can you please explain your mention?
    I repeated this test and found reason was 0x5 or 0x28.
  • Hi Tim,
    Regarding your nRF Connect app log
    As you can see, in the log, the connection didn't even happen successfully. So that log shows an entirely new kind of failure compared to the ones you have shown me...
    For your reference of what normal looks like, here are a few logs I quickly created myself. Just my Android phone, and a peripheral_uart sample modified just like you described.
    hivo c297913 (FF:26:0E:1A:CB:4D)
    D	13:17:09.449	gatt.close()
    D	13:17:09.454	wait(200)
    V	13:17:09.657	Connecting to FF:26:0E:1A:CB:4D...
    D	13:17:09.658	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	13:17:11.814	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	13:17:11.841	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	13:17:11.841	Connected to FF:26:0E:1A:CB:4D
    V	13:17:11.846	Discovering services...
    D	13:17:11.846	gatt.discoverServices()
    I	13:17:12.107	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	13:17:12.172	PHY updated (TX: LE 2M, RX: LE 2M)
    D	13:17:12.492	[Callback] Services discovered with status: 0
    I	13:17:12.492	Services discovered
    V	13:17:12.498	Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    - Client Supported Features [R W] (0x2B29)
    - Database Hash [R] (0x2B2A)
    Generic Access (0x1800)
    - Device Name [R] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
    - TX Characteristic [N] (6e400003-b5a3-f393-e0a9-e50e24dcca9e)
    - RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
    D	13:17:12.498	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	13:17:12.505	gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
    I	13:17:12.605	Connection parameters updated (interval: 48.75ms, latency: 0, timeout: 5000ms)
    D	13:17:12.651	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	13:17:12.675	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
    D	13:17:14.703	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PASSKEY_CONFIRMATION (2)
    I	13:17:16.945	Connection parameters updated (interval: 48.75ms, latency: 0, timeout: 420ms)
    D	13:17:21.645	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
    I	13:17:21.647	Device bonded
    SEGGER J-Link V7.70d - Real time terminal output
    J-Link OB-SAM3U128-V2-NordicSemi compiled Jan 20 2022 16:43:31 V1.0, SN=683326383
    Process: JLink.exe
    [00:00:00.000,183] <dbg> bt_hci_core: bt_hci_driver_register: Registered SoftDevice Controller
    --- 471 messages dropped ---
    [00:00:00.057,525] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:00.057,617] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20008f6c opcode 0x200a len 4
    [00:00:00.057,647] <dbg> bt_hci_core: process_events: count 2
    [00:00:00.057,739] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:00.057,769] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:00.057,769] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:00.057,861] <dbg> bt_hci_core: send_cmd: Sending command 0x200a (buf 0x20008f6c) to driver
    [00:00:00.057,891] <dbg> bt_hci_core: bt_send: buf 0x20008f6c len 4 type 0
    [00:00:00.057,891] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:00.057,983] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:00.058,258] <dbg> sdc_hci_driver: hci_driver_send: Ex0m
    [00:00:09.221,893] <dbg> bt_hci_core: hci_cmd_done: opcode 0x2016 status 0x00 buf 0x20008f6c
    --- 46 messages dropped ---
    [00:00:09.222,259] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.222,259] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:09.222,290] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:09.222,381] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x2016 len 0
    [00:00:09.222,412] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x2032 param_len 7
    [00:00:09.222,503] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:09.222,534] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20008f6c opcode 0x2032 len 10
    [00:00:09.222,656] <dbg> bt_hci_core: process_events: count 3
    [00:00:09.222,717] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:09.222,747] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:09.222,778] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:09.222,778] <dbg> bt_hci_core: send_cmd: Sending command 0x2032 (buf 0x20008f6c) to driver
    [00:00:09.222,869] <dbg> bt_hci_core: bt_send: buf 0x20008f6c len 10 type 0
    [00:00:09.222,900] <dbg> sdc_hci_driver: hci0m
    [00:00:09.222,900] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:09.223,022] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:09.223,114] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.223,236] <dbg> sdc_hci_driver: event_packet_process: Command Status (0x2032) status: 0x00
    [00:00:09.223,266] <dbg> bt_hci_core: bt_recv: buf 0x20008f6c len 6
    [00:00:09.223,327] <dbg> bt_hci_core: hci_cmd_status: opcode 0x2032
    [00:00:09.223,358] <dbg> bt_hci_core: hci_cmd_done: opcode 0x2032 status 0x00 buf 0x20008f6c
    [00:00:09.223,724] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.223,754] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:09.223,815] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:09.223,876] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x2032 len 0
    [00:00:09.443,450] <dbg> bt_conn: tx_notify: conn 0x20001e88
    --- 7 messages dropped ---
    [00:00:09.443,450] <dbg> bt_conn: bt_conn_recv: handle 0 len 11 flags 02
    [00:00:09.443,542] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    [00:00:09.443,542] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:09.443,572] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.443,664] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.443,664] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.443,786] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0xffff type 2b3a
    [00:00:09.444,030] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:09.444,030] <dbg> bt_att: chan_send: code 0x01
    [00:00:09.444,061] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    [00:00:09.444,061] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 9 cb 0x2407d user_data 0x20008184
    [00:00:09.444,183] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:09.444,274] <dbg> bt_hci_core: process_events: count 3
    [00:00:09.444,274] <dbg> bt_hci_core: process_events: ev->st
    [00:00:09.444,488] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 13 type 2
    [00:00:09.444,519] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:09.444,549] <dbg> sdc_hci_driver: acl_handle:
    [00:00:09.444,671] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:09.444,732] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.444,763] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:09.444,793] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:09.483,032] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x04), len (12)
    [00:00:09.483,062] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 14
    [00:00:09.483,459] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:09.483,459] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 14
    [00:00:09.483,520] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:09.483,551] <dbg> bt_ype 2800
    --- 25 messages dropped ---
    [00:00:09.524,322] <dbg> bt_att: read_group_cb: handle 0x0001
    [00:00:09.524,414] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:09.524,505] <dbg> bt_att: read_group_cb: handle 0x0009
    [00:00:09.524,536] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:09.524,627] <dbg> bt_att: read_group_cb: handle 0x0010
    [00:00:09.524,658] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:09.524,688] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x11
    [00:00:09.524,749] <dbg> bt_att: chan_send: code 0x11
    [00:00:09.524,780] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 14
    [00:00:09.524,810] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 18 cb 0x2407d user_data 0x20008184
    [00:00:09.524,932] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:09.525,024] <dbg> bt_hci_core: process_events: count 3
    [00:00:09.525,024] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.525,054] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.525,11ate 4
    [00:00:09.525,146] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:09.525,177] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 18
    [00:00:09.525,177] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 18 flags 0x02
    [00:00:09.525,268] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 22 type 2
    [00:00:09.525,299] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:09.525,299] <dbg> sdc_hci_driver: acl_handle:
    [00:00:09.525,421] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:09.525,512] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.525,543] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:09.525,543] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:09.525,665] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:09.525,726] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:09.604,858] <dbg> bt_att: chan_send: code 0x11
    --- 31 messages dropped ---
    [00:00:09.604,858] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 22
    [00:00:09.604,949] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 26 cb 0x2407d user_data 0x20008184
    [00:00:09.605,072] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:09.605,102] <dbg> bt_hci_core: process_events: count 3
    [00:00:09.605,194] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.605,224] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.605,224] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:09.605,316] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:09.605,316] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 26
    [00:00:09.605,346] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 26 flags 0x02
    [00:00:09.605,438] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 30 type 2
    [00:00:09.605,438] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:09.605,468] <dbg> sdc_hci_driver: acl_handle:
    [00:00:09.605,590] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:09.605,682] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.605,682] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:09.605,712] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    --- 30 messages dropped ---
    [00:00:09.652,770] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:09.652,862] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    --- 45 messages dropped ---
    [00:00:09.667,968] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:09.668,060] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.668,090] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.668,090] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.668,212] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0x0008 type 2802
    [00:00:09.683,197] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0x0008 type 2803
    [00:00:09.683,319] <dbg> bt_att: read_type_cb: handle 0x0002
    [00:00:09.683,380] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:09.683,441] <dbg> bt_att: read_type_cb: handle 0x0005
    [00:00:09.683,502] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    att: chan_send: code 0x09
    --- 49 messages dropped ---
    [00:00:09.713,226] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:09.713,256] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.713,287] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.713,348] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.713,470] <dbg> bt_att: att_read_type_req: start_handle 0x0008 end_handle 0x0008 type 2803
    [00:00:09.713,623] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:09.713,653] <dbg> bt_att: chan_send: code 0x01
    [00:00:09.713,653] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    --- 40 messages dropped ---
    [00:00:09.727,996] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 5
    [00:00:09.727,996] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 5
    [00:00:09.728,080m
    [00:00:09.743,011] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.772,827] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    --- 48 messages dropped ---
    [00:00:09.772,888] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.772,918] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.773,040] <dbg> bt_att: att_read_type_req: start_handle 0x000d end_handle 0x000f type 2803
    [00:00:09.773,162] <dbg> bt_att: read_type_cb: handle 0x000e
    [00:00:09.773,193] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:09.773,284] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:09.773,284] <dbg> bt_att: chan_send: code 0x09
    [00:00:09.773,315] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 9
    [00:00:09.773,376] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 13 cb 0x2407d user_data 0x20008184
    [00:00:09.773,437] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:09.773,529] <dbg> bt_hci_core: process_events: count 3
    --- 37 messages dropped ---
    [00:00:09.787,780] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.787,811] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.787,841] <dbg> bt_att: bt_att_recv5] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:09.817,932] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.817,962] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.818,084] <dbg> bt_att: att_read_type_req: start_handle 0x0010 end_handle 0x0015 type 2803
    [00:00:09.818,176] <dbg> bt_att: read_type_cb: handle 0x0011
    [00:00:09.818,206] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 19
    [00:00:09.818,298] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:09.818,328] <dbg> bt_att: chan_send: code 0x09
    --- 42 messages dropped ---
    [00:00:09.832,977] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.833,007] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.833,129] <dbg> bt_att: att_read_type_req: start_handle 0x0012 end_handle 0x0015 type 2803
    [00:00:09.833,251] <dbg> bt_att: read_type_cb: handle 0x0014
    --- 44 messages dropped ---
    [00:00:09.847,839] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:09.847,900] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:09.847,930] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:09.848,052] <dbg> bt_att: att_read_type_req: start_handle 0x0015 end_handle 0x0015 type 2803
    [00:00:09.848,205] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:09.848,236] <dbg> bt_att: chan_send: code 0x01
    [00:00:09.863,525] <dbg> bt_hci_core: process_events: ev->state 0
    --- 10 messages dropped ---
    [00:00:09.863,616] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:09.863,616] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:09.863,647] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:09.863,708] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 10
    [00:00:09.863,739] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 10 flags 0x02
    [00:00:09.863,769] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 14 type 2
    [00:00:09.863,830] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:09.863,861] <dbg> sdc_hci_driver: acl_handle:
    [00:00:09.863,983] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:09.864,013] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:09.864,074] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e80m
    [00:00:09.864,105] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:09.864,227] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:09.864,257] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:09.876,556] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:09.876,586] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:09.876,586] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:09.876,678] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:09.876,708] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:09.876,800] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:09.877,166] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:09.877,197] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:09.877,197] <dbg> bt_conn: tx_notify: tx 0x20002fe0 cb 0x2407d user_data 0x20008184
    [00:00:09.877,288] <dbg> bt_att: att_rsp_sent: conn 0x20001e88 chan 0x20008180
    [00:00:09.877,288] <dbg> bt_att: att_sent: conn 0x20001e88 chan 0x20008184
    [00:00:09.877,319] <dbg> bt_att: bt_att_sent: chan 0x20008180
    [00:00:09.877,380] <dbg> bt_att: chan_rsp_sent: chan 0x20008180
    [00:00:09.929,229] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x03), len (10)
    [00:00:09.929,321] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 12
    [00:00:09.929,687] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:09.929,718] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 12
    [00:00:09.929,779] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:09.929,809] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x03
    [00:00:09.929,840] <dbg> bt_hci_core: le_conn_update_complete: status 0x00, handle 0
    [00:00:09.929,840] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:09.929,931] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:10.060,211] <dbg> bt_smp: smp_send_security_req:
    [00:00:10.060,546] <dbg> bt_keys: bt_keys_get_addr: 4A:FF:9E:CC:4F:50 (random)
    [00:00:10.060,821] <dbg> bt_keys: bt_keys_get_addr: created 0x20003108 for 4A:FF:9E:CC:4F:50 (random)
    [00:00:10.061,431] <dbg> bt_smp: smp_init: prnd 8ad309c0da9c019cfa363a2a48af3252
    [00:00:10.061,553] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 2
    [00:00:10.061,584] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 6 cb (nil) user_data (nil)
    [00:00:10.061,676] <dbg> bt_hci_core: process_events: count 3
    [00:00:10.061,676] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:10.061,767] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:10.061,767] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:10.061,798] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:10.061,889] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 6
    [00:00:10.061,889] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 6 flags 0x02
    [00:00:10.061,92[00:00:10.122,802] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:10.122,833] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:10.122,863] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:10.122,894] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:10.122,894] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:10.122,985] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:12.403,503] <dbg> bt_hci_core: hci_acl: handle 0 len 11 flags 2
    --- 5 messages dropped ---
    [00:00:12.403,533] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:12.403,533] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:12.403,594] <dbg> bt_conn: bt_conn_recv: handle 0 len 11 flags 02
    [00:00:12.403,625] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    [00:00:12.403,625] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:12.403,717] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 6 len 7
    [00:00:12.403,747] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002144 len 7
    [00:00:12.403,747] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x01 len 6
    [00:00:12.403,778] <dbg> bt_smp: smp_pairing_req:
    [00:00:12.403,869] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 7
    [00:00:12.403,900] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 11 cb (nil) user_data (nil)
    [00:00:12.403,991] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:12.404,083] <dbg> bt_hci_core: process_events: count 3
    [00:00:12.404,113] <dbg> bt_hci_core: proces[0m
    [00:00:12.404,357] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:12.404,357] <dbg> sdc_hci_driver: acl_handle:
    [00:00:12.404,479] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:12.404,510] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:12.404,571] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:12.404,602] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:12.491,577] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    --- 95 messages dropped ---
    [00:00:12.523,254] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:12.523,345] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:12.523,468] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:12.523,498] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:12.523,529] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:12.523,681] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:12.524,230] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:12.524,261] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:12.524,353] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:12.524,353] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:12.524,383] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:12.524,475] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:12.524,780] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 25 type 2
    [00:00:12.524,841] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:12.524,841] <dbg> sdc_hci_driver: acl_handle:
    [00:00:12.524,963] <dbg> sdc_hci_driver: hciit: 0
    [00:00:12.524,993] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:12.525,085] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:12.525,085] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:12.539,154] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 36
    [00:00:12.539,276] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:12.539,276] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 36
    [00:00:12.539,367] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:12.539,398] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x09
    [00:00:12.539,398] <dbg> bt_ecc: bt_hci_evt_le_dhkey_complete: status: 0x00
    [00:00:12.539,489] <dbg> bt_smp: bt_smp_dhkey_ready: 0x20008c94
    [00:00:12.604,522] <dbg> bt_smp: smp_g2: y 8ad309c0da9c019cfa363a2a48af3252
    [00:00:12.606,597] <dbg> bt_smp: smp_g2: res 0a8ff4536ff47f3c7eabe45bdaa4775f
    [00:00:12.606,628] <dbg> bt_smp: smp_g2: passkey 211551
    [00:00:12.606,689] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:12.606,994] <inf> peripheral_uart: Passkey for 4A:FF:9E:CC:4F:50 (random): 211551
    [00:00:12.606,994] <inf> peripheral_uart: Press Button 1 to confirm, Button 2 to reject.
    [00:00:12.607,086] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 17
    [00:00:12.607,116] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 21 cb (nil) user_data (nil)
    [00:00:12.607,238] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:12.607,330] <dbg> bt_hci_core: process_events: count 3
    [00:00:12.607,360] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:12.607,452] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:12.607,452] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:12.607,543] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 21
    [00:00:12.607,574] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 21 flags 0x02
    [00:00:12.607,604] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 25 type 2
    [00:00:12.607,604] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:12.607,696] <dbg> sdc_hci_driver: acl_handle:
    [00:00:12.607,727] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:12.607,818] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:12.607,849] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:12.607,849] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:12.683,013] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:12.683,044] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:12.683,135] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:12.683,135] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:12.683,166] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:12.683,227] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:14.219,940] <dbg> bt_conn: deferred_work: conn 0x20001e88
    [00:00:14.220,031] <dbg> bt_conn: send_conn_le_param_update: conn 0x20001e88 features 0x2d params (24-40 0 42)
    [00:00:14.220,062] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 5 len 12
    [00:00:14.220,062] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 16 cb (nil) user_data (nil)
    [00:00:14.220,184] <dbg> bt_hci_core: process_events: count 3
    [00:00:14.220,245] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:14.220,275] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:14.220,275] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:14.220,306] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:14.220,306] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 16
    [00:00:14.220,397] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 16 flags 0x02
    [00:00:14.220,428] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 20 type 2
    [00:00:14.220,489] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:14.220,520] <dbg> sdc_hci_driver: acl_handle:
    [00:00:14.220,611] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:14.220,642] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:14.220,672] <dbg> bt_conn: conn_prepa[00:00:14.282,745] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:14.282,989] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:14.283,020] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:14.283,020] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:14.283,081] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:14.283,111] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:14.323,089] <dbg> sdc_hci_driver: data_packet_process: Data: handle (0x00), PB(2), BC(0), len(10)
    [00:00:14.323,150] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 14
    [00:00:14.323,455] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:14.323,455] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 3 len 14
    [00:00:14.323,547] <dbg> bt_hci_core: hci_acl: buf 0x20008b78
    [00:00:14.323,577] <dbg> bt_hci_core: hci_acl: handle 0 len 10 flags 2
    9] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:14.323,669] <dbg> bt_conn: bt_conn_recv: handle 0 len 10 flags 02
    [00:00:14.323,699] <dbg> bt_conn: bt_acl_recv: First, len 10 final 6
    [00:00:14.323,699] <dbg> bt_conn: bt_acl_recv: Successfully parsed 10 byte L2CAP packet
    [00:00:14.323,760] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 5 len 6
    [00:00:14.323,791] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002ff0 len 6
    [00:00:14.323,822] <dbg> bt_l2cap: l2cap_recv: Signaling code 0x13 ident 1 len 2
    [00:00:14.323,822] <dbg> bt_lt 0
    [00:00:14.323,913] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:14.482,971] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x03), len (10)
    [00:00:14.483,062] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 12
    [00:00:14.483,459] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:14.483,459] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 12
    [00:00:14.483,520] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:14.483,551] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x03
    [00:00:14.483,581] <dbg> bt_hci_core: le_conn_update_complete: status 0x00, handle 0
    [00:00:14.483,581] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:14.483,642] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:22.522,827] <dbg> sdc_hci_driver: data_packet_process: Data: handle (0x00), PB(2), BC(0), len(21)
    [00:00:22.522,918] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 25
    [00:00:22.523,193] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:22.523,284] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 3 len 25
    [00:00:22.523,284] <dbg> bt_hci_core: hci_acl: buf 0x20008b78
    [00:00:22.523,315] <dbg> bt_hci_core: hci_acl: handle 0 len 21 flags 2
    [00:00:22.523,315] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:22.523,406] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:22.523,406] <dbg> bt_conn: bt_conn_recv: handle 0 len 21 flags 02
    [00:00:22.523,437] <dbg> bt_conn: bt_acl_recv: First, len 21 final 17
    [00:00:22.523,437] <dbg> bt_conn: bt_acl_recv: Successfully parsed 21 byte L2CAP packet
    [00:00:22.523,529] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 6 len 17
    [00:00:22.523,559] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002144 len 17
    [00:00:22.523,559] <dbg> bt_[0m
    [00:00:22.523,620] <dbg> bt_smp: smp_dhkey_check:
    [00:00:22.523,681] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:42.607,299] <err> bt_smp: SMP Timeout
    [00:00:42.607,360] <dbg> bt_smp: smp_pairing_complete: status 0x8
    [00:00:42.607,635] <dbg> bt_keys: bt_keys_clear: 4A:FF:9E:CC:4F:50 (random) (keys 0x0000)
    [00:00:42.607,910] <dbg> bt_settings: bt_settings_encode_key: Encoded path bt/keys/4aff9ecc4f501
    [00:00:42.608,001] <dbg> bt_keys: bt_keys_clear: Deleting key bt/keys/4aff9ecc4f501
    [00:00:42.608,093] <dbg> bt_smp: bt_smp_encrypt_change: chan 0x20002144 conn 0x20001e88 handle 0 encrypt 0x00 hci status 0x1f
    [00:00:42.608,123] <dbg> bt_att: bt_att_encrypt_change: chan 0x20008184 conn 0x20001e88 handle 0 sec_level 0x01 status 0x1f
    [00:00:42.608,398] <wrn> peripheral_uart: Security failed: 4A:FF:9E:CC:4F:50 (random) level 1 err 9
    [00:00:42.608,703] <inf> peripheral_uart: Pairing failed conn: 4A:FF:9E:CC:4F:50 (random), reason 9
    [00:00:55.524,353] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    --- 33 messages dropped ---
    [00:00:55.524,353] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
    [00:00:55.524,444] <dbg> bt_conn: bt_conn_unref: handle 0 ref 1 -> 0
    [00:00:55.524,475] <dbg> bt_conn: bt_conn_set_state: disconnected -> connecting-adv
    [00:00:55.524,566] <dbg> bt_conn: bt_conn_ref: handle 0 ref 1 -> 2
    [00:00:55.524,566] <dbg> bt_adv: bt_le_adv_resume: Resuming connectable advertising
    [00:00:55.524,597] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x200a param_len 1
    [00:00:55.524,688] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:55.524,719] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20008f6c opcode 0x200a len 4
    [00:00:55.524,841] <dbg> bt_hci_core: process_events: count 2
    [00:00:55.524,841] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:55.524,932] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:55.524,932] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:55.524,963] <dbg> bt_hci_core: send_cmd: Sending command 0x200a (buf 0x20008f6c) to driver
    [00:00:55.525,054] <dbg> bt_hci_core: bt_send: buf 0x20008f60m
    [00:00:55.525,054] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:55.525,085] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:55.525,360] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:55.525,360] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:55.525,482] <dbg> sdc_hci_driver: event_packet_process: Command Complete (0x200a) status: 0x00, ncmd: 1, len 4
    [00:00:55.525,573] <dbg> bt_hci_core: bt_recv: buf 0x20008f6c len 6
    [00:00:55.525,573] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x200a
    [00:00:55.525,604] <dbg> bt_hci_core: hci_cmd_done: opcode 0x200a status 0x00 buf 0x20008f6c
    [00:00:55.525,970] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:55.525,970] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
    [00:00:55.526,092] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x200a len 1
    [00:00:55.526,153] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
    --- 469 messages dropped ---
    [00:00:00.051,727] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:00.051,818] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20008f6c opcode 0x200a len 4
    [00:00:00.051,849] <dbg> bt_hci_core: process_events: count 2
    [00:00:00.051,940] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:00.051,940] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:00.051,971] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:00.052,062] <dbg> bt_hci_core: send_cmd: Sending command 0x200a (buf 0x20008f6c) to driver
    [00:00:00.052,062] <dbg> bt_hci_core: bt_send: buf 0x20008f6c len 4 type 0
    [00:00:00.052,093] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:00.052,154] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:00.052,459] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:00.052,459] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:00.052,581] <dbg> sdc_hci_driver: event_packet_process: Command Complete (0x200a) status: 0x00, ncmd: 1, len 4
    [00:00:00.052,642] <dbg> bt_hci_core: bt_recv: buf 0x20008f6c len 6
    [00:00:00.052,673] <dbg> bt_hci_core: hci_cm
    [00:00:00.053,039] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:00.053,070] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 2 events
    [00:00:00.053,161] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x200a len 1
    [00:00:00.053,222] <dbg> bt_conn: bt_conn_unref: handle 0 ref 2 -> 1
    [00:00:00.100,250] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 68
    [00:00:00.100,280] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:00.100,372] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 68
    [00:00:00.100,372] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:00.100,402] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x08
    [00:00:00.100,463] <dbg> bt_ecc: bt_hci_evt_le_pkey_complete: status: 0x00
    [00:00:00.100,494] <dbg> bt_smp: bt_smp_pkey_ready:
    [00:00:16.069,305] <dbg> bt_hci_core: hci_cmd_done: opcode 0x2016 status 0x00 buf 0x20008f6c
    [00:00:16.069,641] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:16.069,671] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:16.069,732] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:16.069,793] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x2016 len 0
    [00:00:16.069,885] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x2032 param_len 7
    [00:00:16.069,915] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:16.069,976] <dbg> bt_hci_core: bt_hci_cmd_send_sync: buf 0x20008f6c opcode 0x2032 len 10
    [00:00:16.070,129] <dbg> bt_hci_core: process_events: count 3
    [00:00:16.070,129] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:16.070,159] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:16.070,190] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:16.070,251] <dbg> bt_hci_core: send_cmd: Sending command 0x2032 (buf 0x20008f6c) to driver
    [00:00:16.070,281] <dbg> bt_hci_core: bt_send: buf 0x20008f6c len 10 type 0
    [00:00:16.070,281] <dbg> sdc_hci_driver: hci0m
    [00:00:16.070,373] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:16.070,495] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:16.070,495] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.070,526] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.070,648] <dbg> sdc_hci_driver: event_packet_process: Command Status (0x2032) status: 0x00
    [00:00:16.070,709] <dbg> bt_hci_core: bt_recv: buf 0x20008f6c len 6
    [00:00:16.070,739] <dbg> bt_hci_core: hci_cmd_status: opcode 0x2032
    [00:00:16.070,770] <dbg> bt_hci_core: hci_cmd_done: opcode 0x2032 status 0x00 buf 0x20008f6c
    [00:00:16.071,136] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:16.071,197] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:16.071,228] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:16.071,350] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x2032 len 0
    [00:00:16.395,385] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:16.395,385] <dbg> bt_conn: bt_conn_recv: handle 0 len 11 flags 02
    [00:00:16.395,416] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    [00:00:16.395,416] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:16.395,507] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.395,538] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.395,538] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.395,660] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0xffff type 2b3a
    [00:00:16.395,904] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:16.395,965] <dbg> bt_att: chan_send: code 0x01
    [00:00:16.395,996] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    [00:00:16.395,996] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 9 cb 0x2407d user_data 0x20008184
    [00:00:16.396,118] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.396,148] <dbg> bt_hci_core: process_events: count 3
    [00:00:16.396,209] <dbg> bt_hci_core: process_events: ev->state 0
    ate 0
    [00:00:16.396,240] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:16.396,270] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:16.396,301] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 9
    [00:00:16.396,362] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 9 flags 0x02
    [00:00:16.396,392] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 13 type 2
    [00:00:16.396,392] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:16.396,484] <dbg> sdc_hci_driver: acl_handle:
    [00:00:16.396,575] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:16.396,636] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:16.396,636] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:16.396,728] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:16.443,664] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x04), len (12)
    [00:00:16.443,72[0m
    [00:00:16.444,213] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x04
    [00:00:16.444,244] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:16.444,244] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.493,743] <dbg> bt_att: read_group_cb: handle 0x0001
    --- 26 messages dropped ---
    [00:00:16.493,774] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:16.493,865] <dbg> bt_att: read_group_cb: handle 0x0009
    [00:00:16.493,896] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:16.494,018] <dbg> bt_att: read_group_cb: handle 0x0010
    [00:00:16.494,018] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.494,110] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x11
    [00:00:16.494,140] <dbg> bt_att: chan_send: code 0x11
    [00:00:16.494,140] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 14
    [00:00:16.494,232] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 18 cb 0x2407d user_data 0x20008184
    [00:00:16.494,354] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.494,384] <dbg> bt_3
    [00:00:16.494,445] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.494,476] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.494,506] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:16.494,506] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:16.494,598] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 18
    [00:00:16.494,628] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 18 flags 0x02
    [00:00:16.494,628] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 22 type 2
    [00:00:16.494,720] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:16.494,720] <dbg> sdc_hci_driver: acl_handle:
    [00:00:16.494,842] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:16.494,873] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:16.494,964] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:16.494,964] <dbg> bt_hci_core: hci_tx_thread: Calling7] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:16.541,137] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x03), len (10)
    [00:00:16.541,229] <dbg> bt_hci_core: bt_recv: buf 0x20008b78 len 12
    [00:00:16.541,595] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:16.541,625] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b78 type 1 len 12
    [00:00:16.541,656] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:16.541,717] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x03
    [00:00:16.541,717] <dbg> bt_[00:00:16.592,224] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    --- 22 messages dropped ---
    [00:00:16.592,224] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.592,254] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x10 len 6
    [00:00:16.592,376] <dbg> bt_att: att_read_group_req: start_handle 0x0010 end_handle 0xffff type 2800
    [00:00:16.592,468] <dbg> bt_att: read_group_cb: handle 0x0010
    [00:00:16.592,498] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 16
    [00:00:16.592,620] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x11
    [00:00:16.592,681] <dbg> bt_att: chan_send: code 0x11
    [00:00:16.592,712] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 22
    [00:00:16.592,742] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 26 cb 0x2407d user_data 0x20008184
    [00:00:16.592,834] <dbg> bt_conn: bt_conn_unref: handle 0 re--- 3 messages dropped ---
    [00:00:16.592,987] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:16.593,078] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:16.593,109] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 26
    [00:00:16.593,109] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 26 flags 0x02
    [00:00:16.593,200] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 30 type 2
    [00:00:16.593,200] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:16.593,231] <dbg> sdc_hci_driver: acl_handle:
    --- 27 messages dropped ---
    [00:00:16.636,718] <dbg> bt_conn: bt_conn_recv: handle 0 len 11 flags 02
    [00:00:16.636,749] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    [00:00:16.636,749] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:16.636,840] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.636,840] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    --- 51 messages dropped ---
    [00:00:16.660,308] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:16.660,339] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.660,369] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.660,430] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.660,552] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0x0008 type 2802
    [00:00:16.660,705] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:16.660,736] <dbg> bt_att: chan_send: code 0x01
    [00:00:16.682,495] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0x0008 type 2803
    [00:00:16.682,556] <dbg> bt_att: read_type_cb: handle 0x0002
    [00:00:16.682,617] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.682,708] <dbg> bt_att: read_type_cb: handle 0x0005
    [00:00:16.704,895] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.705,017] <dbg> bt_att: att_read_type_req: start_handle 0x0006 end_handle 0x0008 type 2803
    [00:00:16.705,139] <dbg> bt_att: read_type_cb: handle 0x0007
    [00:00:16.705,230] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.705,261] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:16.705,322] <dbg> bt_att: chan_send: code 0x09
    [00:00:16.705,352] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 9
    [00:00:16.705,383] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 13 cb 0x2407d user_data 0x20008184
    [00:00:16.705,505] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    --- 38 messages dropped ---
    [00:00:16.727,325] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.727,355] <dbg> bt_l2cap: l2cap_cham
    [00:00:16.727,386] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.749,755] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 5
    [00:00:16.749,786] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x04 len 4
    [00:00:16.749,786] <dbg> bt_att: att_find_info_req: start_handle 0x0004 end_handle 0x0004
    [00:00:16.749,908] <dbg> bt_att: find_info_cb: handle 0x0004
    [00:00:16.750,000] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x05
    [00:00:16.750,000] <dbg> bt_att: chan_send: code 0x05
    [00:00:16.750,030] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 6
    [00:00:16.750,122] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 10 cb 0x2407d user_data 0x20008184
    [00:00:16.750,152] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.750,274] <dbg> bt_hci_core: process_events: count 3
    [00:00:16.750,2736 messages dropped ---
    [00:00:16.772,155] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.772,247] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.772,277] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.772,399] <dbg> bt_att: att_read_type_req: start_handle 0x0009 end_handle 0x000f type 2802
    [00:00:16.794,891] <dbg> bt_att: att_read_type_req: start_handle 0x0009 end_handle 0x000f type 2803
    [00:00:16.795,013] <dbg> bt_att: read_type_cb: handle 0x000a
    [00:00:16.795,043] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.795,135] <dbg> bt_att: read_type_cb: handle 0x000c
    [00:00:16.795,166] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.795,257] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:16.795,257] <dbg> bt_att: chan_send: code 0x09
    [00:00:16.795,28en 16
    [00:00:16.817,352] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.817,474] <dbg> bt_att: att_read_type_req: start_handle 0x000d end_handle 0x000f type 2803
    [00:00:16.817,596] <dbg> bt_att: read_type_cb: handle 0x000e
    [00:00:16.817,626] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:16.817,718] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:16.817,718] <dbg> bt_att: chan_send: code 0x09
    [00:00:16.817,749] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 9
    [00:00:16.817,810] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 13 cb 0x2407d user_data 0x20008184
    [00:00:16.839,691] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:16.839,782] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.839,78m
    [00:00:16.862,152] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:16.862,182] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.862,243] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.862,274] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.862,396] <dbg> bt_att: att_read_type_req: start_handle 0x0010 end_handle 0x0015 type 2802
    [00:00:16.862,609] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:16.862,640] <dbg> bt_att: chan_send: code 0x01
    [00:00:16.862,670] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    [00:00:16.862,731] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 9 cb 0x2407d user_data 0x20008184
    [00:00:16.862,792] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.862,884] <dbg> bt_hci_core: process_events: count 3
    8] <dbg> bt_att: read_type_cb: handle 0x0011
    [00:00:16.892,700] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 19
    [00:00:16.892,730] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:16.892,791] <dbg> bt_att: chan_send: code 0x09
    [00:00:16.892,822] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 23
    [00:00:16.892,852] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 27 cb 0x2407d user_data 0x20008184
    [00:00:16.892,974] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.893,066] <dbg> bt_hci_core: process_events: count 3
    [00:00:16.893,066] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.922,302] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.922,424] <dbg> bt_att: att_read_type_req: start_handle 0x0012 end_handle 0x0015 type 2803
    [00:00:16.922,546] <dbg> bt_att: read_type_cb: handle 0x0014
    [00:00:16.922,637] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 19
    [00:00:16.922,668] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:16.944,671] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:16.944,671] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:16.944,763] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:16.944,885] <dbg> bt_att: att_read_type_req: start_handle 0x0015 end_handle 0x0015 type 2803
    [00:00:16.945,037] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:16.967,254] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 5
    [00:00:16.967,254] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 5
    [00:00:16.967,285] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x04 len 4
    [00:00:16.967,376] <dbg> bt_att: att_find_info_req: start_handle 0x0013 end_handle 0x0013
    [00:00:16.967,407] <dbg> bt_att: find_info_cb: handle 0x0013
    [00:00:16.967,864] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:16.967,895] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:16.967,895] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:16.967,987] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009030 len 10
    [00:00:16.968,017] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 10 flags 0x02
    [00:00:16.968,017] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 14 type 2
    [00:00:16.968,109] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:16.968,109] <dbg> sdc_hci_driver: acl_handle:
    [00:00:16.968,231] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:16.968,261] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:16.968,353] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:16.968,353] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 ev: buf 0x20008a78 len 7
    [00:00:16.988,433] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:16.988,464] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:16.988,464] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:16.988,586] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:16.988,952] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:16.989,013] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:16.989,044] <dbg> bt_conn: tx_notify: tx 0x20002fe0 cb 0x2407d user_data 0x20008184
    [00:00:16.989,074] <dbg> bt_att: att_rsp_sent: conn 0x20001e88 chan 0x20008180
    [00:00:16.989,166] <dbg> bt_att: att_sent: conn 0x20001e88 chan 0x20008184
    [00:00:16.989,166] <dbg> bt_att: bt_att_sent: chan 0x20008180
    [00:00:16.989,196] <dbg> bt_att: chan_rsp_sent: chan 0x20008180
    [00:00:17.033,264] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x03), len (10)
    [00:00:17.033,355] <dbg> bt_hci_core: bt_recv: buf 0x20008b94 len 12
    [00:00:17.033,721] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:17.033,843] <dbg> bt_hci_core: le_conn_update_complete: status 0x00, handle 0
    [00:00:17.033,874] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:17.033,966] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:17.055,236] <dbg> bt_smp: smp_send_security_req:
    [00:00:17.055,572] <dbg> bt_keys: bt_keys_get_addr: 5F:CB:F5:C1:D5:B0 (random)
    [00:00:17.055,847] <dbg> bt_keys: bt_keys_get_addr: created 0x20003108 for 5F:CB:F5:C1:D5:B0 (random)
    [00:00:17.056,457] <dbg> bt_smp: smp_init: prnd c324f97797b496164948bf657a5e70da
    [00:00:17.056,579] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 2
    [00:00:17.056,671] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 6 cb (nil) user_data (nil)
    [00:00:17.056,762] <dbg> bt_hci_core: process_events: count 3
    [00:00:17.056,793] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:17.056,793] <dbg> bt_hci_core: proces8] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:17.057,159] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:17.057,189] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:17.057,250] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:17.057,312] <inf> peripheral_uart: bt_conn_set_security = 0
    [00:00:17.124,633] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:17.124,664] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:17.124,694] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:17.124,755] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:17.124,755] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:17.124,786] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:18.880,126] <dbg> bt_hci_core: hci_acl: handle 0 len 11 flags 2
    [00:00:18.880,157] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:18.880,157] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:18.880,218] <dbg> bt_conn: bt_conn_recv: handle 0 len 11 flags 02
    [00:00:18.880,249] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    [00:00:18.880,249] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:18.880,340] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 6 len 7
    [00:00:18.880,371] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002144 len 7
    [00:00:18.880,371] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x01 len 6
    [00:00:18.880,401] <dbg> bt_smp: smp_pairing_req:
    [00:00:18.880,493] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 7
    [00:00:18.880,523] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 11 cb (nil) user_data (nil)
    [00:00:18.880,645] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:18.880,737] <dbg> bt_hci_core: process_events: count 3
    [00:00:18.880,737] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:18.880,767] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:18.880,767] <dbg> bt_[00:00:18.880,859] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009030 len 11 flags 0x02
    [00:00:18.880,889] <dbg> bt_hci_core: bt_send: buf 0x20009030 len 15 type 2
    [00:00:18.880,981] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:18.880,981] <dbg> sdc_hci_driver: acl_handle:
    [00:00:18.881,103] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:18.881,134] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:18.881,195] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:18.881,225] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:18.985,198] <dbg> bt_hci_core: process_events: ev->state 0
    --- 89 messages dropped ---
    [00:00:18.985,198] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:18.985,229] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:18.985,321] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 21
    [00:00:18.985,321] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 21 flags 0x02
    [00:00:18.985,412] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x2026 len 0
    [00:00:18.985,473] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:19.026,153] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:19.026,184] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:19.026,214] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:19.026,336] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:19.026,367] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:19.026,580] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:19.026,947] <dbg> bt_hci_core: bt_send: buf 0x2000904hci_core: hci_event: event 0x3e
    [00:00:19.032,562] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x09
    [00:00:19.032,592] <dbg> bt_ecc: bt_hci_evt_le_dhkey_complete: status: 0x00
    [00:00:19.032,684] <dbg> bt_smp: bt_smp_dhkey_ready: 0x20008cdd
    [00:00:19.074,859] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:19.075,042] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:19.075,073] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:19.075,103] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:19.075,103] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:19.075,256] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:19.075,653] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:19.075,653] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:19.075,744] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:19.075,744] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:19.075,775] <dbg> bt_conn: bt_conn_ref 3 -> 2
    [00:00:19.124,908] <dbg> bt_smp: smp_g2: y c324f97797b496164948bf657a5e70da
    --- 24 messages dropped ---
    [00:00:19.126,983] <dbg> bt_smp: smp_g2: res bf7067b647c87ddcca750962b0a285f1
    [00:00:19.127,044] <dbg> bt_smp: smp_g2: passkey 441137
    [00:00:19.127,075] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:19.127,349] <inf> peripheral_uart: Passkey for 5F:CB:F5:C1:D5:B0 (random): 441137
    [00:00:19.127,441] <inf> peripheral_uart: Press Button 1 to confirm, Button 2 to reject.
    [00:00:19.127,471] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 17
    [00:00:19.127,563] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 21 cb (nil) user_data (nil)
    [00:00:19.127,685] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:19.127,716] <dbg> bt_hci_core: process_events: count 3
    [00:00:19.127,807] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:19.127,838] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:19.127,892
    [00:00:19.128,021] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 25 type 2
    [00:00:19.128,051] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:19.128,051] <dbg> sdc_hci_driver: acl_handle:
    [00:00:19.128,173] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:19.128,204] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:19.128,265] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:19.128,295] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:19.220,794] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:19.220,886] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:19.220,947] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:19.220,977] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:19.220,977] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:19.221,069] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:21.067,413] <dbg> bt_conn: deferred_work: conn 0x20001e88
    [00:00:21.067,443] <dbg> bt_conn: send_conn_le_param_update: conn 0x20001e88 features 0x2d params (24-40 0 42)
    [00:00:21.067,596] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 5 len 12
    [00:00:21.067,626] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 16 cb (nil) user_data (nil)
    [00:00:21.067,749] <dbg> bt_hci_core: process_events: count 3
    [00:00:21.067,749] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:21.067,779] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:21.067,779] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:21.067,840] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:21.067,871] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 16
    [00:00:21.067,871] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 16 flags 0x02
    [00:00:21.067,962] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 20 type 2
    [00:00:21.067,993] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:21.067,993] <dbg> sdc_hci_driver: acl_handle:
    [00:00:21.068,115] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:21.068,145] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:21.068,206] <dbg> bt_conn: conn_prepare_events: Addinhci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:21.073,913] <inf> peripheral_uart: Numeric Match, conn 0x20001e88
    [00:00:21.073,944] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:21.122,039] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:21.122,070] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:21.122,100] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:21.122,161] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:21.122,192] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:21.122,222] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:21.170,928] <dbg> sdc_hci_driver: data_packet_process: Data: handle (0x00), PB(2), BC(0), len(10)
    [00:00:21.170,989] <dbg> bt_hci_core: bt_recv: buf 0x20008b94 len 14
    [00:00:21.171,295] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:21.171,356] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b94 type 3 len 14
    [00:00:21.171,386] <dbg> bt_hci_core: hci_acl: buf 0x20008b94
    [00:00:21.171,417] <dbg> bt_hci_core: hci_acl: handle 0 len 10 flags 2
    [00:00:21.171,447] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:21.171,508] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:21.171,508] <dbg> bt_conn: bt_conn_recv: handle 0 len 10 flags 02
    [00:00:21.171,539] <dbg> bt_conn: bt_acl_recv: First, len 10 final 6
    [00:00:21.171,630] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 5 len 6
    [00:00:21.171,630] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002ff0 len 6
    [00:00:21.171,661] <dbg> bt_l2cap: l2cap_recv: Signaling code 0x13 ident 1 len 2
    [00:00:21.171,661] <dbg> bt_l2cap: le_conn_param_rsp: LE conn param rsp result 0
    [00:00:21.171,752] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:21.365,814] <dbg> sdc_hci_driver: event_packet_process: LE Meta Event (0x03), len (10)
    [00:00:21.365,905] <dbg> bt_hci_core: bt_recv: buf 0x20008b94 len 12
    [00:00:21.366,271] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:21.366,302] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b94 type 1 len 12
    [00:00:21.366,363] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:21.366,394] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x03
    [00:00:21.366,394] <dbg> bt_hci_core: le_conn_update_complete: status 0x00, handle 0
    [00:00:21.366,424] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:21.366,485] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:25.186,859] <dbg> bt_smp: smp_f6: n2 c324f97797b496164948bf657a5e70da
    [00:00:25.186,981] <dbg> bt_smp: smp_f6: r 00000000000000000000000000000000
    [00:00:25.186,981] <dbg> bt_smp: smp_f6: io_cap 04000d
    [00:00:25.187,072] <dbg> bt_smp: smp_f6: a1 01b0d5c1f5cb5f
    [00:00:25.187,103] <dbg> bt_smp: smp_f6: a2 014dcb1a0e26ff
    [00:00:25.189,208] <dbg> bt_smp: smp_f6: res 20be9dae040029af2b1014c17e8f19c9
    [00:00:25.189,208] <dbg> bt_smp: sc_smp_send_dhkey_check:
    [00:00:25.189,331] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 6 len 17
    [00:00:25.189,331] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 21 cb (nil) user_data (nil)
    [00:00:25.189,453] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:25.189,544] <dbg> bt_hci_core: process_events: count 3
    [00:00:25.189,575] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.189,605] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.189,605] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:25.189,666] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:25.189,697] <dbg> bt_conn: send_buf: conn 0x20001e88 en 21
    [00:00:25.189,727] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 21 flags 0x02
    [00:00:25.189,788] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 25 type 2
    [00:00:25.189,819] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:25.189,849] <dbg> sdc_hci_driver: acl_handle:
    [00:00:25.189,941] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:25.189,971] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:25.190,063] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:25.190,063] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:25.325,103] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    --- 8 messages dropped ---
    [00:00:25.325,103] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b94 type 1 len 15
    [00:00:25.325,134] <dbg> bt_hci_core: hci_event: event 0x3e
    [00:00:25.325,225] <dbg> bt_hci_core: hci_le_meta_event: subevent 0x05
    [00:00:25.325,225] <dbg> bt_hci_core: le_ltk_request: handle 0
    [00:00:25.325,256] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:25.325,317] <dbg> bt_hci_core: bt_hci_cmd_create: opcode 0x201a param_len 18
    [00:00:25.325,347] <dbg> bt_hci_core: bt_hci_cmd_create: buf 0x20008f6c
    [00:00:25.325,378] <dbg> bt_hci_core: bt_hci_cmd_send: opcode 0x201a len 21
    [00:00:25.325,469] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:25.325,500] <dbg> bt_hci_core: process_events: count 3
    [00:00:25.325,592] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:25.325,592] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:25.325,622] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:25.325,622] <dbg> bt_hci_core: send_cmd: Sending command 0x201a (buf 0x20008f6c) to driver
    [00:00:25.325,714] <dbg> bt_[0m
    [00:00:25.325,714] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:25.325,744] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:25.325,866] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:25.325,866] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.325,958] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.326,049] <dbg> sdc_hci_driver: event_packet_process: Command Complete (0x201a) status: 0x00, ncmd: 1, len 6
    [00:00:25.326,080] <dbg> bt_hci_core: bt_recv: buf 0x20008f6c len 8
    [00:00:25.326,110] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x201a
    [00:00:25.326,171] <dbg> bt_hci_core: hci_cmd_done: opcode 0x201a status 0x00 buf 0x20008f6c
    [00:00:25.326,477] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:25.326,568] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:25.326,568] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:25.568,206] <dbg> sdc_hci_driver: event_packet_process: Event (0x08) len 4
    [00:00:25.568,298] <dbg> bt_hci_core: bt_recv: buf 0x20008b94 len 6
    [00:00:25.568,695] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:25.568,695] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b94 type 1 len 6
    [00:00:25.568,756] <dbg> bt_hci_core: hci_event: event 0x08
    [00:00:25.568,786] <dbg> bt_hci_core: hci_encrypt_change: status 0x00 handle 0 encrypt 0x01
    [00:00:25.568,817] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:25.569,122] <dbg> bt_keys: bt_keys_clear: 5F:CB:F5:C1:D5:B0 (random) (keys 0x0000)
    [00:00:25.569,396] <dbg> bt_settings: bt_settings_encode_key: Encoded path bt/keys/5fcbf5c1d5b01
    [00:00:25.569,427] <dbg> bt_keys: bt_keys_clear: Deleting key bt/keys/5fcbf5c1d5b01
    [00:00:25.569,793] <dbg> bt_keys: bt_keys_get_addr: 5F:CB:F5:C1:D5:B0 (random)
    [00:00:25.570,159] <dbg> bt_keys: bt_keys_get_addr: created 0x20003108 for 5F:CB:F5:C1:D5:B0 (random)
    [00:00:25.570,220] <dbg> bt_smp: bt_smp_encrypt_change: chan 0x20002144 conn 0x20001e88 handle 0 encrypt 0x0[00:00:25.617,126] <dbg> sdc_hci_driver: data_packet_process: Data: handle (0x00), PB(2), BC(0), len(21)
    [00:00:25.617,218] <dbg> bt_hci_core: bt_recv: buf 0x20008b94 len 25
    [00:00:25.617,553] <dbg> bt_hci_core: rx_work_handler: Getting net_buf from queue
    [00:00:25.617,553] <dbg> bt_hci_core: rx_work_handler: buf 0x20008b94 type 3 len 25
    [00:00:25.617,584] <dbg> bt_hci_core: hci_acl: buf 0x20008b94
    [00:00:25.617,584] <dbg> bt_hci_core: hci_acl: handle 0 len 21 flags 2
    [00:00:25.617,675] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:25.617,675] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:25.617,706] <dbg> bt_conn: bt_conn_recv: handle 0 len 21 flags 02
    [00:00:25.617,706] <dbg> bt_conn: bt_acl_recv: First, len 21 final 17
    [00:00:25.617,797] <dbg> bt_conn: bt_acl_recv: Successfully parsed 21 byte L2CAP packet
    [00:00:25.617,828] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 6 len 17
    [00:00:25.617,828] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20002144 len 17
    [00:00:25.617,919] <dbg> bt_smp: bt_smp_recv: Received SMP code 0x08 len 16
    [00:00:25.617,919] <dbg> bt_smp: smp_ident_info:
    [00:00:25.618,194] <dbg> bt_keys: bt_keys_get_type: type 2 5F:CB:F5:C1:D5:B0 (random)
    [00:00:25.671,356] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    --- 64 messages dropped ---
    [00:00:25.671,386] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    --- 7 messages dropped ---
    [00:00:25.671,875] <dbg> bt_hci_core: send_cmd: calling net_buf_get
    [00:00:25.671,875] <dbg> bt_hci_core: send_cmd: calling sem_take_wait
    [00:00:25.671,966] <dbg> bt_hci_core: send_cmd: Sending command 0x202d (buf 0x20008f6c) to driver
    [00:00:25.671,997] <dbg> bt_hci_core: bt_send: buf 0x20008f6c len 4 type 0
    [00:00:25.671,997] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:25.672,088] <dbg> sdc_hci_driver: cmd_handle:
    [00:00:25.672,210] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:25.672,210] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.672,241] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:25.672,363] <dbg> sdc_hci_driver: event_packet_process: Command Complete (0x202d) status: 0x00, ncmd: 1, len 4
    [00:00:25.672,424] <dbg> bt_hci_core: bt_recc len 6
    [00:00:25.672,454] <dbg> bt_hci_core: hci_cmd_complete: opcode 0x202d
    [00:00:25.672,485] <dbg> bt_hci_core: hci_cmd_done: opcode 0x202d status 0x00 buf 0x20008f6c
    [00:00:25.672,851] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:25.672,851] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:25.672,943] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:25.673,034] <dbg> bt_hci_core: bt_hci_cmd_send_sync: rsp 0x20008f6c opcode 0x202d len 1
    [00:00:25.673,065] <dbg> bt_smp: smp_pairing_complete: status 0x0
    [00:00:25.673,339] <dbg> bt_settings: bt_settings_encode_key: Encoded path bt/keys/d004b0043d3c0
    [00:00:25.680,419] <dbg> bt_keys: bt_keys_store: Stored keys for D0:04:B0:04:3D:3C (public) (bt/keys/d004b0043d3c0)
    [00:00:25.680,694] <inf> peripheral_uart: Pairing completed: D0:04:B0:04:3D:3C (public), bonded: 1
    [00:00:25.680,725] <dbg> bt_conn: bt_conn_unref: handle 0 re[00:00:26.105,194] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 9
    --- 12 messages dropped ---
    [00:00:26.105,194] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x06 len 8
    [00:00:26.105,224] <dbg> bt_att: att_find_type_req: start_handle 0x0001 end_handle 0xffff type 10240
    [00:00:26.105,316] <dbg> bt_att: find_type_cb: handle 0x0001
    [00:00:26.105,346] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:26.105,438] <dbg> bt_att: find_type_cb: handle 0x0009
    [00:00:26.105,468] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:26.105,560] <dbg> bt_att: find_type_cb: handle 0x0010
    [00:00:26.105,590] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 16
    [00:00:26.105,682] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x07
    [00:00:26.105,712] <dbg> bt_att: chan_send: code 0x07
    [00:00:26.105,712] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    0m
    [00:00:26.105,834] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.105,957] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.105,957] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.106,048] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.106,048] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:26.106,079] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:26.106,140] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 9
    [00:00:26.106,170] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 9 flags 0x02
    [00:00:26.106,201] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 13 type 2
    [00:00:26.106,262] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.106,292] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.106,414] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.106,445] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.106,475] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list00:00:26.203,186] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 9
    --- 23 messages dropped ---
    [00:00:26.203,186] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x06 len 8
    [00:00:26.203,277] <dbg> bt_att: att_find_type_req: start_handle 0x0009 end_handle 0xffff type 10240
    [00:00:26.203,369] <dbg> bt_att: find_type_cb: handle 0x0009
    [00:00:26.203,399] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 2
    [00:00:26.203,491] <dbg> bt_att: find_type_cb: handle 0x0010
    [00:00:26.203,521] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 16
    [00:00:26.203,674] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:26.203,765] <dbg> bt_att: chan_send: code 0x01
    [00:00:26.203,765] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    [00:00:26.203,796] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 9 cb 0x2407d user_data 0x20008184
    [00:00:26.203,918] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.204,010] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.204,040] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.204,132] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 9 flags 0x02
    [00:00:26.204,254] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 13 type 2
    [00:00:26.204,284] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.204,345] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.204,406] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.204,498] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.204,528] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.204,589] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.204,650] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:26.204,742] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:26.300,659] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:26.300,781] <dbg> bt_att: att_read_type_req: start_handle 0x0001 end_handle 0x0008 type 2803
    [00:00:26.300,811] <dbg> bt_att: read_type_cb: handle 0x0002
    [00:00:26.300,903] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:26.300,933] <dbg> bt_att: read_type_cb: handle 0x0005
    [00:00:26.301,025] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:26.301,055] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:26.301,116] <dbg> bt_att: chan_send: code 0x09
    [00:00:26.301,147] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 16
    [00:00:26.301,177] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 20 cb 0x2407d user_data 0x20008184
    [00:00:26.301,269] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.301,391] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.301,39ate 0
    [00:00:26.301,422] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.301,422] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:26.301,513] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:26.301,544] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 20
    [00:00:26.301,605] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 20 flags 0x02
    [00:00:26.301,635] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 24 type 2
    [00:00:26.301,666] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.301,666] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.301,788] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.301,879] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.301,910] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.301,910] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.302,032] <dbg> bt_conn: tx_complet[00:00:26.398,071] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:26.398,071] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:26.398,162] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:26.398,284] <dbg> bt_att: att_read_type_req: start_handle 0x0006 end_handle 0x0008 type 2803
    [00:00:26.398,315] <dbg> bt_att: read_type_cb: handle 0x0007
    [00:00:26.398,406] <dbg> bt_gatt: bt_gatt_attr_read: handle 0x0000 offset 0 length 5
    [00:00:26.398,437] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x09
    [00:00:26.398,529] <dbg> bt_att: chan_send: code 0x09
    [00:00:26.398,529] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 9
    [00:00:26.398,559] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 13 cb 0x2407d user_data 0x20008184
    [00:00:26.398,681] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.398,773] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.398,773] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.398,803] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.398,864] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:26.398,895] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:26.398,925] <dbg> bt_2
    [00:00:26.399,017] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 17 type 2
    [00:00:26.399,047] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.399,047] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.399,169] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.399,261] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.399,291] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.399,353] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.399,414] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:26.399,505] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:26.495,544] <dbg> bt_conn: bt_acl_recv: First, len 11 final 7
    --- 20 messages dropped ---
    [00:00:26.495,544] <dbg> bt_conn: bt_acl_recv: Successfully parsed 11 byte L2CAP packet
    [00:00:26.495,574] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 7
    [00:00:26.495,574] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 7
    [00:00:26.495,666] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x08 len 6
    [00:00:26.495,758] <dbg> bt_att: att_read_type_req: start_handle 0x0008 end_handle 0x0008 type 2803
    [00:00:26.495,910] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x01
    [00:00:26.495,941] <dbg> bt_att: chan_send: code 0x01
    [00:00:26.495,941] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 5
    [00:00:26.496,032] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 9 cb 0x2407d user_data 0x20008184
    [00:00:26.496,124] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.496,185] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.496,246] <dbg> bt_hci_core: process_events: ev->st
    [00:00:26.496,429] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 13 type 2
    [00:00:26.496,520] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.496,520] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.496,643] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.496,673] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.496,765] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.496,765] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.496,887] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:26.496,917] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:26.593,139] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x04 len 4
    [00:00:26.593,170] <dbg> bt_att: att_find_info_req: start_handle 0x0003 end_handle 0x0008
    [00:00:26.593,261] <dbg> bt_att: find_info_cb: handle 0x0003
    [00:00:26.593,292] <dbg> bt_att: find_info_cb: handle 0x0004
    [00:00:26.593,292] <dbg> bt_att: find_info_cb: handle 0x0005
    [00:00:26.593,383] <dbg> bt_att: find_info_cb: handle 0x0006
    [00:00:26.593,414] <dbg> bt_att: find_info_cb: handle 0x0007
    [00:00:26.593,475] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x05
    [00:00:26.593,505] <dbg> bt_att: chan_send: code 0x05
    [00:00:26.593,536] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 22
    [00:00:26.593,536] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 26 cb 0x2407d user_data 0x20008184
    [00:00:26.593,658] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    [00:00:26.593,750] <dbg> bt_hci_core: process_events: count 3
    [00:00:26.593,780] <dbg> bt_hci_core: process_events: ev->state 0
    2
    [00:00:26.594,024] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 30 type 2
    [00:00:26.594,024] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.594,116] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.594,207] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.594,268] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.594,268] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.594,360] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.594,451] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:26.594,482] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:26.690,521] <dbg> bt_conn: bt_acl_recv: First, len 9 final 5
    [00:00:26.690,521] <dbg> bt_conn: bt_acl_recv: Successfully parsed 9 byte L2CAP packet
    [00:00:26.690,551] <dbg> bt_l2cap: bt_l2cap_recv: Packet for CID 4 len 5
    [00:00:26.690,612] <dbg> bt_l2cap: l2cap_chan_recv: chan 0x20008184 len 5
    [00:00:26.690,643] <dbg> bt_att: bt_att_recv: Received ATT chan 0x20008180 code 0x04 len 4
    [00:00:26.690,643] <dbg> bt_att: att_find_info_req: start_handle 0x0008 end_handle 0x0008
    [00:00:26.690,765] <dbg> bt_att: find_info_cb: handle 0x0008
    [00:00:26.690,795] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x05
    [00:00:26.690,795] <dbg> bt_att: chan_send: code 0x05
    [00:00:26.690,887] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 6
    [00:00:26.690,917] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 10 cb 0x2407d user_data 0x20008184
    [00:00:26.691,009] <dbg> bt_conn: bt_conn_unref: handle 0 re3
    [00:00:26.691,131] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.691,162] <dbg> bt_hci_core: process_events: ev->state 0
    [00:00:26.691,162] <dbg> bt_hci_core: process_events: ev->state 4
    [00:00:26.691,253] <dbg> bt_conn: bt_conn_process_tx: conn 0x20001e88
    [00:00:26.691,284] <dbg> bt_conn: send_buf: conn 0x20001e88 buf 0x20009048 len 10
    [00:00:26.691,284] <dbg> bt_conn: send_frag: conn 0x20001e88 buf 0x20009048 len 10 flags 0x02
    [00:00:26.691,375] <dbg> bt_hci_core: bt_send: buf 0x20009048 len 14 type 2
    [00:00:26.691,375] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.691,406] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.691,528] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.691,619] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.691,619] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.691,650] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.691,772] <dbg> bt_conn: tx_complet[00:00:26.787,780] <dbg> bt_conn: bt_conn_ref: handle 0 ref 2 -> 3
    [00:00:26.795,867] <dbg> bt_gatt: sc_store: stored SC for D0:04:B0:04:3D:3C (public) (bt/sc/d004b0043d3c0, 0x0000-0x0000)
    [00:00:26.795,959] <dbg> bt_gatt: bt_gatt_attr_write_ccc: handle 0x0000 value 2
    [00:00:26.795,989] <dbg> bt_gatt: gatt_ccc_changed: ccc 0x2000067c value 0x0002
    [00:00:26.796,264] <dbg> bt_keys: bt_keys_find_addr: D0:04:B0:04:3D:3C (public)
    [00:00:26.796,325] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:26.796,356] <dbg> bt_att: bt_att_chan_send: chan 0x20008180 flags 5 code 0x13
    [00:00:26.796,447] <dbg> bt_att: chan_send: code 0x13
    [00:00:26.796,447] <dbg> bt_l2cap: bt_l2cap_send_cb: conn 0x20001e88 cid 4 len 1
    [00:00:26.796,478] <dbg> bt_conn: bt_conn_send_cb: conn handle 0 buf len 5 cb 0x2407d user_data 0x20008184
    [00:00:26.796,600] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:26.796,691] <dbg> bt_hci_core: process_events: count 0m
    [00:00:26.796,936] <dbg> sdc_hci_driver: hci_driver_send:
    [00:00:26.796,966] <dbg> sdc_hci_driver: acl_handle:
    [00:00:26.797,088] <dbg> sdc_hci_driver: hci_driver_send: Exit: 0
    [00:00:26.797,180] <dbg> bt_conn: bt_conn_prepare_events:
    [00:00:26.797,180] <dbg> bt_conn: conn_prepare_events: Adding conn 0x20001e88 to poll list
    [00:00:26.797,210] <dbg> bt_hci_core: hci_tx_thread: Calling k_poll with 3 events
    [00:00:26.884,368] <dbg> sdc_hci_driver: event_packet_process: Event (0x13) len 5
    [00:00:26.884,490] <dbg> bt_hci_core: bt_recv: buf 0x20008a78 len 7
    [00:00:26.884,521] <dbg> bt_hci_core: hci_num_completed_packets: num_handles 1
    [00:00:26.884,521] <dbg> bt_hci_core: hci_num_completed_packets: handle 0 count 1
    [00:00:26.884,613] <dbg> bt_conn: bt_conn_ref: handle 0 ref 3 -> 4
    [00:00:26.884,643] <dbg> bt_conn: bt_conn_unref: handle 0 ref 4 -> 3
    [00:00:26.885,009] <dbg> bt_conn: tx_complete_work: conn 0x20001e88
    [00:00:26.885,009] <dbg> bt_conn: tx_notify: conn 0x20001e88
    [00:00:26.885,101] <dbg> bt_conn: tx_notify: tx 0x20002fd0 cb 0x2407d user_data 0x20008184
    [00:00:26.885,101] <dbg> bt_att: att_rsp_sent: conn 0x20001e88 chan 0x20008180
    [00:00:26.885,131] <dbg> bt_att: att_sent: conn 0x20001e88 chan 0x20008184
    [00:00:26.885,223] <dbg> bt_att: bt_att_sent: chan 0x20008180
    [00:00:26.885,223] <dbg> bt_att: chan_rsp_sent: chan 0x20008180
    [00:00:27.796,752] <dbg> bt_keys: bt_keys_find_addr: D0:04:B0:04:3D:3C (public)
    [00:00:27.796,844] <dbg> bt_gatt: ccc_save: Storing CCCs handle 0x0004 value 0x0002
    [00:00:27.797,119] <dbg> bt_settings: bt_settings_encode_key: Encoded path bt/ccc/d004b0043d3c0
    [00:00:27.802,764] <dbg> bt_gatt: bt_gatt_store_ccc: Stored CCCs for D0:04:B0:04:3D:3C (public) (bt/ccc/d004b0043d3c0)
    [00:00:27.802,764] <dbg> bt_gatt: bt_gatt_store_ccc:   CCC: handle 0x0004 value 0x0002
    [00:00:27.802,856] <dbg> bt_conn: bt_conn_unref: handle 0 ref 3 -> 2
    nRF Connect, 2022-11-14
    hivo c297913 (FF:26:0E:1A:CB:4D)
    D	13:10:15.605	gatt.close()
    D	13:10:15.612	wait(200)
    V	13:10:15.813	Connecting to FF:26:0E:1A:CB:4D...
    D	13:10:15.813	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	13:10:16.231	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	13:10:16.253	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	13:10:16.253	Connected to FF:26:0E:1A:CB:4D
    V	13:10:16.266	Discovering services...
    D	13:10:16.266	gatt.discoverServices()
    I	13:10:16.473	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	13:10:16.539	PHY updated (TX: LE 2M, RX: LE 2M)
    D	13:10:16.700	[Callback] Services discovered with status: 0
    I	13:10:16.700	Services discovered
    V	13:10:16.708	Generic Attribute (0x1801)
    - Service Changed [I] (0x2A05)
       Client Characteristic Configuration (0x2902)
    - Client Supported Features [R W] (0x2B29)
    - Database Hash [R] (0x2B2A)
    Generic Access (0x1800)
    - Device Name [R] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Nordic UART Service (6e400001-b5a3-f393-e0a9-e50e24dcca9e)
    - TX Characteristic [N] (6e400003-b5a3-f393-e0a9-e50e24dcca9e)
    - RX Characteristic [W WNR] (6e400002-b5a3-f393-e0a9-e50e24dcca9e)
    D	13:10:16.708	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	13:10:16.709	gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
    I	13:10:16.791	Connection parameters updated (interval: 40.0ms, latency: 0, timeout: 5000ms)
    D	13:10:16.955	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	13:10:16.994	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
    D	13:10:19.484	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PASSKEY_CONFIRMATION (2)
    I	13:10:21.394	Connection parameters updated (interval: 40.0ms, latency: 0, timeout: 420ms)
    D	13:10:59.357	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_NONE (10)
    I	13:10:59.357	Bonding failed
    D	13:11:02.354	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    I	13:11:02.354	Disconnected
    D	13:11:02.391	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	13:12:25.176	gatt.close()
    D	13:12:25.184	wait(200)
    V	13:12:25.384	Connecting to FF:26:0E:1A:CB:4D...
    D	13:12:25.384	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	13:12:25.713	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    D	13:12:25.734	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	13:12:25.734	Connected to FF:26:0E:1A:CB:4D
    V	13:12:25.734	Discovering services...
    D	13:12:25.734	gatt.discoverServices()
    I	13:12:26.035	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    I	13:12:26.099	PHY updated (TX: LE 2M, RX: LE 2M)
    D	13:12:26.254	[Callback] Services discovered with status: 0
    I	13:12:26.254	Services discovered
    V	13:12:26.259	Generic Attribute (0x1801)
    D	13:12:26.259	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
    D	13:12:26.262	gatt.setCharacteristicNotification(6e400003-b5a3-f393-e0a9-e50e24dcca9e, true)
    I	13:12:26.358	Connection parameters updated (interval: 40.0ms, latency: 0, timeout: 5000ms)
    D	13:12:26.480	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
    D	13:12:26.539	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_CONSENT (3)
    D	13:12:28.124	[Broadcast] Action received: android.bluetooth.device.action.PAIRING_REQUEST, pairing variant: PAIRING_VARIANT_PASSKEY_CONFIRMATION (2)
    I	13:12:30.874	Connection parameters updated (interval: 40.0ms, latency: 0, timeout: 420ms)
    D	13:13:08.327	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_NONE (10)
    I	13:13:08.327	Bonding failed
    D	13:13:11.281	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
    I	13:13:11.281	Disconnected
    D	13:13:11.318	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    Regarding my comment: devzone.nordicsemi.com/.../395213
    I have explained there what I observed, and why I request at least one sniffer log with the pairing procedure, if not two or three.
    Regarding your following statement:
    Tim Hwang said:
    I repeated this test and found reason was 0x5 or 0x28.
    Do you mean HCI event 0x5, or do you mean HCI event 0x5 and the reason is also 0x5?
    HCI Event 0x5 means BT_HCI_EVT_DISCONN_COMPLETE. It just means a disconnection. It doesn't say why there was a disconnection.
    If you see both reason 0x5 (BT_HCI_ERR_AUTH_FAIL) and reason 0x28 (BT_HCI_ERR_INSTANT_PASSED), and you have the above nRF Connect app log, then your system is showing at least three different kinds of failure with the same setup.
    That is going to be extremely complicated to analyze.
    In this situation, we will need a lot more data, you will have to be very methodical in recording your logs. You need to record both
    - Android log
    - Device RTT log
    - Sniffer traces
    And they need to be organized so both you and I can tell which is what.
    Before you send more logs, I have a few questions/requests
    1. Can your Android app or device consistently successfully pair with any BLE device? A BLE mouse, for example?
    2. Can your current nRF52 device consistently successfully pair with any Android/iOS/Windows device?
    3. Are you working in an environment with a lot of 2.4GHz signals?
    4. Is there any reason why you push aside my request for sniffer logs with the pairing procedure?
    5. Can you also zip up and send us the modified peripheral_uart project which you are using? You can use west build -t clean to remove all build artifacts to keep the file light.
    If you send more data, please try to categorize them by the kind of failure (disconnect reasons), group both Android, RTT, and sniffer trace together for each test/each failure.
    There is just nothing much I can do with fragmented info...
