Value MAX ble_adv_fast_timeout in advertising configuration
I am develloping advertising configuration and would like to use the fast or slow advertising mode.
In the ble_advertising.h, it seems that the limit are an uint32_t
typedef struct
    bool     ble_adv_on_disconnect_disabled;     /**< Enable or disable automatic return to advertising upon disconnecting.*/
    bool     ble_adv_whitelist_enabled;          /**< Enable or disable use of the whitelist. */
    bool     ble_adv_directed_high_duty_enabled; /**< Enable or disable high duty direct advertising mode. Can not be used together with extended advertising. */
    bool     ble_adv_directed_enabled;           /**< Enable or disable direct advertising mode. */
    bool     ble_adv_fast_enabled;               /**< Enable or disable fast advertising mode. */
    bool     ble_adv_slow_enabled;               /**< Enable or disable slow advertising mode. */
    uint32_t ble_adv_directed_interval;          /**< Advertising interval for directed advertising. */
    uint32_t ble_adv_directed_timeout;           /**< Time-out (number of tries) for direct advertising. */
    uint32_t ble_adv_fast_interval;              /**< Advertising interval for fast advertising. */
    uint32_t ble_adv_fast_timeout;               /**< Time-out (in units of 10ms) for fast advertising. */
    uint32_t ble_adv_slow_interval;              /**< Advertising interval for slow advertising. */
    uint32_t ble_adv_slow_timeout;               /**< Time-out (in units of 10ms) for slow advertising. */
    bool     ble_adv_extended_enabled;           /**< Enable or disable extended advertising. */
    uint32_t ble_adv_secondary_phy;              /**< PHY for the secondary (extended) advertising @ref BLE_GAP_PHYS (BLE_GAP_PHY_1MBPS, BLE_GAP_PHY_2MBPS or BLE_GAP_PHY_CODED). */
    uint32_t ble_adv_primary_phy;                /**< PHY for the primary advertising. @ref BLE_GAP_PHYS (BLE_GAP_PHY_1MBPS, BLE_GAP_PHY_2MBPS or BLE_GAP_PHY_CODED). */
} ble_adv_modes_config_t;
But after testing, it seems that the limit are uint16_t. (i would like a timeout after 20 minutes).
The SDK used are 15.3 and softdevice s132_nrf52_6.1.0_softdevice on NRF52832.
Thanks and best Regards,
Julien
