Flash arduino code (hex file) to Custom board based on nRF52810
I have written code based on Bluefruit nRF52 feather board in Arduino IDE. I need help to know is it possible for me to flash same code to my custom board based on nRF52810/ nRF52832.
Note : I'm not asking for code conversion from nRF52832 of Bluefruit Feather board to custom board nRF52810. I need to know can I use nRF52DK  to program my custom  board with arduino hex file?
If not is there any way to achieve same?
  • Yes, I have my schematic reviewed here only before production.
    Here are the private ticket IDs :
    • Case ID: 297698
    • Case ID: 299051
    The image I attached earlier, shows the same pins connection as in the reference image you have shared.
    I have flashed the code with VS code, not the Programmer software. So I want to know, do I have to use only Programmer software for custom board flashing?
    It seems that you do not have the split from VDD to include VTG in your connections, and you do not have GND detect connected either, which is likely why your are unable to program the target.
    Please connect these so that your connections match the image I shared earlier exactly.
    No, you can use any programmer as the programmer will tell the debugger how to flash it, and the debugger will decide which target it should flashed based on the availability of the SWD interface.
    Please remedy the connections, and let me know if you are able to program the target as expected.
    Karl
  • Now when I flash the code it doesn't reset the code on nRF52840 DK. So I hope it uploads the code in custom PCB.
    But I haven't given any testing led on the custom board. So is there a way to serial read from pins P0.5 & P0.8?
    That's good!
    If the debugger reports that the flashing was successful, and the DK program is not overwritten, then you know that the application was written to the external target.
    On the external board?
    P0.05 and P0.08 can be used as GPIOs, so this will depend on how you have routed the pins on your external board and how they are configured in your application.
    Karl
  • On the external board?
    Yes, I'm talking about the custom PCB.
    I have connected male headers directly to the pins: P0.05 and P0.08 on the custom PCB.
    Could you please guide me to some examples to configure those GPIO pins to set HIGH or LOW?
