Ble eddystone and ibeacon simultaneously nrf52832
Hello, I am working on a project that consists of sending Eddystone and ibeacon packets simultaneously, to begin with, I started by sending one package of each separately, it was a success but the problem is that when I send both packages through my uc button,
it sends only the first packet while the second one is never sent, here's a screenshot for a better understanding :
I want to stop sending the first package (ibeacon) by pressing the button_1 (it works).
I want to send the second package (Eddystone) by pressing the button_2 (this one doesn't work) and yet it detects the button press.
Ps : the button is on a chip nordic nrf52832.
  • Hi Hieu,
    Ok I understand, let's do it like this then, Yes please I want to know how to switch between eddystone advertisement and ibeacon advertisement.
    Again, thank you very much,
    Abdullah
  • Hi Abdullah,
    Just want to let you know that I have started working on it. There are a few issues, I will hopefully be done soon.
    I was using my colleague's guide here:  How to update advertising data dynamically using BLE Advertising library
    It turned out the library that he used is only for connectable advertising. Here we are using beacon, so that method is not applicable.
    However, I still share the link, because that example shows a way to change advertising data during connectable advertising.
    I will have to redo this work using the basic API. However, I am out of office tomorrow, so I will resume on next Monday, unless I find some time in the weekend.
    Sorry again for the wait. It is quite bad, this is not supposed to be a major workload.
    Hieu
  • Hi Hieu,
    No problem, take your time, and thanks again.
    Abdullah
  • Hi Abdullah,
    Thank you for your patience. There were some delays due to unforeseen sicknesses, but I finally completed the sample code I promised.
    There is one problem however, I haven't fully tested the behavior. I am working remotely, and my remote test setup is malfunctioning in some parts, so I am could not test the following:
    - Eddystone URL Service Data
    - Advertising Flags
    - Button handling (so I use a timer-based approach to change advertising data instead)
    So, if you want it now, below is the code. Otherwise, I will perform the necessary test next week when I return to office.
    Just create a new project using the <SDK root>/example/ble_peripheral/ble_app_template, replace main.c with the content below, and observe that the device should cycle between
    - 2 seconds of advertising as an iBeacon
    - 4 seconds of advertising as an Eddystone-URL beacon
    You can find the update implemented in update_gap_adv_data() and app_timer_handler().
    Below is the tested code that works as you expected. To test, just create a new project using the <SDK root>/example/ble_peripheral/ble_app_template, replace main.c with the content below.
    The expected behavior is:
    It starts up broadcasting as an iBeacon.
    Button 1 makes it broadcast as an iBeacon.
    Button 2 makes it broadcast as an Eddystone URL
    You can find the update implemented in update_gap_adv_data().
    I hope I included sufficient comments. Don't hesitate to let me know if you have any questions.
    Sorry again for the very long wait.
     * Copyright (c) 2014 - 2022, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_template_main main.c
     * @ingroup ble_sdk_app_template
     * @brief Template project main file.
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
        ret_code_t err_code;
            nrf_pwr_mgmt_run();
    // Dummy function for quick browsing in SES
    static void BLE_INIT_SECTION(void) {}
    #define APP_BLE_OBSERVER_PRIO   3   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG    1   /**< A tag identifying the SoftDevice BLE configuration. */
        ret_code_t err_code = NRF_SUCCESS;
                // No implementation needed.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    static void EDDYSTONE_URL_SECTION(void) {}
    static const uint16_t GOOGLE_LLC_EDDYSTONE_UUID16 = 0xFEAA;
    static const ble_uuid_t es_uuid =
        .uuid = GOOGLE_LLC_EDDYSTONE_UUID16,
        .type = BLE_UUID_TYPE_BLE
    static ble_uuid_t es_uuid_array[] = { es_uuid };
    static uint8_t es_url_service_data_raw[] = "\x10\x00\x01nordicsemi\x00";
    /*                                      |   |   |             |-> \x00: Eddystone's special URL encoding 0x00, ".com"
                                            |   |   |-> \x03: URL Scheme 0x03, "https://www."
                                            |   |-> \x00: TX Power. If TX Power is not updated, it is 0 dBm
                                            |-> \x10: Frame Type 0x10, Eddystone URL
        Overall, the URL is "https://www.nordicsemi.com"
        Details of the byte encoding rules can be found at https://github.com/google/eddystone/tree/master/eddystone-url
    /** @brief Buffer for storing an encoded advertising set. */
    static uint8_t es_encoded_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];
    /** @brief GAP buffer structs that contains pointers to the encoded advertising data buffers. */
    static ble_gap_adv_data_t es_url_gap_adv_data =
        .adv_data =
            .p_data = es_encoded_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static void es_url_gap_adv_data_init(void)
        // Helper "translator" struct for encoding human-readable adv data into GAP adv data buffers
        ble_advdata_t ble_advdata = {0};
        ble_advdata.flags =  (BLE_GAP_ADV_FLAG_LE_GENERAL_DISC_MODE | BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED);
        ble_advdata.uuids_complete.uuid_cnt =    1; // Only Eddystone UUID
        ble_advdata.uuids_complete.p_uuids =     es_uuid_array;
        ble_advdata_service_data_t t_service_data;
        t_service_data.service_uuid =   GOOGLE_LLC_EDDYSTONE_UUID16;
        t_service_data.data.size =      sizeof(es_url_service_data_raw) - 1;
        t_service_data.data.p_data =    es_url_service_data_raw;
        // Since there would be only one member in the array, just pass the service data's address instead
        ble_advdata.p_service_data_array = &t_service_data;
        ble_advdata.service_data_count = 1;
        // Encode the adv data into GAP adv data buffers
        err_code = ble_advdata_encode(&ble_advdata, es_url_gap_adv_data.adv_data.p_data, &es_url_gap_adv_data.adv_data.len);
        uint8_t i;
        NRF_LOG_INFO("es_url_gap_adv_data: len = %d", es_url_gap_adv_data.adv_data.len);
        NRF_LOG_HEXDUMP_INFO(es_url_gap_adv_data.adv_data.p_data, es_url_gap_adv_data.adv_data.len);
    static void IBEACON_SECTION(void) {}
    #define APP_BEACON_INFO_LENGTH  0x17                        /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH     0x15                        /**< Length of manufacturer specific data in the advertisement. */
    #define APP_DEVICE_TYPE         0x02                        /**< 0x02 refers to Beacon. */
    #define APP_COMPANY_IDENTIFIER  0x0059                      /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define APP_MAJOR_VALUE         0x01, 0x02                  /**< Major value used to identify Beacons. */
    #define APP_MINOR_VALUE         0x03, 0x04                  /**< Minor value used to identify Beacons. */
    #define APP_BEACON_UUID         0x01, 0x12, 0x23, 0x34, \
                                    0x45, 0x56, 0x67, 0x78, \
                                    0x89, 0x9a, 0xab, 0xbc, \
                                    0xcd, 0xde, 0xef, 0xf0      /**< Proprietary UUID for Beacon. */
    #define APP_MEASURED_RSSI       0xC3                        /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
    static const uint8_t iBeacon_manuf_data_raw[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
        APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                             // implementation.
        APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                             // manufacturer specific data in this implementation.
        APP_BEACON_UUID,     // 128 bit UUID value.
        APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
        APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
        APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                             // this implementation.
    static uint8_t iBeacon_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t iBeacon_gap_adv_data =
        .adv_data =
            .p_data = iBeacon_enc_advdata,
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    static void iBeacon_gap_adv_data_init(void)
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        manuf_specific_data.data.p_data = (uint8_t *) iBeacon_manuf_data_raw;
        manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        err_code = ble_advdata_encode(&advdata, iBeacon_gap_adv_data.adv_data.p_data, &iBeacon_gap_adv_data.adv_data.len);
    static void ADVERTISING_SECTION(void) {}
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    /**@brief Initialize advertising parameters (used when starting advertising).
    static void adv_params_init(void)
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;                                    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = BLE_GAP_ADV_INTERVAL_MIN;
        m_adv_params.duration        = BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED;   // Never time out.
        uint32_t      err_code;
        es_url_gap_adv_data_init();
        iBeacon_gap_adv_data_init();
        adv_params_init();
        //err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &es_url_gap_adv_data, &m_adv_params);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &iBeacon_gap_adv_data, &m_adv_params);
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    static void APP_TIMER_SECTION(void) {}
    APP_TIMER_DEF(app_timer_instance);
    #define APP_TIMER_PERIOD    APP_TIMER_TICKS(2000L)  // 2000 ms
    static void update_gap_adv_data(ble_gap_adv_data_t* p_gap_adv_data)
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, p_gap_adv_data, NULL);
        // sd_ble_gap_adv_set_configure returns NRF_ERROR_INVALID_STATE in two cases:
        //  1. The 3rd parameter "p_adv_params" is not NULL, while advertising
        //  2. While advertising, the same data buffers (as the one being advertising) is provided
        // Using this function, case 1 is not possible.
        // Case 2 is acceptable. For example, if some advertising data is requested at a button press
        // Therefore, only perform error handling if the err_code is not NRF_ERROR_INVALID_STATE
    static void app_timer_handler(void * p_context)
        static uint8_t x;
        NRF_LOG_INFO("%d", ++x);
        //switch (x % 3)
        //    case 0:
        //        update_gap_adv_data(&iBeacon_gap_adv_data);
        //        NRF_LOG_INFO("iBeacon_gap_adv_data");
        //    break;
        //    case 1:
        //        update_gap_adv_data(&es_url_gap_adv_data);
        //        NRF_LOG_INFO("es_url_gap_adv_data");
        //    break;
        //    case 2:
        //        // Intentionally repeat a case to emulate the same button is pressed twice
        //    break;
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void app_timers_init(void)
        err_code = app_timer_init();
        err_code = app_timer_create(&app_timer_instance,
                                      APP_TIMER_MODE_REPEATED,
                                      app_timer_handler);
    /**@brief Function for starting timers.
    static void app_timers_start(void)
           err_code = app_timer_start(app_timer_instance,
                                        APP_TIMER_PERIOD,
                                        NULL);
    static void BUTTON_SECTION(void) {}
     * @param[in]   event   Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_KEY_0:
                NRF_LOG_INFO("BSP_EVENT_KEY_0");
            case BSP_EVENT_KEY_1:
                NRF_LOG_INFO("BSP_EVENT_KEY_1");
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
    /**@brief Function for application main entry.
        bool erase_bonds;
        // Initialize.
        log_init();
        app_timers_init();
        buttons_leds_init();
        power_management_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("Template example started.");
        app_timers_start();
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Hieu
  • Hi Abdullah,
    There was one missing line in the previous code after all. I fixed it and updated the behavior to work like you initially want. All information is edited into my previous comment.
    By the way, if you are curious, the missing line of code is:
        // vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
        ble_advdata.service_data_count = 1; // <<<<<<<<<<<<<< This is the missing line
    Hieu
