Advertising 128 bit UUID wrong parameter
I already used the sd_ble_uuid_vs_add for adding my base UUID in the internal table and it return a valid uuid_type (in my specific case it's 0x06). I need to add my UUID service into the advertising packet. The UUIDs array is defined as follow :
ble_uuid_t m_adv_uuids[] = {{BLE_UUID_COM_SERVICE,m_com.uuid_type}};
but I receive the err_code = 7 (NRF_ERROR_INVALID_PARAMETER) from the ble_advdata_set function. I'm sure that m_com.uuid_type has the right value because I print it on the console (its value is 0x06).
Why ?
Thanks, Paolo.
  • I see following .... The ble_advdata_set is calling twice, the first time from ble_advertising_init and the second one from ble_advertising_start. The ble_advertising_init is called inside the function I create the m_adv_uuids array and set it to the ble_advdata_t (in the uuid_complete.p_uuids). Inside, the function ble_advertising_init saves this pointer with following code :
    m_advdata.uuids_complete       = p_advdata->uuids_complete;
    Of course this pointer is valid at first call (it's on the stack) but not valid in the second one.
    It means that my m_adv_uuids[] must be defined static and filled when I have the right value for m_com.uuid_type. Now it works. Is it the right way ?
    I didn't find any good documentation about it.
    Thanks, Paolo.
  • If it works, I would guess you have done correctly. I'm having a bit of trouble understanding you though, could you include some more complete code that shows what you mean?
