I'm using the PPK2 to evaluate a DUT which is transmitting over BLE using NUS in SDK 17.0.2. I'm seeing very large variability over each transmission and was wondering if there were any ways to optimize this. Here is one graph for example showing 5 transmissions of the same packet. The middle peak average was 0.33uA while the 5th peak was 0.13uA. While these values are close the percent difference is huge and I was wondering what might cause this.
Also just as a sanity check when the device is powered off the PPK2 reads 0.11uA. Is this a typical leak current for an nRF52840?
I also had even greater variation when power profiling the advertising routine. Each peak represents 10 seconds of advertising. The middle peak was 3.2uA average whereas the first peak was only 0.18 uA average. Is there a way to optimize this, or an explanation of what may be happening to cause such huge differences in an advertising routine which should be similar between trials?
