nrf9160 USAGE FAULT
Hi:
This is Log:
I modify mqtt_simple into 2 threads.
This is code:
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <stdio.h>
#include <zephyr/drivers/uart.h>
#include <string.h>
#include <zephyr/random/rand32.h>
#include <zephyr/net/mqtt.h>
#include <zephyr/net/socket.h>
#if defined(CONFIG_NRF_MODEM_LIB)
#include <nrf_modem_at.h>
#endif /* CONFIG_NRF_MODEM_LIB */
#include <modem/lte_lc.h>
#if defined(CONFIG_MODEM_KEY_MGMT)
#include <modem/modem_key_mgmt.h>
#if defined(CONFIG_LWM2M_CARRIER)
#include <lwm2m_carrier.h>
#include <dk_buttons_and_leds.h>
#include "certificates.h"
#include "user_twi.h"
LOG_MODULE_REGISTER(mqtt_simple, CONFIG_MQTT_SIMPLE_LOG_LEVEL);
/* Buffers for MQTT client. */
static uint8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static uint8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* File descriptor */
static struct pollfd fds;
#if defined(CONFIG_MQTT_LIB_TLS)
static int certificates_provision(void)
	int err = 0;
	LOG_INF("Provisioning certificates");
#if defined(CONFIG_NRF_MODEM_LIB) && defined(CONFIG_MODEM_KEY_MGMT)
	err = modem_key_mgmt_write(CONFIG_MQTT_TLS_SEC_TAG,
				   MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
				   CA_CERTIFICATE,
				   strlen(CA_CERTIFICATE));
	if (err) {
		LOG_ERR("Failed to provision CA certificate: %d", err);
		return err;
#elif defined(CONFIG_BOARD_QEMU_X86) && defined(CONFIG_NET_SOCKETS_SOCKOPT_TLS)
	err = tls_credential_add(CONFIG_MQTT_TLS_SEC_TAG,
				 TLS_CREDENTIAL_CA_CERTIFICATE,
				 CA_CERTIFICATE,
				 sizeof(CA_CERTIFICATE));
	if (err) {
		LOG_ERR("Failed to register CA certificate: %d", err);
		return err;
	return err;
#endif /* defined(CONFIG_MQTT_LIB_TLS) */
K_SEM_DEFINE(carrier_registered, 0, 1);
int lwm2m_carrier_event_handler(const lwm2m_carrier_event_t *event)
	switch (event->type) {
	case LWM2M_CARRIER_EVENT_BSDLIB_INIT:
		LOG_INF("LWM2M_CARRIER_EVENT_BSDLIB_INIT");
	case LWM2M_CARRIER_EVENT_CONNECTING:
		LOG_INF("LWM2M_CARRIER_EVENT_CONNECTING");
	case LWM2M_CARRIER_EVENT_CONNECTED:
		LOG_INF("LWM2M_CARRIER_EVENT_CONNECTED");
	case LWM2M_CARRIER_EVENT_DISCONNECTING:
		LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTING");
	case LWM2M_CARRIER_EVENT_DISCONNECTED:
		LOG_INF("LWM2M_CARRIER_EVENT_DISCONNECTED");
	case LWM2M_CARRIER_EVENT_BOOTSTRAPPED:
		LOG_INF("LWM2M_CARRIER_EVENT_BOOTSTRAPPED");
	case LWM2M_CARRIER_EVENT_REGISTERED:
		LOG_INF("LWM2M_CARRIER_EVENT_REGISTERED");
		k_sem_give(&carrier_registered);
	case LWM2M_CARRIER_EVENT_DEFERRED:
		LOG_INF("LWM2M_CARRIER_EVENT_DEFERRED");
	case LWM2M_CARRIER_EVENT_FOTA_START:
		LOG_INF("LWM2M_CARRIER_EVENT_FOTA_START");
	case LWM2M_CARRIER_EVENT_REBOOT:
		LOG_INF("LWM2M_CARRIER_EVENT_REBOOT");
	case LWM2M_CARRIER_EVENT_ERROR:
		LOG_ERR("LWM2M_CARRIER_EVENT_ERROR: code %d, value %d",
			((lwm2m_carrier_event_error_t *)event->data)->code,
			((lwm2m_carrier_event_error_t *)event->data)->value);
		LOG_WRN("Unhandled LWM2M_CARRIER_EVENT: %d", event->type);
	return 0;
#endif /* defined(CONFIG_LWM2M_CARRIER) */
/**@brief Function to print strings without null-termination
static void data_print(uint8_t *prefix, uint8_t *data, size_t len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	LOG_INF("%s%s", (char *)prefix, (char *)buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	struct mqtt_publish_param param;
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = data;
	param.message.payload.len = len;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", data, len);
	LOG_INF("to topic: %s len: %u",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, &param);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
	struct mqtt_topic subscribe_topic = {
		.topic = {
			.utf8 = CONFIG_MQTT_SUB_TOPIC,
			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
		.qos = MQTT_QOS_1_AT_LEAST_ONCE
	const struct mqtt_subscription_list subscription_list = {
		.list = &subscribe_topic,
		.list_count = 1,
		.message_id = 1234
	LOG_INF("Subscribing to: %s len %u", CONFIG_MQTT_SUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
	return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
	int ret;
	int err = 0;
	/* Return an error if the payload is larger than the payload buffer.
	 * Note: To allow new messages, we have to read the payload before returning.
	if (length > sizeof(payload_buf)) {
		err = -EMSGSIZE;
	/* Truncate payload until it fits in the payload buffer. */
	while (length > sizeof(payload_buf)) {
		ret = mqtt_read_publish_payload_blocking(
				c, payload_buf, (length - sizeof(payload_buf)));
		if (ret == 0) {
			return -EIO;
		} else if (ret < 0) {
			return ret;
		length -= ret;
	ret = mqtt_readall_publish_payload(c, payload_buf, length);
	if (ret) {
		return ret;
	return err;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
		      const struct mqtt_evt *evt)
	int err;
	switch (evt->type) {
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			LOG_ERR("MQTT connect failed: %d", evt->result);
		LOG_INF("MQTT client connected");
		subscribe();
	case MQTT_EVT_DISCONNECT:
		LOG_INF("MQTT client disconnected: %d", evt->result);
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		LOG_INF("MQTT PUBLISH result=%d len=%d",
			evt->result, p->message.payload.len);
		err = publish_get_payload(c, p->message.payload.len);
		if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE) {
			const struct mqtt_puback_param ack = {
				.message_id = p->message_id
			/* Send acknowledgment. */
			mqtt_publish_qos1_ack(&client, &ack);
		if (err >= 0) {
			data_print("Received: ", payload_buf,
			/* Echo back received data */
			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
				payload_buf, p->message.payload.len);
		} else if (err == -EMSGSIZE) {
			LOG_ERR("Received payload (%d bytes) is larger than the payload buffer "
				"size (%d bytes).",
				p->message.payload.len, sizeof(payload_buf));
		} else {
			LOG_ERR("publish_get_payload failed: %d", err);
			LOG_INF("Disconnecting MQTT client...");
			err = mqtt_disconnect(c);
			if (err) {
				LOG_ERR("Could not disconnect: %d", err);
	} break;
	case MQTT_EVT_PUBACK:
			LOG_ERR("MQTT PUBACK error: %d", evt->result);
		LOG_INF("PUBACK packet id: %u", evt->param.puback.message_id);
	case MQTT_EVT_SUBACK:
			LOG_ERR("MQTT SUBACK error: %d", evt->result);
		LOG_INF("SUBACK packet id: %u", evt->param.suback.message_id);
	case MQTT_EVT_PINGRESP:
			LOG_ERR("MQTT PINGRESP error: %d", evt->result);
		LOG_INF("Unhandled MQTT event type: %d", evt->type);
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static int broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		LOG_ERR("getaddrinfo failed: %d", err);
		return -ECHILD;
	addr = result;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			LOG_INF("IPv4 Address found %s", ipv4_addr);
		} else {
			LOG_ERR("ai_addrlen = %u should be %u or %u",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
	return err;
#define IMEI_LEN 15
#define CGSN_RESPONSE_LENGTH (IMEI_LEN + 6 + 1) /* Add 6 for \r\nOK\r\n and 1 for \0 */
#define CLIENT_ID_LEN sizeof("nrf-") + IMEI_LEN
#else
#define RANDOM_LEN 10
#define CLIENT_ID_LEN sizeof(CONFIG_BOARD) + 1 + RANDOM_LEN
#endif /* defined(CONFIG_NRF_MODEM_LIB) */
/* Function to get the client id */
static const uint8_t* client_id_get(void)
	static uint8_t client_id[MAX(sizeof(CONFIG_MQTT_CLIENT_ID),
				     CLIENT_ID_LEN)];
	if (strlen(CONFIG_MQTT_CLIENT_ID) > 0) {
		snprintf(client_id, sizeof(client_id), "%s",
			 CONFIG_MQTT_CLIENT_ID);
		goto exit;
	char imei_buf[CGSN_RESPONSE_LENGTH + 1];
	int err;
	err = nrf_modem_at_cmd(imei_buf, sizeof(imei_buf), "AT+CGSN");
	if (err) {
		LOG_ERR("Failed to obtain IMEI, error: %d", err);
		goto exit;
	imei_buf[IMEI_LEN] = '\0';
	snprintf(client_id, sizeof(client_id), "nrf-%.*s", IMEI_LEN, imei_buf);
#else
	uint32_t id = sys_rand32_get();
	snprintf(client_id, sizeof(client_id), "%s-%010u", CONFIG_BOARD, id);
#endif /* !defined(NRF_CLOUD_CLIENT_ID) */
exit:
	LOG_DBG("client_id = %s", (char *)client_id);
	return client_id;
/**@brief Initialize the MQTT client structure
static int client_init(struct mqtt_client *client)
	int err;
	mqtt_client_init(client);
	err = broker_init();
	if (err) {
		LOG_ERR("Failed to initialize broker connection");
		return err;
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = client_id_get();
	client->client_id.size = strlen(client->client_id.utf8);
	client->password = NULL;
	client->user_name = NULL;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	struct mqtt_sec_config *tls_cfg = &(client->transport).tls.config;
	static sec_tag_t sec_tag_list[] = { CONFIG_MQTT_TLS_SEC_TAG };
	LOG_INF("TLS enabled");
	client->transport.type = MQTT_TRANSPORT_SECURE;
	tls_cfg->peer_verify = CONFIG_MQTT_TLS_PEER_VERIFY;
	tls_cfg->cipher_count = 0;
	tls_cfg->cipher_list = NULL;
	tls_cfg->sec_tag_count = ARRAY_SIZE(sec_tag_list);
	tls_cfg->sec_tag_list = sec_tag_list;
	tls_cfg->hostname = CONFIG_MQTT_BROKER_HOSTNAME;
	tls_cfg->session_cache = IS_ENABLED(CONFIG_MQTT_TLS_SESSION_CACHING) ?
					    TLS_SESSION_CACHE_ENABLED :
					    TLS_SESSION_CACHE_DISABLED;
#else
	/* TLS session caching is not supported by the Zephyr network stack */
	tls_cfg->session_cache = TLS_SESSION_CACHE_DISABLED;
#else
	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
	return err;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
		fds.fd = c->transport.tcp.sock;
	} else {
		fds.fd = c->transport.tls.sock;
#else
		return -ENOTSUP;
	fds.events = POLLIN;
	return 0;
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static int modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	/* Turn off LTE power saving features for a more responsive demo. Also,
	 * request power saving features before network registration. Some
	 * networks rejects timer updates after the device has registered to the
	 * LTE network.
	LOG_INF("Disabling PSM and eDRX");
	lte_lc_psm_req(false);
	lte_lc_edrx_req(false);
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on
		 * and connected.
	} else {
		/* Wait for the LWM2M_CARRIER to configure the modem and
		 * start the connection.
		LOG_INF("Waitng for carrier registration...");
		k_sem_take(&carrier_registered, K_FOREVER);
		LOG_INF("Registered!");
#else /* defined(CONFIG_LWM2M_CARRIER) */
		int err;
		LOG_INF("LTE Link Connecting...");
		err = lte_lc_init_and_connect();
		if (err) {
			LOG_INF("Failed to establish LTE connection: %d", err);
			return err;
		LOG_INF("LTE Link Connected!");
#endif /* defined(CONFIG_LTE_LINK_CONTROL) */
	return 0;
struct k_timer timer;
void expiry_function(struct k_timer *timer_id)
	LOG_INF("expiry function");
	twi_read();
#if 0
void main(void)
	int err;
	uint32_t connect_attempt = 0;
	LOG_INF("The MQTT simple sample started");
	err = certificates_provision();
	if (err != 0) {
		LOG_ERR("Failed to provision certificates");
		return;
	err = twi_init();
	LOG_INF("twi ret=%d",err);
	twi_example();
	do {
		err = modem_configure();
		if (err) {
			LOG_INF("Retrying in %d seconds",
				CONFIG_LTE_CONNECT_RETRY_DELAY_S);
			k_sleep(K_SECONDS(CONFIG_LTE_CONNECT_RETRY_DELAY_S));
	} while (err);
	err = client_init(&client);
	if (err != 0) {
		LOG_ERR("client_init: %d", err);
		return;
	//k_timer_init(&timer, expiry_function, NULL);
	//k_timer_start(&timer,  K_SECONDS(0),  K_SECONDS(5));
	twi_read();
do_connect:
	if (connect_attempt++ > 0) {
		LOG_INF("Reconnecting in %d seconds...",
			CONFIG_MQTT_RECONNECT_DELAY_S);
		k_sleep(K_SECONDS(CONFIG_MQTT_RECONNECT_DELAY_S));
	err = mqtt_connect(&client);
	if (err != 0) {
		LOG_ERR("mqtt_connect %d", err);
		goto do_connect;
	err = fds_init(&client);
	if (err != 0) {
		LOG_ERR("fds_init: %d", err);
		return;
	while (1) {
		err = poll(&fds, 1, mqtt_keepalive_time_left(&client));
		if (err < 0) {
			LOG_ERR("poll: %d", errno);
		err = mqtt_live(&client);
		if ((err != 0) && (err != -EAGAIN)) {
			LOG_ERR("ERROR: mqtt_live: %d", err);
		if ((fds.revents & POLLIN) == POLLIN) {
			err = mqtt_input(&client);
			if (err != 0) {
				LOG_ERR("mqtt_input: %d", err);
		if ((fds.revents & POLLERR) == POLLERR) {
			LOG_ERR("POLLERR");
		if ((fds.revents & POLLNVAL) == POLLNVAL) {
			LOG_ERR("POLLNVAL");
	err = mqtt_disconnect(&client);
	if (err) {
		LOG_ERR("Could not disconnect MQTT client: %d", err);
	goto do_connect;
#define STACKSIZE 1024
#define THREAD0_PRIORITY 7
#define THREAD1_PRIORITY 7
void thread0(void)
	int err;
	if (err != 0) {
		return;
	err = twi_init();
	twi_example();
	do {
		if (err) {
	} while (err);
	if (err != 0) {
		return;
	//twi_read();
do_connect:
	if (err != 0) {
		goto do_connect;
	if (err != 0) {
		return;
	while (1) {
		if (err < 0) {
			if (err != 0) {
			LOG_ERR("POLLERR");
	if (err) {
	goto do_connect;
void thread1(void)
	while (1) {
		k_msleep(5000);
/* STEP 4 - Define and initialize the two threads */
K_THREAD_DEFINE(thread0_id, STACKSIZE, thread0, NULL, NULL, NULL,
		THREAD0_PRIORITY, 0, 0);
K_THREAD_DEFINE(thread1_id, STACKSIZE, thread1, NULL, NULL, NULL,
		THREAD1_PRIORITY, 0, 0);
